Looking to buy these ported 2v heads but i have a question - Forums at Modded Mustangs
 1Likes
post #1 of 37 Old August 22nd, 2015, 03:06 PM Thread Starter
condor123's Avatar
So I am looking to buy these heads My concern is the fact that they have been decked .030
Not sure if that will affect anything. Let me know what you guys think, if you guys think they are good i will start negotiating the price down
Stg. 2 PI heads
$1,000 — El Paso, Texas
$1000 shipped
Lets try this again. NEW PICS
-300 miles on heads
-fully assembled (includes cams, followers, lash adjusters, and valve covers, NO CAM GEARS)
-stock PI cams
-built for high-boost and big cams (just drop in the cam of your choice)
SPECS:
-2002 5-thread casting
-MMR bronze valve guides
-MMR extreme-duty seals
-Comp Hi-load springs
-Stg. 2 port
-performance 5-angle/radius valve job (exhaust shroud removed)
-CNC gasket-matched
-decked to .030
condor123 is offline
post #2 of 37 Old August 22nd, 2015, 04:00 PM
y2k02's Avatar
I would run them. My 02 ported PI heads are decked .030.
The price is good. The only thing I dont like about them is it looks
like they have stock valves. But, I'd still run them.
2002 GT Teksid TFS Heads Edelbrock Intake Twin PTE 6466 turbos TH400/UCC Converter Holley Dominator EFI
2018 Challenger Scat
Eddie Edwards on facebook
y2k02 is offline
post #3 of 37 Old August 22nd, 2015, 06:09 PM
It will change compression but not enough to really mater on your build
mjackson3010 is offline
post #4 of 37 Old August 22nd, 2015, 06:10 PM
What r your plans for this motor?
post #5 of 37 Old August 22nd, 2015, 08:16 PM Thread Starter
condor123's Avatar
I have a terminator short block, Looking to get a set of ported heads and some blower cams, I have a vortech v2. Not sure how much boost i can squeeze out of the blower, might do an 8 rib pulley swap. So y2k i should be fine with stock valves? I think I will offer him 800$ shipped?
post #6 of 37 Old August 22nd, 2015, 09:08 PM
y2k02's Avatar
Yes. The stock valve doesnt give as much clearance for ptv as a aftermarket valve.
y2k02 is offline
post #7 of 37 Old August 22nd, 2015, 10:02 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Heads look good on paper do you have any pictures ide like to see the valves and the ports.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #8 of 37 Old August 22nd, 2015, 10:34 PM Thread Starter
condor123's Avatar
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
post #9 of 37 Old August 23rd, 2015, 02:46 AM
Maybe its just poor pics but that looks like a sloppy DIY port job. Definitely doesn't look like CNC to me. If it is a DIY then that would explain the stock valves when nearly every reputable worked heads would have had bigger valves.
Gasket matching is not porting. Never heard anyone say "CNC gasket matched" before this.
Is he saying MMR did everything? Any paperwork?
---------- Post added at 11:46 PM ---------- Previous post was at 11:34 PM ----------
That's a lot of crust in the water port for something that supposedly has 300 miles on it since all that work.
metalman302 is offline
post #10 of 37 Old August 23rd, 2015, 04:26 AM
SAVE YOUR MONEY AND BUY TFS HEADS.
THATS WAY TO EXPENSIVE FOR SOME CRAPPY WORK PORTED STOCK HEADS.
Look around you see nicley dont up stock heads for 700-800 all the time. They dont have much resale anymore since TFS heads flooded the market... and for good reason. The best ported PI head wont even touch a TFS head out of the box.
1999 GT 630rwhp on pump, TFS Heads, MMR 4.75L, Highly Modified Kenne Bell 2.1 @ 20lbs, Custom Intercooler, JLT High Boost CAI, CMS Custom TFS Specific Cams, 3.55s, MGW, T56
Nitmare67 is offline
post #11 of 37 Old August 23rd, 2015, 09:50 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Oh my, that's not MMR heads I have never seen them do any work like that before if anything that will slow down the flow with all those jagged edges. Keep looking cause those heads suck.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #12 of 37 Old August 23rd, 2015, 01:12 PM Thread Starter
condor123's Avatar
He said it was a local shop porting the heads, he has pics of the paper work. Ill definitely pass on them and keep looking. Glad i made this thread, thanks guys! I have been looking at CMS trickflow head cam packageshttp://www.cushmanmotorsports.com/cms-trick-flow-head-cam-package-track-heat-185-2v-heads-38cc-125lb-springs/, Do i want 38cc or the 44cc heads?
post #13 of 37 Old August 23rd, 2015, 03:15 PM
It depends what your wanting to do. This is a centri car? Whats the current compression and piston dish size? How much peak beat are you running?
post #14 of 37 Old August 23rd, 2015, 03:19 PM Thread Starter
condor123's Avatar
Another part of my build i need help on is selecting the proper head gasket for my application. what are you guys running on your cars?
---------- Post added at 02:19 PM ---------- Previous post was at 02:17 PM ----------
It is a centri car, the bottom end is going to be a 2003 cobra short block so i think 17cc?
post #15 of 37 Old August 25th, 2015, 11:09 AM
I don't like oem ford MLS head gaskets... never have. I pretty much exclusively use the standard fel pro MLS head gaskets. They have a thicker rubber coating in the exterior of the gasket which greatly reduces oil seepage in the event that the decks are not perfect. I've never lost a fel pro head gasket and I'm pushing 21lbs. You can buy them at autozone.
Part number 9790-PT2 and 9792-PT2.... one part number for each side.
If I need a special head gasket or I want something more exotic then it's always cometic.... you're taking 300 for cometic gaskets vs 90 for fel pro so you better be damn sure you need a special head gasket before you go wasting all that money lol
post #16 of 37 Old August 25th, 2015, 02:19 PM Thread Starter
condor123's Avatar
Well I only plan on running 15 lbs so i think i will go with the fel pro head gaskets and use the extra $210 for some head studs lol. thanks for the input
post #17 of 37 Old August 25th, 2015, 02:40 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Guys I've been running the Ford MLS for years and even currently and at 26psi, however I always use molly lube to torque the heads.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #18 of 37 Old August 25th, 2015, 11:28 PM
I do a lot of my own porting and I would throw those heads in the trash.
post #19 of 37 Old August 25th, 2015, 11:37 PM
I tell people that if u r porting at home then less is more. Think those heads would flow less then stock. I could never try to sell heads like that I would be imbarist. I don't know any port shop putting out crap like that.
Head gaskets I use felpro with copper coat on my tt cobra
post #20 of 37 Old August 26th, 2015, 02:31 AM
ARP Head studs are a good idea... torque with ARP lube or moly lube. It comes with the kit... Dont get my comment wrong bout OEM head gaskets. You wont blow one out any easier than a fel pro. The reason I dont like them is because they only have a very very thin viton covering on the gasket and will seep oil alot easier than fel pro gaskets which have a thicker and more tacky coating. If you ever notice you will find alot 4.6 Mustangs (especially 2 valve) will leak oil into the valley pan (area under the intake manifold) they will also have alot of dust accumulated on the sides of the block. This is becase oil of oil seepage between the head and the block. Ford recalled alot of them. I have pulled motors down that were leaking pretty bad, cleanen the decks with brake cleaner and threw them back together with fel pros and they never leak again... If I do use OEM MLS gaskets I spray them with copper coat which provides much better sealing against oil seepage. You just have to be careful and spray to 2 or 3 light even coats. I actually do that on alot of head gasket even on pushrod motors and have always had good results.
