deleting the coolant expansion tank - Page 2 - Forums at Modded Mustangs
post #21 of 33 Old February 28th, 2015, 11:38 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
OP you can delete the bottom hose and put the Cap in the upper hose at this highest point then have the overflow go to a stand alone tank somewhere. I actually still have the parts for this somewhere in my garage if you want them minus the hoses. White03gtanger and myself both went this route then I changed gars when I built my own custom tank.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #22 of 33 Old February 28th, 2015, 12:53 PM
GT o1's Avatar
Pate I'll buy one off you if you decide to make one
GT o1 is offline
post #23 of 33 Old February 28th, 2015, 01:06 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Shoot me a PM well talk about it..
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #24 of 33 Old March 1st, 2015, 10:35 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Kyle you can do it this way, All you do is take the outlet and run it to a stand alone reservoir tank.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #25 of 33 Old March 1st, 2015, 11:14 PM Thread Starter
kyle2002stang!'s Avatar
awsome! thats exactly what i wanted to do.
2002 mustang gt - turbo'd and blown up
1980 mercury zephyr wagon - roller undergoing rust repair
1970 galaxie - 351W cruiser
1978 F150 - 4x4 400M with a few bolt ons
1999 PSD - stock
kyle2002stang! is offline
post #26 of 33 Old March 4th, 2015, 12:46 AM
Anna
FOUSH's Avatar
I may be Interested as well! Lol
FOUSH is offline
post #27 of 33 Old March 4th, 2015, 07:44 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
When I get my car back ill make a couple.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #28 of 33 Old March 6th, 2015, 10:27 PM
Pate so if you get the inline coolant fill what would you do with the tank then? Can you drop it below the top of the radiator then?
dwtjr3 is offline
post #29 of 33 Old March 6th, 2015, 10:30 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Sorry I don't understand what your asking?
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #30 of 33 Old March 6th, 2015, 10:32 PM
Originally Posted by stal94gt View Post
That tank with the bottom fill and the top over fill will work almost like oem. I know you wanted to get rid of the bottom pipe but that tank will require it.
Was you meaning that this tank would work?
Canton Racing Products 80-202, Canton Racing Coolant Expansion Fill Tanks | Canton Racing Products
I like this tank, will it work without the inline coolant fill then or will I still need it?
---------- Post added at 09:32 PM ---------- Previous post was at 09:30 PM ----------
I was meaning in this picture, if you get the inline coolant fill like you are talking about where would you mount the expansion tank then? Does it have to be the highest point in the system then?
dwtjr3 is offline
post #31 of 33 Old March 6th, 2015, 10:35 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Yes a tank like that would work it would basically function like a old fox bodies system would. It don't really matter about the placement. Myself and Sharbait tried the cheap plastic containers and they would blow the cheap plastic lids off so a good solid one like your looking at would work.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #32 of 33 Old March 7th, 2015, 01:22 AM
stal94gt's Avatar
that coolant tank will work, you will use the bottom port if you want it to be able to siphon coolant back into the system like the old fox bodies.
bone stock from the factory!
stal94gt is offline
post #33 of 33 Old June 20th, 2015, 06:23 PM Thread Starter
bumping because i never really got a clear answer. if i run my cap in the upper radiator hose, does the expansion tank still need to be the highest point in the system? i would like to mount it remotely in order to hide it better.
1999 PSD - stock
