Comparison on 99 Mustang GT, 275/40zr17 vs 245/45zr17 - Forums at Modded Mustangs
 5Likes
post #1 of 34 Old February 10th, 2016, 04:49 AM Thread Starter
KB99GT's Avatar
Looking for opinions. I have OEM ordered with the car (and thus, painted to match) 17x9 cobra rims on a 99 GT. They came with 275/40's, I just put Uniroyal Tiger Paw GTZ 245/45zr17's on it. Did I F up or is this a good selection for a DD? Ford Racing B spring drop when i bought it. Only mod done to it before i bought it 5yr ago. Had Michelin Pilot Sport 275/40zr17's on it dried out bad even from the get go, just ran them until they started cracking to dangerous levels. So far, the Uniroyals ride smoother and track well on the car. Stick well and I no longer have the dried out lack of grip, but, I know there's a wealth of knowledge here.
KB99GT is offline
post #2 of 34 Old February 10th, 2016, 09:47 AM
US Air Force (retired)
Eagle2000GT's Avatar
You didn't mess up exactly. A 245/45-17 tire is suppose to fit on 7.5-9" wheels. So safety wise you are OK. I've run them on 9" wheels before. They look stretched and I didn't care much for the look. Tires stretched to the max offer no curb rash protection. I also had a bit of trouble with the outer edges of the tires wearing out first. Stretching the sidewall out pushes the edges of the tread down.
A 245/40-17 has the same sidewall height as a 245/45 (110 mm) so it doesn't throw off your speedometer. They are supposed to fit 9-11" wheels but I've had them on 10.5" wheels and they really looked stretched. So much so that I bought an extra pair of 9" wheels for my winter all-season tires.
Here is a tire/wheel calculator that I use:
Tire Size Calculator - Tire & Wheel Plus Sizing
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
Ret. USAF 1969-1973,1980-1996: Vietnam veteran. Aircraft maintenance. R & D, ICBM Operations.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
post #3 of 34 Old February 10th, 2016, 10:42 AM
maxgst's Avatar
On my other car im running 235/40 on a 10 inch wheel (at least until I get wider fenders and can fit a wider tire), and I have friends running 225 on a 10 inch wheel, so safety wise you are clear.
What you might be lacking is grip.
2000 Mustang GT vert - Gone
2007 BMW 335i
maxgst is offline
post #4 of 34 Old February 10th, 2016, 11:05 AM
245 on a 9 inch wheel will look dumb, IMO.
8 inch wheel = 245
9 inch wheel = 275
10.5 inch wheel = 315
That will leave the sidewall relatively straight with no stretch, and possibly just a touch of bulge depending on the exact brand and how wide they run. My 275 Nittos were straight, and my current 275 BFGs bulge ever so slightly. Looks great.
Eagle2000GT likes this.
-Will
sneaky98gt is offline
post #5 of 34 Old February 10th, 2016, 04:41 PM
akurma's Avatar
8 inch wheel = 245
9 inch wheel = 275
x2 with the "bulge" depending on brand. 315 Mickey Thompson's bulge a bit but i've seen other brand 315's with no bulge
akurma is offline
post #6 of 34 Old February 10th, 2016, 07:37 PM
blownstang's Avatar
I run a BFG 255 on my 9" front wheels. Its slightly more of a stretch than i expected. I wouldnt put a 245 on just because of how it would look.
blownstang is offline
post #7 of 34 Old February 10th, 2016, 08:39 PM
Nile P. Pezdel of Pez Dispenser Inc. CCA
nileppezdel77!'s Avatar
Originally Posted by maxgst View Post
I have friends running 225 on a 10 inch wheel.
Yikes...
Eagle2000GT and sneaky98gt like this.
'01 GT Convertible
Maximum Motorsports TQA|PHB|FLSFC|LCA|Coilovers
D&D T56 Magnum; Cobra R Brakes; Sparco Seats
Tuned by Mustang Magic and so much other stuff
'16 Fiesta ST
Cobb FMIC, Turbo-back exhaust, RMM and Air Filter
Tuned by Stratified
nileppezdel77! is offline
post #8 of 34 Old February 10th, 2016, 08:40 PM
Yup, my 275/40-17 MT ET Street Radials bulge quite a bit on my extra set of track wheels (also 17x9). That being said, I wouldn't go down in size over what I posted above because of it. It definitely looks and performs better if it's a little oversized vs. undersized, and I'd consider those numbers I posted above to be minimums.
