Aftermarket headlights? - Forums at Modded Mustangs
post #1 of 14 Old June 26th, 2014, 10:39 PM Thread Starter
Loving My Mid Life Crisis
BLUECOLLAR's Avatar
Anybody have any experience with the aftermarket headlights sold on eBay? If they work good & LAST they would be a good upgrade.
<iframe width="420" height="315" src="//www.youtube.com/embed/M8mM2F96lr8" frameborder="0" allowfullscreen></iframe>
BLUECOLLAR is offline
post #2 of 14 Old June 26th, 2014, 10:59 PM
I'm Hella From Nor*Cal
707Stang's Avatar
Im running hella e code h4 conversions, i love them. Only diff is that the high low beam wires are switched. Dont bother me, i just left it. Ive had them for over a year and so far so good
---------- Post added at 08:59 PM ---------- Previous post was at 08:56 PM ----------
Hella 5 3/4" Round E Code H4 Halogen Replacement Headlight Kit with Hella 70/65W Osram Hyper Xenon H4 Bulbs:Amazon:Automotive
The Curse: 570 Holley, JBA shortys, Pertronix billet dizzy, Accel coil, 5.0 h.o, dynomax exhaust, SSBC, MSD, FRPP, currie....
707Stang is offline
post #3 of 14 Old June 26th, 2014, 11:04 PM
There are dozens of ebay options, some great, some not so great... You have to be careful. I love mine.
ajzride is offline
post #4 of 14 Old June 27th, 2014, 08:22 AM
Edgethis's Avatar
I have the tri-bar style lights that use H4 bulbs. Got them at CJs, I like em.
Edgethis is offline
post #5 of 14 Old June 27th, 2014, 09:15 AM
707Stang's Avatar
The problem with pre 69 headlights is that they are bigger than the 69-70 so options are stightly limited, since our cars cant get no respect. That is why i went with the hellas, plus theyre a glass housing as well.
707Stang is offline
post #6 of 14 Old June 27th, 2014, 09:56 AM
My car has the 5-3/4 lights which are typically only used in 69 mustangs (70's went back to 7"). I purchased mine on ebay, they use any H4 bulb you want. Make sure you find a light that advertises a glass lens (not plastic).
ajzride is offline
post #7 of 14 Old June 27th, 2014, 11:39 AM
707Stang's Avatar
thanks for reminding me of that. had a brain fart there for a second
707Stang is offline
post #8 of 14 Old June 28th, 2014, 10:44 PM
Ditto on the glass. Mine are eBay bought. I think in the $40 range and use a h4 bulb.
Patzstang is offline
post #9 of 14 Old October 18th, 2015, 11:15 AM
rittenrotton's Avatar
I have a 1970 mustang and want to upgrade my headlights as well. I've heard that the lighting difference between the H4 upgrade vs the stock bulbs isn't that great, is that true? Is the difference that noticeable? HAs anyone ever gone with the led headlight bulbs ( 01-1179-LED2 Mustang Delta Tech Headlight LED Pair 1965-1968/1970-1973 | CJ Pony Parts )?
rittenrotton is offline
post #10 of 14 Old October 18th, 2015, 12:49 PM
If you use a relay kit to ensure that your H4 lights get full alternator voltage, then they are a huge upgrade over stock lights. And a relay kit + H4 housing/bulbs runs under $100, those LEDs are $370. I'm sure the LED would be cool, but I'm not sure they are worth the dough. I know LEDs have come a long way, but in general they are betting for making you seen than letting you see. I'm not sure I would be willing to drop that much extra cash on something I wasn't sure was going to be a huge upgrade.
ajzride is offline
post #11 of 14 Old October 18th, 2015, 01:01 PM
Edgethis's Avatar
I have driven with LED headlights on alot of military vehicles. They work great, not sure how those compare the to ones CJPP has tho.
The H4 style lights will produce more light and draw less amperage then your stock 1970 bulbs. Make sure you get a glass lens housing as AJ mentioned and some good bulbs and a relay kit.
Edgethis is offline
post #12 of 14 Old October 19th, 2015, 08:35 AM
Ok, H4 headlights it will be! Thank you!
post #13 of 14 Old October 19th, 2015, 02:05 PM
I make oil's Avatar
I have JW Speaker LED's.
I make oil is offline
post #14 of 14 Old November 4th, 2015, 07:55 PM
i used a set of these and made the led my signal lights
5 3 4" H5006 H5001 Amber COB SMD LED Halo Angel Eye Halogen Light Bulb Headlight | eBay
newstang is offline
