The Turbo Build Has Begun - Page 142 - Forums at Modded Mustangs
 116Likes
post #2821 of 5051 Old June 21st, 2015, 08:37 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Originally Posted by RDY4WAR View Post
On 93, no. I'd stay 11.8-12.0 range on 93. E85 though I'd try to get closer to 10.8.
Are the plugs above on 93 or E85?
93 I ran them about 10 minutes on Corn.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2822 of 5051 Old June 21st, 2015, 08:53 PM
Rent Asunder!
RDY4WAR's Avatar
No wonder they look weird. lol Put in a fresh set of plugs to run only on corn.
1993 Camaro bracket car
2002 Tahoe family/tow rig
2006 Altima daily
RDY4WAR is offline
post #2823 of 5051 Old June 21st, 2015, 08:53 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Well I pulled them prior to and they were perfect brown Its almost like the corn cleans them off. Ill put me a new set in before I start any WOT pulls. these things have almost no run time on them they are brand new. This is the second set I have installed since I started tuning on 93. It seems like a waste of money and time to put in new plugs that have less then 100 miles or so on them.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2824 of 5051 Old June 21st, 2015, 09:04 PM
Rent Asunder!
RDY4WAR's Avatar
Originally Posted by CalBoy101 View Post
So if the plating is all burned off then you are too lean?
The more burn on the base ring, especially if it moves into the 1st and 2nd threads, means you're getting too hot. It doesn't necessarily mean you're too lean. Could be fat with too hot of a plug. Alcohol is a weird fuel. You could make adjustments with the fuel that might raise or lower EGTs and AFR but hardly change the reading on the plug.
---------- Post added at 09:04 PM ---------- Previous post was at 08:55 PM ----------
I know some guys who put in a fresh set of plugs every pass down the track when tuning so they have a fresh slate to gauge each adjustment. I love the recessed tip BR6EF and BR7EF plugs which are only like $2/ea. If you're using expensive $6+/ea plugs then I could understand. At least clean them off good and try to get all the carbon depositing off of them from the gas before reinstalling for E85. The alcohol will eat away the carbon eventually anyway but still. It's just better to grab a clean sheet of paper to plot new data.
2006 Altima daily
RDY4WAR is offline
post #2825 of 5051 Old June 21st, 2015, 09:20 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Thanks for the tips I used to run the BR7EF's and they did good for me and were cheap, this time I stepped up the plug to a more expensive unit. I did clean them of this time with carbon cleaner.
---------- Post added at 09:20 PM ---------- Previous post was at 09:17 PM ----------
to Dumb this down for someone who might not understand Your talking about the little silver tip that looks like it has a flat head slot inside it inside the white part on tip of the plug correct? SO you look at the burn on it and see how far it goes down to gauge your readings?
In the past I have never read it I always read the tips so ive learned something today as well.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2826 of 5051 Old June 21st, 2015, 10:29 PM
Rent Asunder!
RDY4WAR's Avatar
No. I'm referring to the base ring of the plug for AFR and the barb (strap, ground electrode, etc.. whatever you want to call it) for the timing. You're referring to the center electrode, which can also be used to read timing but harder to see accurately.
If the color on the base ring is white and between 80-100% of the ring, you're good to go. If the white is spreading down past the first thread, you're too hot. You can either keep the same AFR and put in a colder plug or can richen the tune up to make us of the hotter plug. Either method will work but only one will make more power. If the white is only showing on about half or less of the base ring, then you're too cold. You either need to lean it out or put in a hotter plug.
2006 Altima daily
RDY4WAR is offline
post #2827 of 5051 Old June 21st, 2015, 10:59 PM
y2k02's Avatar
Wallace Racing - Spark Plug Reading
2002 GT Teksid TFS Heads Edelbrock Intake Twin PTE 6466 turbos TH400/UCC Converter Holley Dominator EFI
2018 Challenger Scat
Eddie Edwards on facebook
y2k02 is offline
post #2828 of 5051 Old June 22nd, 2015, 08:46 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
So i am starting to fabricate some kind of strut brace tower for the GT, Its proving to be difficult because the intercooler pipin is making me push everything forward. Has anyone ran across and custom stru brace towers done on a setup like mine?
the reason I want a brace is to stiffen it up just a little bit more in the corners, the shock spring combination i chose heled alot but i feel like i need a little more.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2829 of 5051 Old June 22nd, 2015, 11:05 AM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
You don't have a front sway anymore do you?
