Finally got to the dyno today - Forums at Modded Mustangs
 4Likes
post #1 of 23 Old May 31st, 2016, 07:49 PM Thread Starter
So after having installed the Vortech over a week ago and staring at it in the driveway the whole time I finally got to the dyno. Car put down 389 rwhp / 360 rwtq
2004 GT
-Vortech V3 non intercooled w/Anderson power pipe
10 lbs boost
-SLP LT Headers, SLP Catted X, SLP LM1 Catback
-BBK 73mm TB
-90mm Lightning MAF /IAT Relocate to in front of TB
-Walbro 255lph Fuel Pump
-FR 47lb injectors
-NGK TR6 Plugs
IAT Temps were getting really up there so I'm adding Meth Injection and headed back for a retune. Shooting for 425rwhp or better.
I did notice after the blower install I have hesitation and bucking at low Rpms and speeds. It was happening on the temp tune on the ride up and on my current tune. Any thoughts? Fuel is not the problem, and I don't seem to have a vac leak.
Other than the small hesitation car screams and I am very happy with my results.
Last edited by Importkilla; May 31st, 2016 at 09:17 PM. Reason: Did not spell word correctly
Importkilla is offline
post #2 of 23 Old May 31st, 2016, 08:05 PM
Your tuner needs to work on the part throttle of your tune. A lot of tuners don't spend enough time dialing in the lower rpm parts of the tunes
02 roush turbo forged and built
mhs stage 3 heads cms 2.5 turbo cams
CG T6 hot side billet BW S478 with race cover
Dyno numbers coming
Sonic 02 is offline
post #3 of 23 Old May 31st, 2016, 08:23 PM
99SilverGTVert's Avatar
Is you car a manual or an auto?
Vortech V3, Treadstone TR10, Magnapacks/Catted XPipe,Stack 70mm TB/Plenum, 3.73s, 377 RWHP, 370 RWTQ
99SilverGTVert is offline
post #4 of 23 Old May 31st, 2016, 08:44 PM Thread Starter
Manual
post #5 of 23 Old May 31st, 2016, 09:56 PM
blownstang's Avatar
Congrats! Power sounds right. Mine made 356/371 with a non intercooled V1 S at 9psi years ago. Do you know how much timing?
blownstang is offline
post #6 of 23 Old May 31st, 2016, 10:04 PM Thread Starter
Unfortunately, no
post #7 of 23 Old June 1st, 2016, 06:54 AM
Originally Posted by Importkilla View Post
Manual
Nice numbers!
post #8 of 23 Old June 1st, 2016, 11:16 AM Thread Starter
Nice numbers!
Thanks
---------- Post added at 11:16 AM ---------- Previous post was at 11:05 AM ----------
So I'm gonna order an intercooler instead with the Vortech Race bypass valve. I am thinking I would like to pulley down to a 3.33 pulley to maintain my current boost levels. Can I just add that pulley alone or do I have to change the idler also. I'm thinking I'm gonna go with the Mishimoto M Line IC from American muscle and just use the CX Racing piping kit from eBay.
I'm hoping this setup will net me 10 - 12lbs of boost and 425 - 450rwhp.
post #9 of 23 Old June 1st, 2016, 11:17 AM
GBPackerFan's Avatar
Good numbers dude! Meth smells awesome so that is a secondary benefit to it
NVM, you are getting an IC...good choice.
Importkilla likes this.
Matthew 26:52-54 / Go Pack Go!
2001 GT Convertible - D1SC / Cammed / Geared / 440wh 400wt
1994 V6 Convetible - Stock
2009 Malibu LTZ - Stock
GBPackerFan is offline
post #10 of 23 Old June 1st, 2016, 05:44 PM
blownstang's Avatar
See if there are any used Procharger 3 core intercoolers floating around. Great intercooler and usually run $200-$400 used. I went this route and used cxr piping. You can change just the pulley. Im guessing youll be at 11psi with this setup and a 3.33 pulley. You should really find out how much timing is in it to have an idea of what you can gain. Depending where you are now with timing 425rwhp is possible.
post #11 of 23 Old June 1st, 2016, 10:32 PM
Carving corners
MineralGreyGT's Avatar
iTrader: 18 reviews
185.00 Procharger Intercooler | eBay
Follow me on Instagram! Username:whistles._
https://www.instagram.com/whistles._/
MineralGreyGT is offline
post #12 of 23 Old June 2nd, 2016, 07:04 AM
I made 10.36 psi with a similar setup (no longtubes) and a 3.33 pulley and a Treadstone TR10 intercooler 377rwhp through an auto.
post #13 of 23 Old June 2nd, 2016, 01:09 PM Thread Starter
Talked to my tuner about what my timing is at and he said max is 15 but I'm seeing about 12 at 150 degrees
post #14 of 23 Old June 2nd, 2016, 04:34 PM
blownstang's Avatar
Mine was at 15 non intercooled as well. On the dyno you probably saw 15 as your iats were most likely not more than 120 with a fan blowing in front. Thats what mine were. With an intercooler he can add 2 degrees to bring it up to 17. Going up to 18 degrees would be pushing it a little. So an intercooler should get you another 15-20rwhp safely if boost stays the same. Power will be more consistent as there will be less heat soak.
post #15 of 23 Old June 15th, 2016, 07:29 PM Thread Starter
So I just got back from having my tuner tune for my alcohol injection setup. I am still adding an intercooler but wanted to also add the alky kit too. Very happy with my new numbers. Ended up with 433rwhp and 457rwtq @10.4 lbs boost. Can't wait to get her to the track so I can get some times.
post #16 of 23 Old June 15th, 2016, 07:35 PM
PRODUCTIONMAN's Avatar
if you're still having bucking issues I would suspect the Maf. That's around the power level that I was having a bucking problem with the Lightning maf and even a SCT BA3000. Went to blow through and a world of difference for driveability
PRODUCTIONMAN is offline
post #17 of 23 Old June 15th, 2016, 08:11 PM Thread Starter
Bucking issues have seemed to get better, still there but very subtle. However I do plan on changing over to blow through as soon as the intercooler goes in.
post #18 of 23 Old June 15th, 2016, 10:56 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
what were your AIT's?
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #19 of 23 Old June 16th, 2016, 07:03 AM Thread Starter
Yesterday it was about 85 degrees out and with the meth my temps were at 75-80. Regular driving they were around 125-135.
post #20 of 23 Old June 16th, 2016, 07:15 AM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
yes you need an intercooler ASAP yesterday it was over 90 degrees here and driving around I was logging 92 on my At's. The mishimoto R series is a over looked intercooler that seriously out performs the CX racing 4 core one. the other year when I logged with the CX racing 4 core on a day similar in heat my AIT's were well over 110 degrees.
604 RWHP 516 FT LB
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
