66 Mustang engine questions - Forums at Modded Mustangs
post #1 of 2 Old October 21st, 2015, 11:11 PM Thread Starter
stanger1944's Avatar
Okay, so I got a 66 Mustang project. It has no engine or transmission and needs much of the wiring as well as interior and gauges. I am looking at installing a 95 Mustang 5.0 ho engine and a C4 transmission. I am getting a 5.0 EFI harness from Summit Racing and will need a computer from a 89-93 5.0 Mustang. My question is will the 95 motor work with the fox body style wiring and computer. Will be using a clutch fan and my main concern is the distributor. Any advice would be appreciated.
2010 GT Track Pack Crew is the shhhhhh
stanger1944 is offline
post #2 of 2 Old October 22nd, 2015, 02:36 PM
Edgethis's Avatar
Yes you can make it all work. You will need to make sure the parts you get have the same connectors as the harness. You shouldn't have any issues for the most part. Make sure you get the ECU for a manual trans equuipped car, the C4 doesn't have any sensors.
Edgethis is offline
