1968 rust - Forums at Modded Mustangs
post #1 of 13 Old October 29th, 2015, 07:47 AM Thread Starter
1968 rust
Hey guys. I'm in the process of getting a 68 mustang was wondering how tough of a fix this is. I'll post the pic. I'm going to see the car Saturday but before I do I want to make sure it's fixable. He says it's the only part of the car that's bad and that, that hole doesn't lead to the trunk. Let me know thanks in advance.
Robert_Digi is offline
post #2 of 13 Old October 29th, 2015, 08:34 AM
That is not an easy fix. And sadly I doubt that is all there is to fix. As rotted as that looks, there will be more. Check the floorboards from underneath, check the bottom of the rear quarters, check the bottoms of the doors, check the cowl (up under the dash). Also it looks like that car has a vinyl roof, you can almost bet half of the metal under that vinyl looks like the hole on the back deck. I hate to rain on a parade, I just don't want to see you get yourself in over your head and find that you need to spend thousands on metal work.
ajzride is offline
post #3 of 13 Old October 29th, 2015, 10:58 AM
Edgethis's Avatar
Everything is 'fixable" its only a matter of cost or time/skill. Don't be afraid of rust, just be sure you think about the potential issues you may have to fix because of it. These cars aren't getting any easier to find, if thats the biggest issue you have to deal with then you're doing ok.
Be sure to check the cowl as AJ mentioned, thats the bad spot.
Edgethis is offline
post #4 of 13 Old October 29th, 2015, 05:46 PM Thread Starter
Sounds good I guess i pass on it. It's the only original v8 car for a decent price. I'm going to look into some 6 cylinders then they are a bit cheaper. Planning on taking engine out and putting a 351c in there.
post #5 of 13 Old October 29th, 2015, 10:57 PM
Be careful with that as well. A six to eight swap can run almost 3K over the cost of the engine. You have to upgrade the entire suspension system, brakes, fuel system etc. I'm not saying it can't be done, just be careful.
ajzride is offline
post #6 of 13 Old October 30th, 2015, 09:57 AM
nkausch's Avatar
I've seen people basically replace an entire car before so you can fix rust it just takes time and money. Can't see the picture so I can't comment further
94 GT Vert
<a href="https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html"]https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html">70mm Turbo Build</A>
nkausch is offline
post #7 of 13 Old October 30th, 2015, 05:09 PM
DEC '12 ROTM CO-Winner
Blue67coupe's Avatar
I haven't been on in forever, hey guys. But it's true rust does suck and is a pain but all is fixable. I need to tackle my floor board since it is horrible. All caused by the leaking cowl as stated by other it leaked into the car over the years and sat on the floor board. If you need a temp. fix for this until you can get it done they sell cowl covers which is what I run and have never had an issue with it.
67 Coupe
03 Roush: sold
02 Roush 360R
Blue67coupe is offline
post #8 of 13 Old October 30th, 2015, 11:31 PM Thread Starter
Damn California is not a good state for these cars now days. So here's what the rest of the car looks like
ID:	169122   Click image for larger version
ID:	169130   Click image for larger version
post #9 of 13 Old October 31st, 2015, 12:00 AM
Edgethis's Avatar
That looks nice, but you really wanna look at the floor boards and in the cowl vents. If its not too far away, its always worth stopping by and actually get on the ground and look at the underside. Especially right where your feet/legs would be in the car.
Edgethis is offline
post #10 of 13 Old October 31st, 2015, 12:04 AM Thread Starter
Yes I am close to it about a 30 minute drive. I'm planning on doing all of that. Like I said it's the only running 8 cylinder out here in California for a decent price. If you say that spot behind the rear window is fixable then hopefully I can get a good deal on it.
post #11 of 13 Old October 31st, 2015, 12:07 AM
Edgethis's Avatar
Anything is fixable, but that hole goes somewhere, so be sure to look real well in the trunk, Hell, ask them to pull the rear seat (its only 2 bolts) to make sure nothing crazy is hiding behind it.
Edgethis is offline
post #12 of 13 Old October 31st, 2015, 12:16 AM
+1 the whole rear seat can be out in a no time at all. Definitely worth it to check back there.
67 Coupe
03 Roush: sold
02 Roush 360R
post #13 of 13 Old October 31st, 2015, 12:16 AM Thread Starter
That's very good advice I wouldn't have thought of that. I'll make sure to get a close look at everything. I'll update to see if I purchased it or not.
