PI intake coolant leak? - Forums at Modded Mustangs
post #1 of 30 Old August 7th, 2015, 09:33 AM Thread Starter
ZenMGT's Avatar
I'll try to load some pics later, but I let my '02 GT sit for about 3wks, and after two quick drives my AC dies, and I develop a coolant leak. Yay.
The coolant leak problem:
It's definitely coming from the thermostat gasket area, or directly below on the intake (intake cross over that leads right up to the thermostat).
I can see what looks like a little bit of spray marks right in that area, my driver side of the motor is wet.
I caught the leak quick, no overheating.
My oil is clean.
The coolant is brown, but I believe from age.
From what I described, it's safe to say it's either the thermostat gasket, OR my intake has cracked in that area, correct?
,,,and if it's the intake manifold, I'm assuming (for my stock'ish car) the FRPP is the best choice - who's got the best price on these?
Graci
GMS intake & plenum, 70mm frpp tb, UPR ss w/rockcrusher, UPR o/r X, frpp 3.73s, Predator'd
boringly stock........but running well
LZR RED CREW#15
ZenMGT is offline
post #2 of 30 Old August 7th, 2015, 10:56 AM
maxgst's Avatar
Are you in Boca, FL?
2000 Mustang GT vert - Gone
2007 BMW 335i
maxgst is offline
post #3 of 30 Old August 7th, 2015, 11:33 AM Thread Starter
ZenMGT's Avatar
In Boca for work - Coconut Creek home.
---------- Post added at 10:33 AM ---------- Previous post was at 10:06 AM ----------
A few pics of what I could see:
LZR RED CREW#15
ZenMGT is offline
post #4 of 30 Old August 7th, 2015, 12:03 PM
bodyshot's Avatar
The plastic under the aluminum crossover cracked, how many miles on the car?
bodyshot is offline
post #5 of 30 Old August 7th, 2015, 01:41 PM Thread Starter
ZenMGT's Avatar
I bought it at 72k, she has 127k miles now.
Ya, I had a bad feeling it was probably the plastic under the aluminum crossover like you mentioned.
I'll dry it up tonight and watch for it happen to be sure.
Anyone got a new PI intake for sale? Where's the cheapest place to get a new one?
LZR RED CREW#15
ZenMGT is offline
post #6 of 30 Old August 7th, 2015, 01:57 PM
98SnakeHorse's Avatar
AM has them for around $200 you can find them all the time over on corral pretty cheap.
1998 Mustang Cobra [Sold]
2000 Mustang Gt Built/Blown [Sold]
1995 Mustang Gt Built/Turbo [Part-Out]
1998 Mustang Gt Built 2v / Vortech V3 (Budget Blue)
98SnakeHorse is offline
post #7 of 30 Old August 7th, 2015, 02:03 PM Thread Starter
ZenMGT's Avatar
Well I see AM sells the FRPP one for $300, and another no name (I'm assuming the Dorman) for $200'ish.
Is the FRPP one the same as what came on my '02 from factory? Or are there three? (FRPP PI, Stock PI, Dorman/other junk)
LZR RED CREW#15
ZenMGT is offline
post #8 of 30 Old August 7th, 2015, 02:19 PM
Go FRPP or Stock, dorman/others are crap I hear. Also I am pretty sure @maxgst has one for sale is is sort of local.
2003 Redfire & Black V6. Full suspension, 8.8 w/ 4.10s, tuned. 4.3L stroker + turbo capable of 550 hp soon
1992 5.0 Auto Hatchback...needs wiring, interior, ...basically everything
RIP: 2015 SHO PP, 12.87 @107 1/4 mile
Derfdog15 is offline
post #9 of 30 Old August 7th, 2015, 02:35 PM Thread Starter
ZenMGT's Avatar
Ya, I saw his for sale thread, he's very local,,, but it looks like that intake is off a car with 120k miles,,, mine has 127K and it just busted. I'm sure it's a good part he has, but I'd rather a fresh part.
Looks like Amazon has them for $240'ish shipped.
