How to change rear main seal? - Forums at Modded Mustangs
post #1 of 21 Old January 17th, 2015, 12:46 AM Thread Starter
condor123's Avatar
So i dropping my trans to change the clutch and i figure i should change the rear main seal and i honestly dont know how . is this the best seal to get? Mustang Rear Main Seal (96-10) 4.6
Is their a special way that I am supposed to take out the old seal and install the new?
condor123 is offline
post #2 of 21 Old January 17th, 2015, 01:07 AM
Still slow.
1996 GT's Avatar
Pull the old one out with a seal puller or something that has a small hook to make life easy. Tap the new seal in with a piece of flat wood and a hammer so it will go in evenly. Pretty straight forward.
1996 GT is offline
post #3 of 21 Old January 17th, 2015, 01:21 AM
stal94gt's Avatar
It is easier to remove the rear main seal housing. It is held in by 8mm bolts in the block and the rear oil pan bolts along with rtv
bone stock from the factory!
stal94gt is offline
post #4 of 21 Old January 17th, 2015, 08:11 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
+1 remove the rear main seal housing if you want to do it right, I don't like trying to beat a seal into the housing over the back of the crank. Make sure you lubricate the inside of the new seal with oil or silicone to help it slide on the crank and get a perfect seal.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #5 of 21 Old January 17th, 2015, 09:58 AM
I agree, I changed mine like this last night and it was a breeze. Make sure you oil the new seal and it will slide back on the crankshaft very easily.
2002 GT - 5 Speed
Novi 1000 @ 9 psi
Mods in My Garage
Silver GT is offline
post #6 of 21 Old January 17th, 2015, 01:18 PM Thread Starter
condor123's Avatar
Thanks for all the help everyone!!!
post #7 of 21 Old January 17th, 2015, 01:32 PM
CalBoy101's Avatar
Condor, you need to put a 1/8" bead of something like Ultra Black RTV on the seal plate surfaces when you install it, make a circle around each bolt hole.
Also put some in the surface between the plate bottom and the oil pan.
Get those surfaces and the crank surface where the seal rides fully cleaned off also and put a light coat of grease on the crank surface.
When installing the plate go finger tight on the bolts and leave it like that for 30 minutes to let the RTV setup a little bit, then do the final torque on the plate.
Don't overtorque that plate when installing it, the torque spec is pretty low (7.5 ft-lbs or 90 in-lbs) and if its overtorqued it will warp and leak.
I like to put blue threadlocker on low torque bolts like this so they don't loosen.
2002 GT/Auto/Vert
2.1 KB 12psi/2600 MAF/75mm Accufab TB
BE Tuner/PopsRacing
Silverfox VB/Circle D 3400 CV/Steeda LCA's+Subs
Control Boost from ControlBoost.com
CalBoy101 is offline
post #8 of 21 Old January 18th, 2015, 12:34 PM Thread Starter
condor123's Avatar
This was very helpful!!! thank you i appreciate the input
post #9 of 21 Old January 18th, 2015, 10:04 PM
Silcone inside the seal???lol
Bottledgt is offline
post #10 of 21 Old January 18th, 2015, 10:09 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Yes Clear silicone compound I use it all the time to lubricate the seals when I install them.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #11 of 21 Old January 18th, 2015, 11:15 PM
CalBoy101's Avatar
Just to be clear these guys mean the spray silicon lubricant, not silicone sealer.
I like motor oil better since that's what's going to end up on the seal.
2002 GT/Auto/Vert
BE Tuner/PopsRacing
post #12 of 21 Old January 19th, 2015, 09:05 AM
PRODUCTIONMAN's Avatar
I know it goes against normal thinking, but if you use the FelPro seal BS-40644 (the one that has a hybrid compound, not just rubber), the install instructions that come with the seal say specifically to NOT lubricate the seal or the crankshaft and that it must go in dry. I just did mine and was shocked to see that. I followed the instructions even though my inclination was to oil it. I have to assume they know what they are talking about. If you use the rubber version BS-40620 then that one you would lubricate.
PRODUCTIONMAN is offline
post #13 of 21 Old January 19th, 2015, 05:43 PM
jonwrong's Avatar
Installing the seal into the plate on a bench and then installing as an assembly is a mistake. Ask me how I know. It is difficult to get the seal back on without flipping the lip the wrong way. I had to redo my install after using that method.
I used this tool, and it was worth every penny. I did pay less than the current Amazon price, though. It sets it at the right depth and perfectly straight. No need to remove the plate with it.
Saleen Series II, MHS Stage 1 Heads & Blower Cams, 365whp/385wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, Cobra Brakes.
jonwrong is offline
post #14 of 21 Old January 19th, 2015, 05:54 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Holy Crap that's expensive.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #15 of 21 Old January 19th, 2015, 07:22 PM Thread Starter
condor123's Avatar
Amazon.com: OTC 7786 Rear Main Seal Installer for Ford: Automotive
want to let me borrow it? lol ill pay you
---------- Post added at 06:22 PM ---------- Previous post was at 06:20 PM ----------
i like the idea of not having to remove the plate, just one less thing for me to possibly fuck up lol
post #16 of 21 Old January 19th, 2015, 09:19 PM
CalBoy101's Avatar
The Felpro seal's come with a plastic "speculum" that keeps the seal lip from flipping the wrong way when you're sliding it on the crank.
Once its slipped on you just pull the speculum out.
So you don't need the installation tool with the Felpro seals.
2002 GT/Auto/Vert
BE Tuner/PopsRacing
post #17 of 21 Old January 19th, 2015, 10:20 PM
stal94gt's Avatar
i never used a install tool with the felpro gasket. non the less if you use one of the inverted seals you can risk it flipping installing it with the housing on. my thing is i keep tools away from the crank. any scratches or nicks will cause a leak so installing it on a bench is easy. that install tool does look nice but it is a waste of money
stal94gt is offline
post #18 of 21 Old January 20th, 2015, 09:34 PM
jonwrong's Avatar
Sure.
If you had to remove your passenger side header to drop your tranny, which involves pulling the K-member to pull the header, you would not think it is a waste of money. It was cheap insurance. Getting the seal perfectly lined up and at the right depth is not rocket science, but it does often take one or two tries. Plus, I only paid about $85 as I recall.
jonwrong is offline
post #19 of 21 Old January 20th, 2015, 11:23 PM
Been putting seals in with a punch and a hammer for 15 years. No issues.
post #20 of 21 Old January 20th, 2015, 11:28 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Same here with the exception of more then 20 and I've never used one of those. The only thing I've ever used a seal driver on was those cheap ass CTIS air seals which are so deep in the Hub you pretty much have to.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
