HP guess - Page 3 - Forums at Modded Mustangs
 19Likes
post #41 of 51 Old March 28th, 2018, 05:13 PM Thread Starter
GBPackerFan's Avatar
Numbers are in. It made 440wh and 400wtq on 11 pounds of boost ( @Eagle2000GT you were right on the money with the boost numbers!!). Runs good!
16 degrees of timing, 11.5:1 AFR, 70% duty cycle on the pump. Very pleased!
https://youtu.be/b5H7ESjPMyI
Eagle2000GT and bodyshot like this.
Matthew 26:52-54 / Go Pack Go!
2001 GT Convertible - D1SC / Cammed / Geared / 440wh 400wt
1994 V6 Convetible - Stock
2009 Malibu LTZ - Stock
GBPackerFan is offline
post #42 of 51 Old March 28th, 2018, 10:31 PM
Carving corners
MineralGreyGT's Avatar
iTrader: 18 reviews
Originally Posted by GBPackerFan View Post
Numbers are in. It made 440wh and 400wtq on 11 pounds of boost ( Eagle you were right on the money with the boost numbers!!). Runs good!
nice!!! congrats now enjoy it
GBPackerFan likes this.
Follow me on Instagram! Username:whistles._
https://www.instagram.com/whistles._/
MineralGreyGT is offline
post #43 of 51 Old March 28th, 2018, 10:59 PM Thread Starter
It needs to stop raining! It rained all the way home and is supposed to rain most of the week. Then I'm out of town next week...one day I'll drive it
MineralGreyGT likes this.
post #44 of 51 Old March 28th, 2018, 11:13 PM
US Air Force (retired)
Eagle2000GT's Avatar
Very nice numbers. You are going to love how the car performs.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
Ret. USAF 1969-1973,1980-1996: Vietnam veteran. Aircraft maintenance. R & D, ICBM Operations.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
post #45 of 51 Old March 29th, 2018, 09:45 AM
46L281GT's Avatar
Those are some awesome numbers! You'll get use to it and want more lol.
1999 Mustang GT 5 Speed Vert
Procharger P1SC @ 9 psi
382/382 STD
Tuned by Chicken Hawk Motorsports
Supercharger Build Thread: https://www.moddedmustangs.com/forums...ld-thread.html
46L281GT is offline
post #46 of 51 Old March 29th, 2018, 09:46 AM
bodyshot's Avatar
Great numbers for relatively safe timing!!!!
Go kick some new car ass!
sounds like dumped flows just like mine, gotta love it!
bodyshot is offline
post #47 of 51 Old March 29th, 2018, 11:38 AM Thread Starter
Yeah I am very pleased with how it came out. This D1 shines in the upper RPMs.
Yeah...I'm sure that's true. I have a 4.6 and 5.4 block sitting around...just need rods and pistons
Yeah I thought so too. It was a cool day so that helped. Once it gets warmer it will lose some power but overall very good numbers for the setup. The D1 is very good blower. Tuner says it will pull up to 3 degrees based on IATs and the AFR was flat 11.5:1 the whole way. I'm anxiously waiting for the weather to improve. I'm ready to surprise the arrogant coyote owners around my area.
Yes, dumped Super 44s. Actually not as loud inside the car as I was expecting. MAC LT, BBK H, Dumpers 44s.
bodyshot likes this.
post #48 of 51 Old April 13th, 2018, 09:44 AM
bodyshot's Avatar
I dumped mine after taking a good look at the way mine were welded in by the previous owner. After the dump my drone is almost non existent with the original 40 series. I think it all has to do with exhaust tip design. Mine are a straight shot with about a 30 degree cut end. The welded mufflers with stock tailpipes droned incredibly bad at around 2700 RPM.
What pump and injectors did you end up with? I maxed my Division X 340 out with 42lb green tops @ 448-410. Started to lean out at around 6200
bodyshot is offline
post #49 of 51 Old April 13th, 2018, 09:53 AM Thread Starter
My drone is gone too. Itís loud but not droney which is bearable.
I have a walbro tu229hp-2 which Iíve seen is either 255 or 290 and a vortech boost a pump. 60lb Siemens Deka injectors. Iím only at 70% duty cycle on the pump at 6300.
post #50 of 51 Old May 13th, 2018, 12:07 AM
blown 02's Avatar
I thought I had replied to your comment but my phone didn't post it I guess. I am keeping the stock proflow BOV for now to see how it does. If I need to upgrade I'll go to the Big Red BOV. Mine is vented to the atmosphere with a K&N Filter, right under the ABS module.
I wouldnt mind a nice loud jet sound. My brother had a very loud BOV on his 2013 ST, that was pretty cool.
What is the filter on the BOV for? it will be closed until air is forced out of it.
Some people are afraid of dirt or dust getting in there and messing up the maf meter or even the engine. I have been running the big red open for over five years now and had zero issues.
Spinning ain't Winning
blown 02 is offline
post #51 of 51 Old May 15th, 2018, 03:42 PM
Good numbers, mine made 377 @10psi with a 4inch pulley. I'm trying to see how I can break into the 400's
Mods: Procharger D1sc, 4'pulley, 3 core IC, DW300, 60lb inj, vmp 5000 MAF, Tial BOV, Accufab plenum/75 tb, Catted X Pipe, Magnapack CB, 3.73 Gears, Exedy Clutch, Nittos nt555g2. [email protected]
mustang562 is offline