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #2830 of 5051 Old June 22nd, 2015, 11:38 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Nope its gone
So onto something strange, I have the SCT X-3 tuner that's supposed to hold 3 tunes right? now so far I have 5 tunes stored and there is still plenty of room. I wonder if SCT downloaded the X4 software in it when they updated it.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2831 of 5051 Old June 22nd, 2015, 12:06 PM
MM sells a STB for the 03-04 Cobras with a Whipple charger that has an elevated crossbar. I bought one for my car to clear my JLT CAI. I'm going to have to redrill the brace to line up with my factory holes but take a look at it and see if that might work for you.
Edit: It probably won't work unless you have a cowl hood.
Billet 323 2V big bore/stroker
T76 CG Fab Turbo build in progress
McCLOUD is offline
post #2832 of 5051 Old June 22nd, 2015, 12:13 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
thanks Mccloud ill take a look at that, Actually it gives me some new design ideals since I do not have to attach it to the Camber bolts.
I found out from Brooks that the new firmware for the X3 supports up to about 10 files so anyone who has an X3 and wants to hold more then 3 files look into updating your firmware on your SCT hand held.
I also got a file revision to datalog tonight so once I get off ill be running some logs again. as close as this E-85 tune is we should be going WOT in a couple days at most.
Chris Dickerson likes this.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2833 of 5051 Old June 22nd, 2015, 12:19 PM
PRODUCTIONMAN's Avatar
my SCT X-3 that I bought last year holds ten tunes and 5 lock/unlocks
PRODUCTIONMAN is offline
post #2834 of 5051 Old June 22nd, 2015, 03:34 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Decided to make me a custom shift extension so i could sit back further and reach the shifter without having to lean forward when the seat is all the way back where i have to ride to et the leg room i need..
when I get it installed in the car ill put up a picture of it actually mounted.
started with this
A little heating and shaping
A buddy of mine doing a little gringind and sanding
Tapping out some holes for the lock
Here is the finished product, it will thread onto my Existing B&M shifter and give me a little rise and a couple inches back.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2835 of 5051 Old June 22nd, 2015, 05:04 PM
BYAHHHH!
iTrader: 5 reviews
What shifter are you using? Why not relocate it with a MidSouth relocation kit? Looks like nice work though!
Powered by Ford
post #2836 of 5051 Old June 22nd, 2015, 05:23 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
I still have ti finish screwing it all the way down to cover up that exposed threaded area but this gives you an ideal.
DAMN this is super comfortable now, im getting ready for some data logging..
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #2837 of 5051 Old June 23rd, 2015, 01:36 AM
Have you ever considered doing anything like this?
ONE OF THE SICKEST MODS FOR YOUR MUSTANG!!! SPECIAL SN95 MEMBER PRICING
Grant Holland is the owner of Mid South Hydrographics and he makes and sells all of these kits in whatever color or graphics you want. Ive purchased some stuff off of him and he does great work and is awesome to work with. Search him on Facebook - Grant Holland or Mid South Hydrographics.
1999 GT 630rwhp on pump, TFS Heads, MMR 4.75L, Highly Modified Kenne Bell 2.1 @ 20lbs, Custom Intercooler, JLT High Boost CAI, CMS Custom TFS Specific Cams, 3.55s, MGW, T56
Nitmare67 is offline
post #2838 of 5051 Old June 23rd, 2015, 07:06 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
That's nice I wonder how much modification is needed to the hardware to move it back?
That crazy looking thing I made sure is comfortable my son named it the flamingo cause it looks like one Lol.
SSG Pate is offline
post #2839 of 5051 Old June 23rd, 2015, 10:27 AM
Torchin tires...
mellis's Avatar
Hahaha thats great. Kids are awesome!
2004 Torch Red GT
Motor build + turbo swap in progress...
mellis is offline
post #2840 of 5051 Old June 23rd, 2015, 03:09 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Going in to some wot pulls to ight on E85 if the storms can wait till I get finished. Going to start out at 17 PSI tonight then work my way up to 25-27PSI.
SSG Pate is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/336618-turbo-build-has-begun.html
My "re" build thread - Trick flow/turbo build - Page 3 - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback July 9th, 2016 07:34 PM
Thread The Turbo build has begun | Forums at Modded Mustangs | BoardReader This thread Refback December 1st, 2015 12:31 AM
kurgan motorsports | BoardReader This thread Refback February 3rd, 2015 07:14 PM
The Turbo build has begun - Page 66 This thread Refback December 2nd, 2014 11:02 PM
UPR cracked | BoardReader This thread Refback March 27th, 2014 05:50 PM
UPR customer service | BoardReader This thread Refback March 27th, 2014 05:01 PM
