Brake Light help - Forums at Modded Mustangs
post #1 of 8 Old August 15th, 2015, 09:12 AM Thread Starter
rittenrotton's Avatar
Brake Light help
I need some help troubleshooting a problem....my brake lights don't work. The tail lights turn on with the headlights and turn signals but don't light up when I step on the brakes. Any suggestions as why this could be happening or how I can fix this?
rittenrotton is offline
post #2 of 8 Old August 15th, 2015, 09:22 AM
There is a sensor attached to the brake pedal, check the output with a multimeter or test light while pushing the pedal down. If that works the problem is probably the turn signal switch. From the pedal The brake signals go through there to pick up blinky blinky before heading to the back.
ajzride is offline
post #3 of 8 Old August 15th, 2015, 09:37 AM Thread Starter
Ok, I'll try that. Thank you!
post #4 of 8 Old August 15th, 2015, 02:05 PM
Powered by LSx tears
69fastback's Avatar
My switch fell off a few weeks ago. Either way, it sounds like the switch is the problem.
I tell the truth. Deal with it.
69fastback is offline
post #5 of 8 Old October 24th, 2015, 05:53 PM Thread Starter
So unfortunately I'm having the issue again; replaced the fuse, brake light switch, flasher module but now all the lights work except emergency flashers and brake lights or one brake light/turn signal works (drivers side works but not the passenger side). Anyone have any ideas?
post #6 of 8 Old October 26th, 2015, 10:20 AM
You had one job!
TCStang's Avatar
Did you just replace your headlight switch? I think you mentioned that in the other thread. Make sure the wiring harness is fully connected to the headlight switch. If not you will get some issues.
1968 Coupe- Sold
2007 Premium GT- Sold
MY CO BUILD
TCStang is offline
post #7 of 8 Old November 12th, 2015, 11:10 AM Thread Starter
Turns out that the turn signal switch was bad as well as had a short in the rear passenger side taillight...
post #8 of 8 Old November 12th, 2015, 11:40 AM
You had one job!
TCStang's Avatar
Glad to see you got it all cleared up.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