-Will
post #9 of 34 Old February 10th, 2016, 08:48 PM
The Dude Abides
1MeanNonPI2v's Avatar
I wouldn't run anything less than a 275 on a 9" wide wheel. You get much better turn in response and braking with the wide front tires too.
"Yeah, well, you know, that's just, like, your opinion, man." - The Dude
"If you can't hear it before you see it, what's the point?" - Jesse James
1MeanNonPI2v is offline
post #10 of 34 Old February 10th, 2016, 11:16 PM
I run 275/40-17 Continental ExtremeContact DWS on my 9" wheels. They look and perform well. I have run 245/45-17 Continental ExtremeContact DWS on the same wheels. I won't do it again.
post #11 of 34 Old February 10th, 2016, 11:20 PM
Post some pics man. I was debating about 17x9s and running my 245s for now.
2k2wranglerx is offline
post #12 of 34 Old February 11th, 2016, 10:14 AM
maxgst's Avatar
Lol, Mustang people be way too uptight, throwing accusations without any real world experience.
this is 225 on a 9.5 (My ex roommate)
This my my other roommate, with the 225 on 10 inch rim I was talking about
I'm not saying it looks good, but they both have been running that set up for a long ass time, and never had any issues. so 245 on a 9 inch rim is totally fine.
2007 BMW 335i
maxgst is offline
post #13 of 34 Old February 11th, 2016, 11:44 AM
Anandavenkatakrishnan
dsgpony's Avatar
If you're looking for better turn in, I would actually put a 255/265 on the front with a lower profile (35 series) and turn the camber down.
[/CENTER]
dsgpony is offline
post #14 of 34 Old February 11th, 2016, 12:30 PM
The Dude Abides
The narrower tire won't out brake the 275. And the 275 will still have a larger contact patch in the turns. The 275 is superior to the 255 IMO.
I've had a 245, 255 and a 275 on the front of my cars. 275 is hands down my favorite and it absolutely fits a 9" wide wheel the best.
post #15 of 34 Old February 11th, 2016, 06:39 PM
blownstang's Avatar
I bought my car with a 275 up front and went to a 255. I didnt want that big of a tire up front. It feels much better. The 255 BFG is flush with the lip and offers little curb rash protection. A 245 would definitely have the lip sticking out. I wouldnt do 245 just because of the ricer look.
post #16 of 34 Old February 11th, 2016, 08:58 PM
The Dude Abides
Well I just mounted my new Toyo R888 275/40R17 front and 315/30R18 rears and it looks spectacular. Tires are super sticky, haven't done anything crazy to really test them out. I'll never go away from a 275 in front of a 94-04 unless I go slick and skinnies.
post #17 of 34 Old February 11th, 2016, 09:50 PM Thread Starter
KB99GT's Avatar
I personally love the 245's, especially the grip for an all season tire. Grips better than the 275's ever did, bit taller though, and with the b spring/no isos on the front....gotta watch big bumps. Outside of that, it corners better, and where i usually go hard from a stop, and always ended up sideways going from 1/2 it just has a light chirp going to 2nd. Width difference is barely noticable, and very very little bulge. heck, the 275's bulged more, probably due to the dry-rot. By the way, these are stock tire size for OEM cobra rims from 99, which is what this has on it. Overall, very pleased with the choice.
KB99GT is offline
post #18 of 34 Old February 11th, 2016, 11:32 PM
Corner Carvin
Nobody is throwing accusations, they are throwing truths. Just because a bunch of stance nation idiots run stretched out tires doesnt make it advisable.
Tires are meant to fit specific wheel sizes based off the tire widths. It's not fiction.
Eagle2000GT and 1MeanNonPI2v like this.
99 cobra- Slow
JCP281 is offline
post #19 of 34 Old February 12th, 2016, 12:21 AM
blownstang's Avatar
99 cobra wheels are 17x8. You mentioned 17x9 in your first post?
post #20 of 34 Old February 12th, 2016, 09:33 AM
New time's coming soon!!!
CJackson's Avatar
iTrader: 9 reviews
I never noticed a difference going from a 245 to a 275. It isn't going to matter. Then when I swapped to skinnys I honestly still didn't notice much when it comes to braking. But obviously I did when it came to turning, even then it isn't near as bad as some people put it out to be.
My Build Thread : https://www.moddedmustangs.com/forums...-gt-build.html
D1SC 12-13psi 391rwhp 411rwtq
CJackson is offline
