The Turbo Build Has Begun - Page 17 - Forums at Modded Mustangs
 117Likes
post #321 of 5059 Old February 27th, 2014, 03:18 AM
The UPR K member looks nice.... but ive seen 3 of them either cracked or broken that were never in an accident. They do not hold up at all to daily driving... I had one sitting in my garage awhile back that was brand new and I kept looking at it thinking it looks nice enough to me, maybe I could beef it up a bit... Then I started doing weld thickness checks and found them to be VERY inconsistent in a couple places damn right paper thin where the plates are welded and meet the tubes at a 45. In comparison I did the same thing once to an MM K member and and found them all to be very close.
Put it like this if your roll cage was welded in your race car with the same quality as that UPR K member I had it would not pass tech when they did the weld inspection... kinda scary huh.
Either way though I hope your ride turns out awesome, your happy and its fast. I know one thing for sure it will be pretty!
1999 GT 630rwhp on pump, TFS Heads, MMR 4.75L, Highly Modified Kenne Bell 2.1 @ 20lbs, Custom Intercooler, JLT High Boost CAI, CMS Custom TFS Specific Cams, 3.55s, MGW, T56
Nitmare67 is offline
post #322 of 5059 Old February 27th, 2014, 06:47 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Thanks for that info, Were those Chrome molley pieces that cracked? It felt tlike a good solid piece when I was installing and inspecting it, and i never read anything like this until now so I thought they were top notch especially the chrome Molly.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #323 of 5059 Old March 2nd, 2014, 01:56 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Boys I need some info, im working on the K member, who has kept the Sway bar because I really would like to keep it for handling?
Also I have poly bump steer bushing should I use those or just go buy some stock one because I bought a bump steer kit?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #324 of 5059 Old March 2nd, 2014, 02:13 PM
BOSSMAN2888's Avatar
Sarge, I am running the factory sway bar through utilizing the MM swar bar relocation bracket here:
Front Swaybar Relocation Kit, 1994-04
By bumpsteer bushing are you referring to the Rack bushings? If so I used the MM solid bushings that are eccentric and allow 4 mounting positions depending on clearance with the oil pan, it also eliminates the slop from the factory rack bushings.
Steering Rack Bushings, Solid, 1979-04 Mustang with MM K-member
BOSSMAN2888 is offline
post #325 of 5059 Old March 2nd, 2014, 02:18 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
I was referring to the power steering rack bushing, Right now I have the offset ones, but I wasn't sure if I should use those since I bough the bumpsteer kit that replaces the factory tie rod ends.
AS far as the sway bar it looks like it will line up just fine with the K member.
This is the bumpsteer kit I have
http://www.uprproducts.com/mustang-e...er-kit-79.html
these are the bushings I have, and wasn't sure If I should go back to the standard ones since I have the Bumps steer kit.
http://www.uprproducts.com/mustang-o...-bushings.html
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #326 of 5059 Old March 2nd, 2014, 02:30 PM
I had poly prior to the solid mounts. I would use the poly over the rubber, and on the offset if your rack is low, as in the tie rods are going upward to meet the a-arm you should be able to turn the offset bushing upside down to reduce the upward angle and not run as many washers on the Tie-rod bumpsteer kit.
post #327 of 5059 Old March 2nd, 2014, 02:40 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
What I'm asking is who has used the offset with the bumpster or should I useful standard rack bushings.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #328 of 5059 Old March 2nd, 2014, 03:43 PM
y2k02's Avatar
I've been running the offsets and bumpsteer kit since 05.
2002 GT Teksid TFS Heads Edelbrock Intake Twin PTE 6466 turbos TH400/UCC Converter Holley Dominator EFI
2018 Challenger Scat
Eddie Edwards on facebook
y2k02 is offline
post #329 of 5059 Old March 2nd, 2014, 05:24 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
I too am running offset rack bushings and bumpsteer. Works well. I am going to lower it more this year so we shall me.
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #330 of 5059 Old March 2nd, 2014, 08:16 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
I put On the sway bar and it fit good didn't require any kind of modification, I ran out of time on it today because I had to work on my other mustang for a little while. Maybe tomorrow I'll get the steering rack and everything hooked up..
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #331 of 5059 Old March 4th, 2014, 07:09 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Still waiting on a few parts for my suspension so in the meantime!! The Short block is pretty much complete, only thing I need is Billett gears for the oil pump.
