#2 pass side spark plug blowout, PLEASE HELP!!! - Forums at Modded Mustangs
post #1 of 12 Old March 7th, 2015, 11:44 AM Thread Starter
Applehead281's Avatar
I started the car this morning, and it instantly blew out the number 2 plug on the pass side.... Need help on what to do next, and my options. Reps for sure!!! Thanks
The usual bolt on's..
Applehead281 is offline
post #2 of 12 Old March 7th, 2015, 11:48 AM
46L281GT's Avatar
Most people take it and get a timesert or helicoil. I personally went with the helicoil because it was cheaper and it's fairly easy to do. did it bust your coil pack?
1999 Mustang GT 5 Speed Vert
Procharger P1SC @ 9 psi
382/382 STD
Tuned by Chicken Hawk Motorsports
Supercharger Build Thread: https://www.moddedmustangs.com/forums...ld-thread.html
46L281GT is offline
post #3 of 12 Old March 7th, 2015, 11:58 AM Thread Starter
Oh yeah broke it clean off where it bolts to the intake, gotta order a new one from msd, pisses me off, it just turned 40,000 miles.... You got a link for the helicoil???
post #4 of 12 Old March 7th, 2015, 12:27 PM
46L281GT's Avatar
I believe that i used this one.
Buy Heli-Coil Thread Repair Kit M14 x 1.25in. HEL5334-14 at Advance Auto Parts
You can also buy oem coils from advance and they always have discount codes which makes it one of the cheapest places to get them
Motorcraft Original Equipment (O.E.) Ignition Coil DG-508: Advance Auto Parts
With coupon code WD59 both of these are around 65 bucks
382/382 STD
46L281GT is offline
post #5 of 12 Old March 7th, 2015, 01:21 PM
stal94gt's Avatar
heli-coils work ok, but they are more of a temporary fix. some people have gotten good mileage out of them but many have issues with them backing out and stripping out the already hogged out hole. i would invest in a timesert. timesert is just as if not more reliable as stock and is not hard to do, just more expensive.
bone stock from the factory!
stal94gt is offline
post #6 of 12 Old March 7th, 2015, 02:06 PM
Mootang's Avatar
Never heard of timesert someone school me on what they are
Mootang is offline
post #7 of 12 Old March 7th, 2015, 05:25 PM
Tex1986
+1 on the timesert
Tex1986 is offline
post #8 of 12 Old March 7th, 2015, 09:23 PM
copermn's Avatar
Send a message via AIM to copermn
I used that one when mine went out on me nearly two years ago. Held the entire time. No issues with it. I don't use my kit anymore since I am putting a new engine in so I'd sell you mine for way less than what amazon wants, just PM me.
Edit: Just take your time using this kit. IT DOES WORK, like a F***ing charm. But to do it right you must take your time and just vacuum out the spark plug hole and if you can vacuum the cylinder as well (use a thin tube connected to the vacuum) Using a lot of grease on the taps helps as well. Don't want loose metal in the cylinder. I did it by myself. Took me a few hours but it worked like a charm and the car ran like new once I was done.
Perfection is impossible, but striving for it is not
copermn is offline
post #9 of 12 Old March 8th, 2015, 12:28 PM
Procrastinator
I have used the timesert kit to fix multiple blown out plugs on multiple vehicles. I have used helicoils for non vehicle related things and there is no way id use one for a spark plug on a car id prefer to keep. The timesert kit is a few more steps but is fairly easy and can be done within an afternoon.
DickH is offline
post #10 of 12 Old March 8th, 2015, 02:24 PM
It would be cheaper to buy a new cylinder head than using a timesert.
I guess you could sell the tool when you're done because the actual part is only $12.
2002 GT - 5 Speed
Novi 1000 @ 9 psi
Mods in My Garage
Silver GT is offline
post #11 of 12 Old March 8th, 2015, 03:18 PM
kyle2002stang!'s Avatar
i did the timesert on mine with no complaints and im boosted.
2002 mustang gt - turbo'd and blown up
1980 mercury zephyr wagon - roller undergoing rust repair
1970 galaxie - 351W cruiser
1978 F150 - 4x4 400M with a few bolt ons
1999 PSD - stock
kyle2002stang! is offline
post #12 of 12 Old March 9th, 2015, 01:22 PM Thread Starter
Thanks for all the info guys, But for the amount the timesert is, I could start building a 306... I am seriously considering putting a pushrod engine in this car. I can build a 400 hp 306 for like 3 grand. It would be a lot of work to convert but in the long run I would save myself the headache of another plug blowout again. Reps to you all!
