Transmission leak (pics) - Page 2 - Forums at Modded Mustangs
 1Likes
post #21 of 28 Old June 29th, 2018, 12:49 PM
bodyshot's Avatar
Originally Posted by Nightmare69 View Post
Thanks man! Iíll definitely give that a try.
Get it fixed?
bodyshot is offline
post #22 of 28 Old July 1st, 2018, 03:11 PM Thread Starter
All Homo All The Time
Nightmare69's Avatar
Originally Posted by bodyshot View Post
Get it fixed?
Haven't yet. Ill have an oil change done soon so Ill take a look at it then.
Nightmare69 is offline
post #23 of 28 Old July 3rd, 2018, 09:09 AM
ZEN357's Avatar
LMR carries the gasket.
ZEN357 is offline
post #24 of 28 Old July 4th, 2018, 04:42 PM Thread Starter
I pulled the crossmember and its not leaking anywhere above it. It has to be where 2 parts of the trans meet up and sealed with RTV as that is where it drips from. I don't see how to fix that without pulling the trans. I filled it back up, only took 1 pump of fluid so it doesn't leak bad.
post #25 of 28 Old July 6th, 2018, 03:00 PM
bodyshot's Avatar
Damn you donít see tail housing leaks to often.
Good luck man
bodyshot is offline
post #26 of 28 Old July 7th, 2018, 12:58 AM Thread Starter
Good luck man
Maybe I can convince the wife the only fix is to upgrade to a T56.
post #27 of 28 Old July 30th, 2018, 11:38 PM
Wade_GT's Avatar
I have the same problem with my TR3650. As another mentioned, your trans mount bushing is probably melted and needs to be replaced. I just have my trans fluid topped off around 1 time per year.
'01 Mustang GT 5M 138k miles
Drivetrain:
Steeda,Dragon,Accufab,SLP LMII,Magna X,Triax,3.73,PBR/Stoptech/Porterfield,Alum DS
Suspension:MM C/O F 350#,Griggs SFC,MM LCAs,FRPP UCA,MM PHB,Mach1 STB,Prothane SB Bushing,18X9 03 Cobra
Wade_GT is offline
post #28 of 28 Old August 8th, 2018, 11:57 AM Thread Starter
I replaced my transmission cross member. Mine was a bit worn but not in bad shape.
