Hard lines on steering rack question - Forums at Modded Mustangs
post #1 of 2 Old May 20th, 2019, 04:41 AM Thread Starter
6 Cylinduh, Really Bruh?
TheOdessa's Avatar
Hey guys. So one of the hard lines on my steering rack is leaking. It's a hard line that is on the rack itself connecting the driver side connection to the valve body where the steering shaft connects to it. It's a AC Delco reman and it looks like in it's past life part of the hard line rubbed at a spot causing the metal to thin and now leak.
Short of going to a junk yard and getting a new hard line, is there another route to take? I was reading you can use steel braided hose. Any thoughts?
Sent from my SM-G920T1 using Tapatalk
EDIT: Here is the hardline I'm speaking of:
http://imageshack.com/a/img832/3492/odessadone.jpg
2001 Mustang GT Convertible - Black with Black Top - 5SPD
Bolt On Warrior - Everything done to my car:
https://www.moddedmustangs.com/forums...l#post11931130
TheOdessa is offline
post #2 of 2 Old May 20th, 2019, 04:06 PM
Troy McClure
WickedSnake00's Avatar
I don't think I'd use braided hose for that. However splicing in hard line or just replacing it with hard line wouldn't be tough. You can use brake line of the same diameter and a suitable high pressure type fitting (i.e. JIC, NOT compression)
WickedSnake00 is offline
