Hose question. Reps given for a fix. - Forums at Modded Mustangs
post #1 of 23 Old January 10th, 2014, 11:18 AM Thread Starter
Hardcore Devotee
cl0udedth0ught's Avatar
iTrader: 5 reviews
Does anyone know where you can get the hose that goes from the pcv valve on the valve cover to the port on the plenum? There is a plastic tube in between the pcv and the plenum that leads into the hose that I need. (The hose is a different inside diameter on each end and a few inches long.)
Backstory: When I changed to an accufab throttle body and plenum, the stock hose was all dry rotted and broke when I tried to remove it. I tried getting one from the help aisle at the parts store help aisle but the only one that they had that would work isn't rigid enough and collapses when the car is running and after a few months of being fine, it started making this horrible loud vacuum noise at idle. The guy at the desk didn't know anything of course and said that they didn't have anything else that would work. Tried another parts store, and same problem. Tried looking online but didn't find anything there either....
The accufab plenum that I bought used seems to have a bigger port them my factory one did as well which also complicates the problem further bc I don't know if a new factory one would work either? Has anyone else ran into this?
Here's a pic for reference: I circled the hose in red. Not my car but you get the idea.
2000 GT - Full Bolt-on's
cl0udedth0ught is offline
post #2 of 23 Old January 10th, 2014, 11:20 AM
nothin.but.a.stang's Avatar
what Accufab are you running? I have the 70mm and my factory hose works without issues
l 2000 GT l CMS Stage 2 N/A Cams / CMS valve springs / K&N CAI / 70mm Accufab TB / BBK LT Headers / BBK H-pipe / Borla Stinger Catback / Exedy Mach 400 Clutch / Exedy Flywheel / Steeda Tri-Ax / Steeda UD Pulleys l
nothin.but.a.stang is offline
post #3 of 23 Old January 10th, 2014, 11:24 AM
xandraxal's Avatar
If you go to any decent hose/rubber repair they should have what you need. I have a Goodyear place local, that's where I get a lot of hose and fittings. But you should be able to get good vacuum hose from any parts store. Try NAPA
96 GT turbocharged - SOLD
97 Cobra vert stock -SOLD
xandraxal is offline
post #4 of 23 Old January 10th, 2014, 11:25 AM
condor123's Avatar
it should be 5/8ths,
condor123 is offline
post #5 of 23 Old January 10th, 2014, 11:34 AM
i dont believe its two different sizes on the ends (may appear this way from long-term use)...the ports may be but the the line should be able to be stretched onto the bigger port without any issues
post #6 of 23 Old January 10th, 2014, 12:02 PM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
The port is definately bigger. Its the accufab 75mm. I guess I'll check a napa this weekend and report back. Thanks guys.
post #7 of 23 Old January 10th, 2014, 01:02 PM
yea thats what i meant was the port might be, but i wouldnt think the hose would be different sizes on either end.
post #8 of 23 Old January 10th, 2014, 01:46 PM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
what i meant is the accufab port is bigger than the factory plenum port by a fair amount.
post #9 of 23 Old January 10th, 2014, 02:10 PM
Still slow.
1996 GT's Avatar
Even home depot, just get the re enforced tubing.
1996 GT is offline
post #10 of 23 Old January 10th, 2014, 04:21 PM
Crimson's Avatar
If I'm understanding you correctly I think I had the same issue. I just cut a small section of bigger diameter hose and put that over the plenum port and existing hose and band clamped both ends.
I believe that the stock hosing on the earlier model new edges is smaller than the later models. On my 2000 gt I had the issue I just explained my solution to but on my 2004 gt I did not need the larger diameter hose, the stock hose fit on the plenum port.
Crimson is offline
post #11 of 23 Old January 10th, 2014, 04:43 PM
ndfrspd's Avatar
OEM from Ford dealership, they may upcharge for it but i doubt home depot or an auto store would have a hose with different I.D.'s.... thats not the PCV valve. pcv valve is coming off the driver side valve cover... idk what you meant by that.
ndfrspd is offline
post #12 of 23 Old January 10th, 2014, 04:49 PM
Technically he is right it is refered as PVC valve
Don't go to a dealer they want $40 just for the elbow Use an elbow strong enough for now and order this
Mustang PCV Valve To Upper Intake Hose (01-04) GT 4.6 2V - LatemodelRestoration.com
Mine should be here tomorrow
Red_04stang is offline
post #13 of 23 Old January 10th, 2014, 05:22 PM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
Thanks man. That looks like what I need.
---------- Post added at 05:22 PM ---------- Previous post was at 05:20 PM ----------
Originally Posted by ndfrspd View Post
.thats not the PCV valve. pcv valve is coming off the driver side valve cover... idk what you meant by that.
Mustang PCV Valve & Tube Set (96-01) 4.6 2V - LatemodelRestoration.com
This is similar to what goes into my passenger side valve cover. (I actually already tried this kit but the hose is not even close to expanding enough to go on the plenum.) Is that not a pcv valve on the end though?
post #14 of 23 Old January 10th, 2014, 07:41 PM
No that is for a 99-01 what you need is the one I posted that is the one that goes from the plenum to the pass side valve cover
And don't use radiator hose or any soft hose they fail in 10 min because of the heat
And I wouldn't suggest breathers eather but that's another route you can go
post #15 of 23 Old January 10th, 2014, 07:55 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Ive got that hard plastic hose your talking about somewhere in my garage, and Ill sell it to you. I no longer need it because I am using a catch can.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #16 of 23 Old January 10th, 2014, 07:56 PM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
If you find it, I'll be glad to take it off your hands. Let me know man. You can just PM the details if you want.
post #17 of 23 Old January 10th, 2014, 08:09 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
I have both plastic hoses which one do you want?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #18 of 23 Old January 12th, 2014, 12:45 PM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
I actually already have the plastic piece. I need a short rubber angled piece that goes from that plastic piece and connects to the plenum. The original one was dry rotted on my car and fell apart. I ordered this kit from late model restoration and the hose diameter was way to small. I think I need one for 01-04 mustangs since this plenum outlet is much bigger than the original plenum and I heard they are different from 96-00 vs 01-04. May try this one that someone posted earlier. I hate to waste another 30 bucks on something that may not work though. http://www.latemodelrestoration.com/...er-Intake-Hose
post #19 of 23 Old January 12th, 2014, 02:09 PM
I got mine and installed yesterday they are actually kind of a hard plastic unlike a rubbery hose like elbow that came with the car it's motorcraft so it's good quality I don't think you would be disappointed and I'll take a pic when I get home and show you if you like
post #20 of 23 Old January 13th, 2014, 07:18 AM Thread Starter
Hardcore Devotee
iTrader: 5 reviews
That would be really helpful man. I would appreciate it.
