balancer removal - Forums at Modded Mustangs
post #1 of 5 Old May 13th, 2015, 06:42 PM Thread Starter
2v Turbo Teksid swap
balancer removal
So who has the trick to remove this? I have tried an impact to get the center bolt off, and she isn't budging the slightest. I tried it both ways hoping to loosen up what ever build up of rust or whatever BS has worked its way in there. It does come off counter clockwise when you are looking at the front of the motor I assume. Cant remember off the top of my head though.
nicks01gt is offline
post #2 of 5 Old May 13th, 2015, 06:52 PM
Too broke
Fatstang's Avatar
Yes, counter Clock wise. Put the car in 3rd if a stick, use a large breaker bar with a pipe on the end
Fatstang is offline
post #3 of 5 Old May 13th, 2015, 06:54 PM Thread Starter
Its an auto. I did realize my impact is only good to 250lbs of torque. Getting another one that can go to 800lbs from a buddy. Thanks for the +1 on the rotation Fat.
post #4 of 5 Old May 13th, 2015, 11:30 PM
King Trashmouth
WickedSnake00's Avatar
Lefty loosie.
I usually end up using a 2ft breaker with another 1-2ft of cheater pipe, with the car in 6th, e-brake on, and wheels chocked.
WickedSnake00 is offline
post #5 of 5 Old May 14th, 2015, 09:24 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Counterclockwise is the correct direction for removal, you'll need a good quality impact those impact with little torque wont get it done...
On installation make sure you put a dab of sealant on the crank key.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
