8.8 explorer rear end? - Forums at Modded Mustangs
post #1 of 12 Old July 19th, 2013, 06:26 PM Thread Starter
I'm putting an Explorer rear in my in my 65 coupe my question is spring plates. Do they make a plate with the a shock mount with holes the proper size for the 3.25 axle tube u-bolt?
faztedyboochie is offline
post #2 of 12 Old July 19th, 2013, 08:40 PM
69coupe's Avatar
you can re-use your old one. I dont think you have to mod anything from what I've read but if you do I believe there are some places where you can buy them.
69coupe is offline
post #3 of 12 Old July 21st, 2013, 03:30 PM
66resto's Avatar
Double check the offset of your wheels.
A popular mod to the 8.8 is to remove the long axle and replace it with a short axle (have to cut down the tube to match). That centers the pumpkin and narrows the rear end just a little allowing you to tuck wheels that have less than optimum backspacing.
Good luck with the install.
Easy mod and worth doing the math to before you bolt it up.
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
66resto is offline
post #4 of 12 Old July 22nd, 2013, 04:30 PM Thread Starter
Thanks found a set of spring plates at Mustang Depot from TCP. I do have a wheel rite tool for getting the wheels correct. Resto the car is sweet brother! Thanks for the info boys.
post #5 of 12 Old July 22nd, 2013, 09:17 PM
66resto's Avatar
Thanks Faz, she's coming along finally.
Just so you know, if you do decide to go with two short axles, I am pretty sure it's 57" from surface to surface. I had one I bought that was already cut down and was going to install, but then then the 9" came along and I used that instead.
The explorer is a great swap. Just make sure to get the right year for the freebies. 3.73 gears, disc brakes, locker, 31 spline. And pretty reasonable.
66resto is offline
post #6 of 12 Old July 24th, 2013, 06:56 PM
What year is best??? I am thinking about doing this swap.
dwkresin is offline
post #7 of 12 Old July 24th, 2013, 11:22 PM
66resto's Avatar
In my head I was thinking '97 and up to? But it looks like '95 and up come with disc brakes, 31 spline and 3.73 gears. The one I owned had the tubes welded like in the link.
http://www.therangerstation.com/tech...plorer8_8.html
66resto is offline
post #8 of 12 Old July 25th, 2013, 12:33 AM
Thanks, My local pick and pull has a bunch of these and I got a friend who works there pulling one for me and hiding it inside. Figure $200 including gas for a read diff and a extra short shaft is fair. Best of all I wont get greasy or sweaty pulling it.
dwkresin is offline
post #9 of 12 Old July 25th, 2013, 05:11 AM
66resto's Avatar
Cost that much just for gears OR rear disc brakes. Nice score.
What brakes do you have up front? Probably going to need a Proportioning valve of some sort.
66resto is offline
post #10 of 12 Old July 25th, 2013, 08:29 AM
You had one job!
TCStang's Avatar
Be sure to take pictures and update us with everything you end up needing to do the swap. This looks like a pretty good option for an upgrade. Just to rebuild my 8 inch with new gears and trac-lock is around 1000.00
1968 Coupe- Sold
2007 Premium GT- Sold
MY CO BUILD
TCStang is offline
post #11 of 12 Old November 2nd, 2015, 10:34 PM
So, how'd the rear end swap work out? I'm doing the same in my 66 here next month and I'm still researching online to find any hidden terrors. Seems pretty straight forward but you never know.
jesse_gp_gt is offline
post #12 of 12 Old November 3rd, 2015, 05:11 PM
I make oil's Avatar
Mine is out of a 96
I make oil is offline