So my cart currently has:
FRPP intake manifold
8 Inj O-rings
Felpro intake manifold gasket set
New thermostat (already bought)
new thermostat gasket (already bought)
Do I need anything else for this job?
I'll probably do the plugs, and give the lower intake a good scub'n while i'm in there.
LZR RED CREW#15
ZenMGT is offline
post #10 of 30 Old August 7th, 2015, 02:58 PM
maxgst's Avatar
you need some high temperature rtv sealer for the sensor that bolts into the passengers side on the front of the manifold.
2007 BMW 335i
maxgst is offline
post #11 of 30 Old August 7th, 2015, 03:29 PM
bodyshot's Avatar
you may need a few pintle shrouds for you injectors if any of them are cracked.
bodyshot is offline
post #12 of 30 Old August 7th, 2015, 03:45 PM Thread Starter
ZenMGT's Avatar
Forgot the RTV! - thanks Max.
I thought we had the 4 hole design injectors? Where do I get these pintle shrouds/caps? Never heard of them before.
LZR RED CREW#15
ZenMGT is offline
post #13 of 30 Old August 7th, 2015, 10:30 PM
GT Rob's Avatar
ZenMGT your not the only one having that problem I just rebuilt my motor about 3 months ago and been through 2 intakes should have bought a new from the start there's some on ebay
GT Rob is offline
post #14 of 30 Old August 9th, 2015, 01:59 PM
bodyshot's Avatar
You can get them at NAPA
bodyshot is offline
post #15 of 30 Old August 11th, 2015, 07:54 AM
6 Cylinduh, Really Bruh?
TheOdessa's Avatar
Do not get the Dorman! Get the frpp all day. I got the Dorman and had to replace it.
Get some new felpro gaskets and a good torque wrench. Tighten the bolts in the right pattern and to the correct specs. Make sure the surface is extremely clean prior to installing the new intake. I did this with a wire brush and shop vac to suck up all the crap. It's not a hard job, just tedious.
I can't stress enough on how important it is to get the frpp one for proper fitment. Also buy new. I wouldn't trust this part used.
http://imageshack.com/a/img832/3492/odessadone.jpg
2001 Mustang GT Convertible - Black with Black Top - 5SPD
Bolt On Warrior - Everything done to my car:
https://www.moddedmustangs.com/forums...l#post11931130
TheOdessa is offline
post #16 of 30 Old August 11th, 2015, 01:19 PM Thread Starter
ZenMGT's Avatar
Indeed - the FRPP is what will be ordered.
There was thread on here that listed all the tools I would need - I can't seem to find it now?
Not looking forward to the work, my back has been killing me.
I've honestly been toying with the idea of selling her as I recently picked up another project vehicle (a regular cab dakota R/T), and of course this and the AC dying would happen.
LZR RED CREW#15
ZenMGT is offline
post #17 of 30 Old August 11th, 2015, 01:41 PM
maxgst's Avatar
Take it from me, the intake manifold is VERY easy to replace.
2007 BMW 335i
maxgst is offline
post #18 of 30 Old August 11th, 2015, 02:49 PM Thread Starter
ZenMGT's Avatar
I'm sure it isn't bad. I've done a few intakes on various cars, swapped a few cams in my day - just popping my cherry on the mustang finally.
If I fix it,,, I'll probably keep it instead of selling it, and I need to sell it - have to many cars right now. I just love how these car look, and the ride.
I might even put the stock air intake/plenum/tb/tune back on... so depressing.
LZR RED CREW#15
ZenMGT is offline
post #19 of 30 Old August 11th, 2015, 03:03 PM
maxgst's Avatar
I know what you mean, I got a bmw 335i, and I really miss the mustang haha
2007 BMW 335i
maxgst is offline
post #20 of 30 Old August 12th, 2015, 09:26 PM
TheOdessa's Avatar
My AC issue ended up being a burned up relay box located in the passenger fender well. Only place I could find it was Napa locally. Sure it was online cheaper but I wanted it asap as no AC in FL with an all black car sucks.
