The Turbo Build Has Begun - Page 221 - Forums at Modded Mustangs
 117Likes
post #4401 of 5059 Old July 24th, 2016, 02:50 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Don't let this mess persuade you all either way, Ive spent a lot of money on parts that certain vendors said would work but came up short in the long run.
My Advice if you want a turbo buy an on3 and don't waste your money on this other shit. How the Fuck does a 2K turbo only made 700hp on a motor setup for 1000RWHP?
So my question is where do I go from here? ive not reached my goal with this car HP wise but have track wise. Could my converter be messed up causing this Chaos?
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4402 of 5059 Old July 24th, 2016, 03:51 PM
y2k02's Avatar
Need to take the car to the track and see how it runs.
What does your car weigh?
2002 GT Teksid TFS Heads Edelbrock Intake Twin PTE 6466 turbos TH400/UCC Converter Holley Dominator EFI
2018 Challenger Scat
Eddie Edwards on facebook
y2k02 is offline
post #4403 of 5059 Old July 24th, 2016, 05:39 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
3650 with me at 216
---------- Post added at 05:39 PM ---------- Previous post was at 04:02 PM ----------
Been sitting here thinking about selling my Trans and going manual. I think I'm going to sell the whole setup including MVB, New Converter all the switches for lockup, OD and even my shifter.
With that being said I am assuming il be looking for a T56? who sells a manual trans that will hold down some power?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4404 of 5059 Old July 24th, 2016, 05:51 PM
GBPackerFan's Avatar
That sucks Pate. I have no input. I hate dynos...I go by trap speed now.
Good luck. I hope you figure it out.
Matthew 26:52-54 / Go Pack Go!
2001 GT Convertible - D1SC / Cammed / Geared / 440wh 400wt
1994 V6 Convetible - Stock
2009 Malibu LTZ - Stock
GBPackerFan is offline
post #4405 of 5059 Old July 24th, 2016, 06:13 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Ill try trap speed then this time to see if it improved, I got one more chance on AUG 2nd to use the track and after that it shits down to folks like me.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4406 of 5059 Old July 24th, 2016, 07:47 PM
wicked96gt's Avatar
Originally Posted by SSG Pate View Post
3650 with me at 216
I'd give it one more shot at the track and see how it runs. If I wasn't deploying in a few months is be all over your auto setup! I wanna take my t56 out at some point.
2001 Mustang GT Bullitt #05239, Built and turbo 2v!
17psi 665rwhp 678rwtq
23psi 804rwhp 782rwtq
Carolina Crew #3
2012 Wrangler stock for now. The DD
wicked96gt is offline
post #4407 of 5059 Old July 24th, 2016, 08:10 PM
y2k02's Avatar
This is a good calculator. It shows flywheel horse power.
ET-MPH-HP Calculator
y2k02 is offline
post #4408 of 5059 Old July 24th, 2016, 08:28 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Ide probably trade you my entire setup for yours Ive got an absurd amount of money in the trans converter setup.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4409 of 5059 Old July 24th, 2016, 08:31 PM
wicked96gt's Avatar
That is so tempting man. I know how quickly a built auto setup can run. I was looking into it before my oil pump went out.
Carolina Crew #3
post #4410 of 5059 Old July 24th, 2016, 08:37 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
That's pretty good Its shows my 121 trap speed at 498hp and I know it was making 523 at the dyno on a good day so with the heat soak ide say it was around 500hp.
On my 134 its saying 676 which I couldn't tell you how much I make on 16PSI but that's what I pulled it off with.
This dyno is OLD it doesn't even log AFR so I probally shouldn't take it with a grain of salt.
---------- Post added at 08:37 PM ---------- Previous post was at 08:35 PM ----------
Well I'm not really a track person I go once in a while but mainly like to street drive. mine is a FMVB with OD and Lockup. got a 1 piece billet shaft and built to handle the power.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4411 of 5059 Old July 24th, 2016, 08:43 PM
wicked96gt's Avatar
That's pretty much the setup I want haha my car is for racing street and will eventually get around to making it to the track every few weeks after deployment. I've got my built t56, McLeod RST with only 500 miles on it, aluminum driveshaft, and mgw shifter.
Carolina Crew #3
post #4412 of 5059 Old July 24th, 2016, 08:47 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
That sucks your deploying again I know your pain make sure you PM me your APO and ill send you some packets.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4413 of 5059 Old July 24th, 2016, 08:58 PM
wicked96gt's Avatar
This one should be pretty cool. It'll be a deployment with some prett sweet perdiem. And it's only 6 months so it won't be to bad. But will do man. Thanks. And if you decide for sure you want to go the t56 route let me know. I may just keep the car down a little while longer for the right swap.
Carolina Crew #3
post #4414 of 5059 Old July 24th, 2016, 09:03 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
PM sent!!
wicked96gt likes this.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4415 of 5059 Old August 15th, 2016, 09:17 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
It has been an exceptionally hot summer this year up in the 90's with over80 precent humidity which is hard on a car. This heat exposed a weak spot in my fuel system where my fuel was getting ridiculously hot after a good drive.
So to fix this i went from the traditional return to a dead head style fuel setup. Ill be trying this out this week after the 410 gear swap ill be doing Wednesday night. Also during this process I found that my Waste gate wiring harness was burned in two so apparently my BC hasn't been working. Im sure this has had to impact the way my car came into boost.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4416 of 5059 Old August 15th, 2016, 09:44 PM
y2k02's Avatar
y2k02 is offline
post #4417 of 5059 Old August 15th, 2016, 09:51 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
4.10
i just went up 2" in tire my calculations say i need a 410 coming through the 1/4 at 5950 isnt cutting it
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4418 of 5059 Old August 15th, 2016, 10:19 PM
Powered by LSx tears
69fastback's Avatar
Well, you're going to have to do something to get those times down hehe
I'll toss that dude's salad
69fastback is offline
post #4419 of 5059 Old August 15th, 2016, 10:21 PM Thread Starter
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
LOL Touche Ive still got an ass whopping coming right?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #4420 of 5059 Old August 16th, 2016, 09:43 AM
69fastback's Avatar
Someday! Yours is coming along a lot faster than mine. I still have a bare block sitting in the corner of the garage.
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/336618-turbo-build-has-begun.html
My "re" build thread - Trick flow/turbo build - Page 3 - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback July 9th, 2016 07:34 PM
Thread The Turbo build has begun | Forums at Modded Mustangs | BoardReader This thread Refback December 1st, 2015 12:31 AM
kurgan motorsports | BoardReader This thread Refback February 3rd, 2015 07:14 PM
The Turbo build has begun - Page 66 This thread Refback December 2nd, 2014 11:02 PM
UPR cracked | BoardReader This thread Refback March 27th, 2014 05:50 PM
UPR customer service | BoardReader This thread Refback March 27th, 2014 05:01 PM
