I need advice on oil pressure Please - Forums at Modded Mustangs
post #1 of 23 Old March 28th, 2015, 09:12 PM Thread Starter
raveer2000's Avatar
I just did a 4V swap on my 02 GT. I removed the 4V from the 97 Mark 8 myself. I started the car numerous times and ran it by spraying fuel into the intake to listen for knocking noises. The fuel pump was bad in the lincoln. I just tried to start my GT and I have no oil pressure. I have fuel and spark but the engine wont run. I pulled the oil pressure sensor and spun it over and not a drop came out of the port. I lowered the stock pick up tube by an inch so I know it was submerged in oil. Could this oil pump just no work all of a sudden??
raveer2000 is offline
post #2 of 23 Old March 28th, 2015, 09:29 PM
StangAddiction's Avatar
Send a message via Skype™ to StangAddiction
What oil pump are you using? Is this the one that was already on the used mark engine or the one from your GT?
USN - E5
1999 GT: 2 Spun Rod Bearings
2007 Cadillac CTS-V: Bone stock
StangAddiction is offline
post #3 of 23 Old March 28th, 2015, 09:53 PM Thread Starter
raveer2000's Avatar
I used the mark pump and pick up tube. Mark oil filter adapter. I just cant believe I have zero oil pressure.
post #4 of 23 Old March 28th, 2015, 11:48 PM
Froush's Avatar
iTrader: 8 reviews
You could have lowered it too much and it might not have any clearance between the suction and bottom of the pan. There is a spec on how much clearance needed. I would have a book somewhere but I'm not sure where it's at. Joys of still unpacking. Lol
"Happiness is being blown and stroked at the same time"
V6 => Teksid 302 stroker
Caitlyn Jenner swapped
My Build Thread click link
https://www.moddedmustangs.com/forums...shs-build.html
Froush is offline
post #5 of 23 Old March 28th, 2015, 11:59 PM
You should use the GT's pickup tube.
USN - E5
post #6 of 23 Old March 29th, 2015, 12:09 AM
evil02gt's Avatar
I agree it could be a clearance issue.
evil02gt is offline
post #7 of 23 Old March 29th, 2015, 09:30 AM Thread Starter
raveer2000's Avatar
The sump 3/4 inch from the bottom. It clears fine. I think the oil pump has just completely stopped pumping. with me spraying fuel into the throttle body I guess I just bypassed the no oil pressure signal by putting fuel into it. The sensor must tell the computer to inject fuel is why it wont crank now. I am wondering no how the sensor references the computer. Does it show ground when pressure is applied. I would like to make it fire once to make sure my wiring is ok before I pull this motor and go through it.
---------- Post added at 08:30 AM ---------- Previous post was at 08:23 AM ----------
GT's pickup tube wont fit the mark oil pump. Its too small.
I simply used a longer bolt and a spacer and moved the pickup tube lower into the pan. Its not on the bottom about 3/4 inch from the bottom.
post #8 of 23 Old March 29th, 2015, 09:32 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
If you think its a computer issues clear the computer. As far as the oil pump it is mechanical so not a lot to go wrong a couple things come to mind for me..
Did you put the O ring back on the oil pickup tube where it bolts to the pump? If not your not sealing off enough to create a good suction.
Your not going to get oil pressure turning over a motor It physically has to be running, And if you have not primed the oil system yet you will not get any oil pressure.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #9 of 23 Old March 29th, 2015, 09:54 AM Thread Starter
raveer2000's Avatar
I believe this might be my problem. I dont know how long the engine sat in the mark 8 before I bought it. I didnt know I had to prime the system. I never removed the pick up tube only lowered it. I guess Im gonna get a cheap garden sprayer and adapt it to 1/4 NPT and try priming it.
post #10 of 23 Old March 29th, 2015, 09:57 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
You'll need to also make sure your o ring is installed if you cant remember, and your clearances are correct between the pan and pickup which it sounds like you already checked.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #11 of 23 Old March 29th, 2015, 03:13 PM
wraitherx's Avatar
iTrader: 13 reviews
do you come to the conclusion that you have no oil pressure because of the factory gauge?
1999 Ford Mustang SVT Cobra Built
2011 Ford Taurus SHO TT AWD
Originally Posted by Towelie View Post
he spent all the time
thinking about if it could be done, and not thinking about if it should be done
wraitherx is offline
post #12 of 23 Old March 29th, 2015, 06:59 PM Thread Starter
raveer2000's Avatar
Update...
I bought a cheap pump sprayer and a 1/4 air hose repair kit from home depot. I piece of rubber hose clamped on the nozzle and the other end to the oil pressure port. It took about 15 to 20 mins to pump 5 quarts into the motor. I slowly rotated the crank as it pumped in. After it all went in. I poured in the last qurat and put the sensor back in. Turned the key on and the gauge read pressure before I even cranked it. I spun it over and it wouldn't crank again. Fuel pressure is steady at 45 psi. I pulled the plugs just out of curiosity and the gap and wear was huge. Over 100 thousands gap on everyone. I gapped them all to 40 thousands and reinstalled. Motor fired but wouldn't run well. Mass airflow meter doesn't fit in the mark intake tube. I haven't gotten the cold air yet, so on a whim i duct taped the meter to the tube just as a temporary thing to see and the motor fired right up and idled ran great.. starts first time every time now. I don't trust the oil sensor at all so I am going to hook a manual gauge tomorrow and check the actual pressure. If it has pressure then I will continue to get it finished. Thanks for all the help
post #13 of 23 Old March 29th, 2015, 07:33 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Good deal it sounds like the reason its running rough is because your MAF is displaced not getting a good signal.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #14 of 23 Old March 29th, 2015, 07:36 PM Thread Starter
raveer2000's Avatar
Definetly. Do you have any ideas on a mark 8 throttle body to stock gt mass air meter tubing? I have the mark tube and gt tube but only the gt mass air meter
post #15 of 23 Old March 29th, 2015, 07:58 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Can you post a picture of the TB? I am sure we can find a coupler to adapt it to the GT housing but I cant remember what the TB looks like off hand.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #16 of 23 Old March 29th, 2015, 09:09 PM Thread Starter
raveer2000's Avatar
Best pic I have at the moment
---------- Post added at 08:09 PM ---------- Previous post was at 08:01 PM ----------
post #17 of 23 Old March 29th, 2015, 09:52 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
ok your going to need to measure that TB and order a silicone couplers that goes from oval to round. I personally don't know what size it takes but with a quick measurements you'll be able to order the right one.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #18 of 23 Old March 29th, 2015, 10:35 PM Thread Starter
raveer2000's Avatar
Ok I will take some measurements tomorrow and order the couplers. Thanks
post #19 of 23 Old March 30th, 2015, 08:17 AM
Hans Sprungfeld
WickedSnake00's Avatar
Off the top of my head I think it was either 3/8" or 1/2."
Another one I think I recall, it should be about 4.25" for the oval TBs. I think most of the adapters are 4.25 to 3.5 or 3.
WickedSnake00 is online now
post #20 of 23 Old March 30th, 2015, 01:12 PM Thread Starter
raveer2000's Avatar
I had some good news this morning. 90 PSI oil pressure at startup on a manual gauge
