01 Bullitt Tick/Knock - Forums at Modded Mustangs
post #1 of 12 Old March 24th, 2019, 02:07 AM Thread Starter
Hey guys, here is my built 2v with less then 500 miles on this combo. However the heads were used. Does this sound like a tick(top end) or a knock (bottum end). The noise will match rpms if revved. I checked all the adjusters and followers all were fine. I'm not sure what else to do. I'm really hoping I dont have to pull this engine out.
https://youtu.be/VENOo-UYDks
01Bullitt82 is offline
post #2 of 12 Old March 24th, 2019, 07:55 AM
First off I would not run this engine again. It's hard to tell from a video but to me it sounds like it could be coming from bottom end. I would drain the oil and cut open the filter and see if there is any metal shaving in the oil or filter.
02 roush turbo forged and built
mhs stage 3 heads cms 2.5 turbo cams
CG T6 hot side billet BW S478 with race cover
Dyno numbers coming
Sonic 02 is offline
post #3 of 12 Old March 24th, 2019, 01:13 PM
Have you tried pulling the spark plug wires when the engine runs and see if the knock/noise goes away on all the cylinders? Sounds pretty loud and consistent with the rpm.
3.8L Lincoln Locked MustangClutch burned
Now daily driving my 3.8L Auto Mustang
Mrvince is online now
post #4 of 12 Old March 24th, 2019, 01:30 PM
6 Cylinduh, Really Bruh?
TheOdessa's Avatar
How did you post this?!!! I keep getting a database error. WTF I cant post new threads
http://imageshack.com/a/img832/3492/odessadone.jpg
2001 Mustang GT Convertible - Black with Black Top - 5SPD
Bolt On Warrior - Everything done to my car:
https://www.moddedmustangs.com/forums...l#post11931130
TheOdessa is offline
post #5 of 12 Old March 24th, 2019, 06:28 PM
I get same error on new post
Dyno numbers coming
Sonic 02 is offline
post #6 of 12 Old March 25th, 2019, 08:06 AM
ZEN357's Avatar
Take the oil pan off and see what's going on with the bottom end. If nothing, then I'd replace the heads with a good set/newly rebuilt.
ZEN357 is offline
post #7 of 12 Old March 25th, 2019, 09:22 AM Thread Starter
Thanks for all the comments guys. I had trouble making the post at work but my phone let me post it just fine.
I did try unplugging the coil packs one at a time, no change. I also unplugged the fuel injectors one at a time, no change. I even pulled the Cam cover and pulled all the adjusters and followers and all seemed good. I really hope its not the bottom end.
post #8 of 12 Old March 26th, 2019, 07:57 AM
ZEN357's Avatar
Good luck! We are all hoping the best for your situation!!!!
ZEN357 is offline
post #9 of 12 Old March 26th, 2019, 10:47 AM Thread Starter
Thanks, I have someone coming to pick it up this week to try to diagnose it for me. I really just need someone with more experience then me to tell me if I need to pull the engine out. I just didn't want to do all the work to find out its something I could have fixed without pulling the engine.
post #10 of 12 Old March 27th, 2019, 08:22 AM
ZEN357's Avatar
Be there, done that!
ZEN357 is offline
post #11 of 12 Old April 17th, 2019, 11:56 AM Thread Starter
UPDATE: If anyone cares.lol The guy that was suppose to come pick the car up to diagnose it stood me up, so I started to taking everything apart. Since I'm going to pull the engine I of course started draining all the fluids. Including the oil. The oil really didn't have any metal shaving in it, maybe a flake or two that I saw but the oil filter was different story. The oil filter had a lot of metal in it. So I'm going to continue to pull it out so I can take it all apart and have a machine shop inspect everything. I should have it out this weekend. Really pains me to tear this whole thing apart that had less then 500 miles on it.
post #12 of 12 Old April 28th, 2019, 07:36 AM Thread Starter
I got the engine all torn apart. Looks like my crank is probably trash, due to this rod bearing. Not sure what caused this though. I thought I had to much crank end play, so I thought I was going to find some trashed thrust bearings but they looked good.
ID:	203607   Click image for larger version
