Tune Numbers finally!! - Forums at Modded Mustangs
post #1 of 42 Old July 8th, 2014, 02:22 PM Thread Starter
Wiser by the Minute
aluv4speed's Avatar
All:
I have been gone and very busy with work and this build. I haven't posted any updates. I'll shoot some pics later on per request. I can give you all any info you would like too.
1996 GT - Built bottom end - stock heads/cam - 5 angle valve job and stage 3 boost valve springs. Full fuel system - E85 - 78/68 turbonetics turbo - on3 FF turbo kit - on3 wastegate & bov. MMR oil pan, windage tray, & frpp high volume oil pump.
16 psi - 628/654 ( we made 667 on 18psi but backed it off )
Kurgan tuned -
Michael
** Car will be FOR SALE or TRADE sooner than later. On to the next project.
" Drive Fast - Take Risks "
On3 2nd gen kit, 78/68 Benita, E85, - 628/654 16psi | 677/695 18psi {Just swapped in the Edelbrock, 6061 plenum, 75mm tb, & 4" intercooler} Need new tune.
aluv4speed is offline
post #2 of 42 Old July 8th, 2014, 02:41 PM
Very nice!!
87 GT, R302 block 347, S480 turbo, E85 blow thru carb.
Deths2002GT is offline
post #3 of 42 Old July 8th, 2014, 03:03 PM
Osiris's Avatar
Congrats, man! Those damn turbos...
Osiris is offline
post #4 of 42 Old July 8th, 2014, 03:16 PM
Oiljunkie's Avatar
damn on stock heads and cams with only a valve job!
00 GT, 4v and Heaton Swap, T56 Mag Build thread: https://www.moddedmustangs.com/forums...aton-swap.html
Oiljunkie is offline
post #5 of 42 Old July 8th, 2014, 05:22 PM
SleeperStang
Jgib4's Avatar
iTrader: 6 reviews
Npi heads and cam? Which intake?
Laser Red Crew #6
276/296 on a pi swap and OPS1 cams
Mods in Garage
Jgib4 is offline
post #6 of 42 Old July 8th, 2014, 05:27 PM
Lexus FTW
02GTAUTO's Avatar
: fuel setup?
02GTAUTO is offline
post #7 of 42 Old July 8th, 2014, 06:33 PM
Rent Asunder!
RDY4WAR's Avatar
Turbo FTW! Great numbers!
The stock heads and cams are great for a street driven turbo car.
1993 Camaro bracket car
2002 Tahoe family/tow rig
2006 Altima daily
RDY4WAR is offline
post #8 of 42 Old July 8th, 2014, 08:41 PM
MM's V6 Hater
iTrader: 31 reviews
Nice numbers.
2013 GT
2016 F150
Cabikejumper is offline
post #9 of 42 Old July 8th, 2014, 09:29 PM
The Little 2v That Could
srt10ram's Avatar
Awesome numbers, was NOT expecting nearly that much from stock cams, I bet that Valve Job freed up about 15-25cfm.
Have any opinions or recommendations on the ON3 FF kit? I plan on buying their hotside and doing a 7675 precision or turbonetics turbo. Also what's the downpipe/exhaust setup?
Toy - 01' Bullitt #3320: Borg Warner S475/83 - Built 4r70w
DD - 09' Kawasaki ZX6r
srt10ram is offline
post #10 of 42 Old July 9th, 2014, 03:23 AM
-- Logan --
DGS2vGT's Avatar
thats crazy good for stock heads and cam!!
DGS2vGT is offline
post #11 of 42 Old July 9th, 2014, 06:25 AM
Garage Built
YOUNG-GUN's Avatar
Nice numbers!! Whats the spool like with that turbo? When do you hit max boost?
Instagram: CSRGONZA
Build thread
YOUNG-GUN is offline
post #12 of 42 Old July 9th, 2014, 07:43 AM
hi you can call me mater
03 cristian's Avatar
iTrader: 5 reviews
Damn nice numbers!
Can you take some detail pics of the set up under the hood please
"I wonder if I sprayed some on my junk, I could go raw dog and not get herpes. But first I'd have to find a female willing to have relations."-kmac1622
03 cristian is offline
post #13 of 42 Old July 9th, 2014, 09:37 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Its amazing how well our cars respond to boost, are you happy with the results? do you plan on going any further?
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #14 of 42 Old July 9th, 2014, 12:25 PM Thread Starter
Wiser by the Minute
aluv4speed's Avatar
PI heads & cam - from 2001 I believe. Stock Plastic PI intake with alum crossover. aftermarket pleanum and TB. I believe it's only a 70mm
---------- Post added at 09:15 AM ---------- Previous post was at 09:02 AM ----------
Originally Posted by 02GTAUTO View Post
: fuel setup?
