2013 Ford Taurus brake sticking - Forums at Modded Mustangs
post #1 of 7 Old February 13th, 2016, 02:13 PM Thread Starter
FBGM
I've had this car since November and today I noticed that when I came to a stop the rear of the car made a groaning sound. I could smell burning brakes and could feel my right rear wheel was very hot and for sure hotter than the rest of the wheels. Has anyone else had a problem on a ford and know how long it would take to replace. It looks like it's part of the caliper that holds the pads and because of corrosion it doesn't let the pad lift off the rotor so they are always dragging.
Saleen SuperCharged, C500 Side Exhaust, Cervinis Ram Air IV Hood, Hurst Short Throw Shifter, Chrome GT500 Replica wheels, GT500 Front Splitter ModBMR 1.25 Lowering Springs, ADJ Panhard Bar, CHE Torque Limiters and K Member Brace
kmac1622 is offline
post #2 of 7 Old February 13th, 2016, 05:16 PM
Pic would be nice but I think a good cleaning with a stiff wire brush or wheel should clean it up good enough to free it up. If it's the actual sliders that the ears of the pads are held I know I always get a new set included when I buy pads. Otherwise I think you would have to replace the caliper.
When mine started doing that it ended up that the internal ratcheting system for the e-brake was stuck. I ended up replacing the caliper, twice.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #3 of 7 Old February 13th, 2016, 07:11 PM
Dirt Dives Me Crazy
monkeygrits's Avatar
My parents 13 SHO did the same thing. I think it's a known issue that Ford doesn't wanna do anything about. The garage said they've had other cars with the same issue. Theirs were stuck and warped the factory rotors. They upgraded to powerstop carbon ceramic pads and their drilled/slotted rotors. Car stops on a dime now. It is a very noticeable difference. They haven't had the problem since. I pretty sure my dad checks where the caliper slides on the rear and cleans and greases it when they swap from winter to summer wheels twice a year as well.
https://www.moddedmustangs.com/forums/signaturepics/sigpic56003_1.gif
monkeygrits is offline
post #4 of 7 Old February 13th, 2016, 10:47 PM
Woodman's Avatar
Remove the calipers, LUBE the slide pins, if pads are worn down, replace.
woodman: achieving the impossible since 1967. 1973? 1980? 1985? 1976? whatever, you get my point
ford's advertising slogan was literally "you can pay for all of it today or you can go fuck yourself"
Woodman is offline
post #5 of 7 Old February 14th, 2016, 10:32 AM Thread Starter
FBGM
This is what I found. My calipers don't look like that at all in the video they look brand new, still completely silver and the areas where the clips are have no corrosion at all. I checked the pad thickness and theres still a lot of meat on them. I did double check to see if my E brake was off since Ive only used it once, I put it on and took it off. I then drove home and when I got home my rear rotors were completely cold after driving for 45 mins. I didn't take the wheel off since my dad said not to and that we would be taking it to the dealership on Monday. Ill try to get a picture of the caliper but it will be with the wheel on but Ill get several pictures from different angles of the caliper, rotor and pads.
kmac1622 is offline
post #6 of 7 Old February 15th, 2016, 03:54 PM Thread Starter
FBGM
I took it to the dealer and they couldn't find anything wrong so they are just gonna lube the slide pins up.
kmac1622 is offline
post #7 of 7 Old February 15th, 2016, 04:49 PM
DSMs are cool...
Mattdbal's Avatar
My dad's 2011 F150 had some weird break locking up problem..some pump was bad and they replaced like 2 calipers..
1973 Chevelle SS - 454...4300lbs hunting for 12's (13.1)
1993 Eagle Talon TSI: 5spd AWD Turbo. Fixing for DD fun
Mattdbal is offline
