Nitrous for cooling AIT - Page 3 - Forums at Modded Mustangs
post #41 of 58 Old June 2nd, 2013, 01:33 AM
MM elder
casper gt's Avatar
the best thing you can do for yourself, your car & your wallet is quit thinking & spending money & just get to the track & get some experiance.
the first tip is a simple one, why are you taking so much time going around the water box & backing up? what do you think that is doing to your ait's?
there is absolutely no reason for it, you should have been right up there with the ls car, ready to go, hell he wasn't very fast to the line either, you could have beat him up there.
look at the video you posted again & think about how much time you could have saved yourself just in that short video, time = heat in a touchy application like yours.
my second tip would be if you must spend money, spend it on a cowl hood to get some heat out & some decent wheels & tires, keep the m/t's for street use.
aside from that, like I said above, get some track time, then make a decision.
MM BRACKET RACING CREW CO-FOUNDER
2012 300a GT A6......10.78 @ 124.........sold
2014 301a GT A6.............12.73 @ 112........d/r only
casper gt is offline
post #42 of 58 Old June 2nd, 2013, 09:35 AM
JayC's Avatar
Good point about the stageing time. I love running boosted cars for that very reason. I never start my burnout untill the boosted car is done with theirs, then stage as late as possible. It give me a huge advantage!
12.25 @ 111 mph w/ CMS stage II cams
10.95 @ 119 mph NX 150 shot
6.96 @ 102 1/8th mile
Best 60', 1.43
JayC is offline
post #43 of 58 Old June 2nd, 2013, 11:33 AM
MM elder
casper gt's Avatar
it's an even better tool when your in acual competition & your track runs autostart.
I let him heat up & then power out of the burnout & double bulb him as soon as I see him light his prestage light.
works every time, lol.
I've got a few tricks for the nitrous guys too..................
post #44 of 58 Old June 2nd, 2013, 11:55 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
I'm just an old country boy this is getting to complicated I think I'll just turbo my Kubota and call it a day lol
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #45 of 58 Old June 3rd, 2013, 07:40 PM
It's not that complicated LOL!
Let's see, I can run that same ET with 150rwhp less than you've got - and I'm not bragging because I pretty much suck at getting a good ET for my trap speed, compared to some of the dragstrip veterans out there.
I use 275/60/15 ET Street Radials and your using street-sized wheels/tires.
It's in the wheels and tires, and driving skill of course ...
Your trap speed should be over 130mph if you're able to get traction going down the strip (at that power level).
---------- Post added at 07:40 PM ---------- Previous post was at 07:38 PM ----------
So much for "courtesy staging" LOL!
MM Bracket Racing Crew Member #5
saxmanJJ is offline
post #46 of 58 Old June 3rd, 2013, 09:47 PM
MM elder
casper gt's Avatar
I guess you can look at it that way but theres no friends on race day once they call us out of the lanes.
IMO, a person shouldn't be bracket racing a combo that comprimises their chances of winning & if the do, shame on their compeditor for not taking advantage of them, I use the same approach on someone who takes their time deep staging & have burned many deep stage guys with autostart as well.
Jay C happend to mention race type circumstances so I followed thru with me take on it.
race days are for 1 thing, winning, screw courtesy.
test & tunes are a little diffrent though, in that case I just avoid being paired with a guy that takes too long at the starting line.
post #47 of 58 Old June 3rd, 2013, 10:00 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
After talking it over with my tuner Ive decided to just do the intercooler, and not the nitrous mix.
And ill be doing the 15" wheels since I cant hook up these damn Mickey T and im not sure what tires to get should i get slicks or drag radials?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #48 of 58 Old June 3rd, 2013, 10:13 PM
MM elder
casper gt's Avatar
it kinda depends on weither you want to haul slicks out to the track with you or just drive out on drag radials.
my personal vote on an auto car would be d/r's, screw changing tires at the track.
post #49 of 58 Old June 3rd, 2013, 10:19 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Changing tires is no big deal for me so if slicks are the best way Thats what ill do. I was looking at these
http://www.summitracing.com/parts/gdy-2790
http://www.summitracing.com/parts/sum-521-5866ps
from now on on hot days ill be hauling my car to the track so It does not have 45-60 minutes of heat soak on it before I get there.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #50 of 58 Old June 3rd, 2013, 10:40 PM
MM elder
casper gt's Avatar
I'd stick with a more main stream tire/slick (ie. m/t, hoosier)
I would also go a little wider.
that said however, I still stand by the d/r comment, you've got enough problems as it is trying to learn all this racing stuff, you don't really need to deal with slicks walking around on you on top end at 130+, d/r's will make life alot easier for you.
these on an 8" rim will be all you need,
http://www.summitracing.com/parts/mtt-3753r
if you must have a 28 for some reason, then here you go,
lastly if you think you need more (you don't) here you go,
http://www.summitracing.com/parts/mtt-90000001536
any of those will support 60's faster than your car will ever see in it's current state & drive well at speed.
post #51 of 58 Old June 3rd, 2013, 10:44 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Thanks for that information, Im not very knowledgable in this area so Ill ask the crazy question thats bothering me.
Those are pretty close to what i have as far as tread, but they are much taller so what makes these work better then what I have?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #52 of 58 Old June 4th, 2013, 12:13 AM
MM elder
casper gt's Avatar
it's mainly the tread compound & the ability for the side wall to flex because of the 15" rim vs what you have now.
what you have now can get the job done as well but thore will make life easier.
post #53 of 58 Old June 4th, 2013, 08:51 PM
I don't see much "double-bulbing" where I race (and I mean during a bracket race not a test and tune). In fact you can get disqualified for doing it.
saxmanJJ is offline
post #54 of 58 Old June 5th, 2013, 02:36 AM
MM elder
casper gt's Avatar
yeah, its track sensitive, some let you get away with it, some don't.
as long as everyone knows what they are doing then it's a mute point, both guys will go in immedeately anyway, it's the slackers that generally take their good old time staging & double bulbed or not they are generally going home early anyway.
if I race at a track with starting line restrictions, I just adjust my dial accordingly & deal with pesky cars on the other end..............
post #55 of 58 Old June 5th, 2013, 09:33 AM
JayC's Avatar
It's my understanding that if the other car has lit the first bulb you can drive on in and stage. If he hasn't lit one bulb then you are "double-bulbing" .
Best 60', 1.43
JayC is offline
post #56 of 58 Old June 12th, 2013, 10:54 AM
We have been doing alot of SC setups with spray bars plumbed into the lower. We have been seeing double the increase or more in HP gains. 50 HP shots have easily netted 100 HP gain. We have one customer with a ZR1 that gained 200 on a 100 shot single nozzle system.
post #57 of 58 Old June 12th, 2013, 04:22 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Spray bars plumbed into what? I was thinking pre intercooler just for cooling purposes on smoking hit days.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #58 of 58 Old June 12th, 2013, 04:27 PM
T-Lee. 30's Avatar
Send a message via Yahoo to T-Lee. 30
look into a co2 sprayer
I haven't seen or heard of anyone on here running one I just seen it on youtube a long time ago.
http://compare.ebay.com/like/3307811...Types&var=sbar
-03 GT V1S trim 5psi, 3xxhp/3xxtq
-06 TBSS LS3H,cam,f.exhaust 4xxrwhp/4xxrwtq
-03 Dakota SLT Quad cab 2wd stock
Iraq and Afghanistan War Vet . Convoys and convoy security. My Wife is also a Army and Afghanistan war vet.
T-Lee. 30 is offline