I built fuel system from scratch myself
Stock 96 gt tank
UPR fuel pickup
-10an PTFE feed line
-6an PTFE return line
12-1400 holley external pump
UPR fuel rails
aremotive reg -10 & -6
80lb injectors
E85 fuel
---------- Post added at 09:19 AM ---------- Previous post was at 09:15 AM ----------
The kit isn't bad at all overall. Worth the money for sure. Hot side fit nice overall. Downpipe to 1st exhaust pipe that runs over the a-arm is a little off so may need a bit of fab work but not much.
* The oil relocation kit is kind of a PITA - I had new lines made. Make sure before you put the header on that you have the relocation kit tightened all the way and the fittings are in the correct direction and you have your hoses on. We had a hell of a time with it.
Downpipe is the stock ff on3 3" one. and goes into magnaflow cat back No cats.
Exhaust seperated at the lap band where downpipe and 1st exhaust starts so I am running open downpipe until I can get a little piece made to extend the pipe. Not a big deal.
One thing I will say though is that with my 78/68 .96AR ex side turbo, it is pretty laggy but hits very hard. I would consider this when getting your turbonetics.
---------- Post added at 09:23 AM ---------- Previous post was at 09:19 AM ----------
Thanks SSG... I am very happy. I was like WOW when I saw 667 rwhp on 18psi and we backed off. Not sure why but I accepted it. I wanted to crack 600 so I am happy.
I would like the boost to come on sooner though allthough I do have a 3:73 gear and will probablly go down to 3:55. Once in boost in 1st, shifting into second it really dosn't lag and stays in boost so in a race the car stays in boost so not bad.
I had a twin screw before this and used to the instant boost. Guess I was just spoiled but the turbo pulls much harder when in boost.
I mean with the Kenne Bell I made 489 at 15psi and now I am at 628 on just a tad over 16psi.
LET ME GET SOME pics for yall. hold up
---------- Post added at 09:25 AM ---------- Previous post was at 09:23 AM ----------
REPS TO EVERYONE, Thanks!
post #15 of 42 Old July 9th, 2014, 12:52 PM
CalBoy101's Avatar
Very impressive.
I love these engines, its insane that you can make that kind of power with stock heads and cams.
Any chance you could post the dyno curve?
2002 GT/Auto/Vert
2.1 KB 12psi/2600 MAF/75mm Accufab TB
BE Tuner/PopsRacing
Silverfox VB/Circle D 3400 CV/Steeda LCA's+Subs
Control Boost from ControlBoost.com
CalBoy101 is offline
post #16 of 42 Old July 9th, 2014, 03:41 PM Thread Starter
Wiser by the Minute
aluv4speed's Avatar
---------- Post added at 12:39 PM ---------- Previous post was at 12:39 PM ----------
---------- Post added at 12:40 PM ---------- Previous post was at 12:39 PM ----------
---------- Post added at 12:41 PM ---------- Previous post was at 12:40 PM ----------
post #17 of 42 Old July 9th, 2014, 04:28 PM
CalBoy101's Avatar
Wow, if I'm reading that curve correctly the HP peak is at 5100 RPM or so.
That means improved heads, cams and higher revs would probably be knocking the door on 800 rwhp.
You are definitely giving me a bad case of E85/Turbo Envy.
2002 GT/Auto/Vert
BE Tuner/PopsRacing
post #18 of 42 Old July 9th, 2014, 05:00 PM Thread Starter
Wiser by the Minute
aluv4speed's Avatar
Probably screeming for more CFM - We had it at 18psi and it made 667 rwhp but we turned it down.
post #19 of 42 Old July 9th, 2014, 05:16 PM
srt10ram's Avatar
Looks good man, now all we need are some videos of it. I bet that thing would pick up alot of RPM and probably 60whp+ with turbo cams.
srt10ram is offline
post #20 of 42 Old July 9th, 2014, 07:15 PM
02gt2v's Avatar
I don't have numhers on mine because of dyno issues but my power curve feels like what yours looks like (not talking actual hp numbers) I have a turbonetics 76/68 . 96 ar so essentially the same turbo as you. I also have stock cams. I feel that the fix would either be stick with stock cams and switch to a .68 ar or possibly an .81 housing and have a nasty power band at the cost of a few top end hp ( which the stock cams are robbing anyways) or leave the turbo alone and swap to turbo cams
Go turbo, don't look back.
02gt2v is offline