All my pistons are scuffed up and deburred, to ensure I didn't have any sharp edges which will be an attraction point for detonation.
Got the deck resurfaced, block honed out, and all that good stuff, The machine shop said the assembly was way out of balance but she is dialed in now. The guy that did the balancing Won an award at the Amsoil engine build off so Im certain my motor should be about perfect for high revolutions.
I also left my Main bearing clearances towards the loose side .0027 to .0028 to allow a little more oil to flow in between them in the upper RPM's. My only concern was losing oil pressure, but since I have the Cobra pickup tube and housing flow shouldn't be an issue.
---------- Post added at 07:07 PM ---------- Previous post was at 06:26 PM ----------
I called and talked to them about this and yes they had a couple issues with their old stuff, but there is no issues with their new K members.......
---------- Post added at 07:09 PM ---------- Previous post was at 07:07 PM ----------
I went ahead and ordered all new POLY stock style bushings since I have all the right hardware on my K member to correct this.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #332 of 5059 Old March 5th, 2014, 01:16 AM
aarongt2000's Avatar
SSG, what kind of transmission are you running? Im thinking of going auto some day, maybe a turbo or blower.. what options are there?
aarongt2000 is offline
post #333 of 5059 Old March 5th, 2014, 06:51 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Im running a Built 4R70W with a Full manual Valve Body with a PA Flex plate!! Once the turbos go on ill be sending it to Fred Brown performance for a couple upgrades I have been wanting such as Trans Brake and a lockup converter, and a thorough inspection before I throw the power to it.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #334 of 5059 Old March 5th, 2014, 10:46 AM
Is that a ford transmission?
post #335 of 5059 Old March 5th, 2014, 10:57 AM
a.k.a. Racecougar
Tang Stang's Avatar
The 4R70W is the factory offered automatic for these cars, save the '04 which received the 4R75W.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #336 of 5059 Old March 5th, 2014, 11:19 AM
so that trans will take some abuse in stock form huh?
post #337 of 5059 Old March 5th, 2014, 11:33 AM
a.k.a. Racecougar
Tang Stang's Avatar
A fair amount. However, as Pate said above, he's running a built up 4R70W, not a bone-stock one.
<----I run a built 4R70W in this car, as well. It's a good Ford OD transmission with decent aftermarket support.
post #338 of 5059 Old March 5th, 2014, 11:09 PM
How much work/ money/ parts does it take to handle 500-600 hp?? aftermarket converters are a large part of the cost right?
post #339 of 5059 Old March 6th, 2014, 08:14 AM
a.k.a. Racecougar
Tang Stang's Avatar
You'll have to get your own quotes there. As far as work and parts are concerned, the complete J-Mod article (not just the valvebody modifications) is a great resource. Yes, a good converter can easily retail north of $700.
TCCoA Transmission Article - Page 1
post #340 of 5059 Old March 6th, 2014, 09:52 AM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Worked on istalling the power steering rack last night, I ordered up some new standard polly bushings and they arrived, but i ran into an issue with the rack bolts. Seems the PS rack bolts are to long and wont allow you to tighten up the rack before running out of thread. so After a couple emails to some friends it was determined that the PS bolts need ot be replaced.
I called UPR and ordered a set of Grade 8 Power steering rack bolts so Ill be putting things on hold till I get these in. By the way UPR has some awesome customer service!!!
So those of you looking to install a k member remember that youll need new shorted Power steering rack bolts.
---------- Post added at 09:52 AM ---------- Previous post was at 09:48 AM ----------
Another note, I was talking to an engine builder and was mentioning brass Valve guides upgrades for my heads. HE was telling me NOT to use those for a street car because they would wear out and burn up in about 20K miles or so. They are great for the track, but not that great for the street because brass is a material that wears easily as we all know anyhow. So ill be shying away from the whole brass thing now.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/336618-turbo-build-has-begun.html
My "re" build thread - Trick flow/turbo build - Page 3 - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback July 9th, 2016 07:34 PM
Thread The Turbo build has begun | Forums at Modded Mustangs | BoardReader This thread Refback December 1st, 2015 12:31 AM
kurgan motorsports | BoardReader This thread Refback February 3rd, 2015 07:14 PM
The Turbo build has begun - Page 66 This thread Refback December 2nd, 2014 11:02 PM
UPR cracked | BoardReader This thread Refback March 27th, 2014 05:50 PM
UPR customer service | BoardReader This thread Refback March 27th, 2014 05:01 PM
