Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg - Forums at Modded Mustangs
post #1 of 63 Old February 21st, 2012, 09:13 AM Thread Starter
rktsci25's Avatar
My mustang has seen a lot of changes in the past 3 years I have owned it. It was an auto, then had a t-56, now has a t-56 magnum (I didn't like the gearing of the original 56). It's been vortech'ed for quite awhile now, and it's starting to get a bit boring, and I want to change it up a bit.
So it's time for a coyote swap! I opted for the low compression (.5:1 version, as I do plan on putting a TVS on it later. I am shooting for 440 rwhp, and 30mpg. I got 25 with the blower, and will have lower gearing and less weight than a new gt, so we shall see how that turns out. The sleeper effect is just the icing on the cake in my opinion. I'm really hoping it turns out sounding "somewhat" like a 2V with cold air and long tubes.
Current parts list includes:
9.5:1 compression 5.0 Coyote, designed for s/c applications
new wiring harness from ford racing
BBK coyote swap long tube headers
S&R performance alternator, and power steering relocation brackets
Steeda Battery Relocation kit
Custom aluminum coolant tank for where the battery used to be
UPR Tubular K-Member
I know that I need to convert to a return style fuel system, but am not all that familiar with the system, perhaps somebody could provide a bit of input there. I found the stuff for switching on a regular 2V, but am not sure what is no longer needed when dropping in an engine designed for the system and a paired ECU.
I am doing the work myself, with the help of a few friends who are a bit more knowledgeable than I, and some guidance and tips from my boss. I've already taken the majority of the blower components off, and the car is looking really sad right now.
I am somewhat going off of the "write up" that s&r put up on here awhile ago swapping into an 01 bullit. Though I am moving the battery and the ecu slightly and trying to maintain my fenderwell CAI.
For some reason I am having trouble uploading pictures to this. So below are the links.
The Old
The New Front
The New Back
Current State
rktsci25 is offline
post #2 of 63 Old February 21st, 2012, 11:29 AM
nkausch's Avatar
Wow 440 rwhp and 30 mpg would be awesome.
I'll deffinately be following this. Good luck!
94 GT Vert
<a href="https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html"]https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html">70mm Turbo Build</A>
nkausch is offline
post #3 of 63 Old February 23rd, 2012, 01:00 PM Thread Starter
rktsci25's Avatar
Thanks. It's going to be a process, though it'll be worth it. I mean can you really argue with 440 and 30mpg. I'm in the process of trying to figure out all the requirements and parts required to switch to a return style system. Then it's assembly time. The engine and old k-member should be coming out this weekend, and the battery relocation going in.
Hopefully my trolling for fuel parts works well, and I can get that system in by next weekend.
rktsci25 is offline
post #4 of 63 Old February 23rd, 2012, 01:27 PM
I love to skydive
Durr4456's Avatar
Interesting. But why the coyote. Why not just build the bottom end?
That mobile device thingy
MM is awful. Don't ever come here if you haven't been sucked in already!
Durr4456 is offline
post #5 of 63 Old February 23rd, 2012, 01:37 PM Thread Starter
rktsci25's Avatar
Multitude of reasons:
-Trickflow is the only company that makes aftermarket heads for 2V's
-I want to TVS it eventually (next year or so)
-I wanted something semi-original
-The people I get my parts through don't have 99-04 parts anymore. So, to make better use of my contacts, I went with the new motor, as they have more products for those. Paying msrp for things is overrated.
I thought about a termi swap, but it came down to a lot of the same reasons, and now I have a brand new motor complete with warranty and all. Sure, it will be more work, but I think it will be worth it.
rktsci25 is offline
post #6 of 63 Old February 23rd, 2012, 01:43 PM
I love to skydive
Durr4456's Avatar
But the coyote motors are pike 7k aren't they?
Durr4456 is offline
post #7 of 63 Old February 23rd, 2012, 01:57 PM Thread Starter
rktsci25's Avatar
The regular ones were something around there, the lower compression ones were a bit more. But those numbers are msrp, and not what I paid for them...
rktsci25 is offline
post #8 of 63 Old February 23rd, 2012, 02:02 PM Thread Starter
rktsci25's Avatar
We are also running the work car in Belle Rose on 3/24. I will be bringing my mustang up as well. No doubts plans can be made to see the final product.
Coyote swapped 01 Mustang GT-
03 Lariat- stock, tows the afore mentioned mustang
Work vehicle:
It needs an aircraft carrier.
rktsci25 is offline
post #9 of 63 Old February 23rd, 2012, 02:34 PM
I love to skydive
Durr4456's Avatar
What did yours cost you?
Durr4456 is offline
post #10 of 63 Old February 23rd, 2012, 03:25 PM Thread Starter
rktsci25's Avatar
I paid 8 flat after tax and shipping. Jegs has the engine right now for 7400+tax, and the harness is listed as $1800 before tax and shipping on the 2012 ford racing catalog.
part numbers:
m-6007-a50sc (engine)
m-6017-a504v (harness)
Work vehicle:
rktsci25 is offline
post #11 of 63 Old February 23rd, 2012, 03:29 PM
Wanna be show worthy.
B's04gt's Avatar
Badass man!
I want to see pictures along the way!
i love Uranus
B's04gt is offline
post #12 of 63 Old February 23rd, 2012, 05:32 PM
Certified Bwaloligisit
Mach Stang!'s Avatar
this is Awesome! i love the idea of the new 5.0 in a new edge. never seen it done before.
-Rocco
Mach Stang! is offline
post #13 of 63 Old February 23rd, 2012, 08:02 PM Thread Starter
rktsci25's Avatar
If you look about 9 months ago on here there is one from s&r performance that was put into an 01 bullit. I'm doing one slightly different but you can see how much it fills up the bay.
Sent from my ADR6300 using AutoGuide.com App
Work vehicle:
rktsci25 is offline
post #14 of 63 Old February 23rd, 2012, 09:34 PM
Full Frontal Nudity
bullitt1680's Avatar
http://www.mustang50magazine.com/fea...ber/index.html
MM BRONY CLUB
Mostly Gone But Never Forgotten
bullitt1680 is offline
post #15 of 63 Old February 23rd, 2012, 09:35 PM
Full Frontal Nudity
MM BRONY CLUB
post #16 of 63 Old February 23rd, 2012, 09:37 PM
PapaSmurf's Avatar
iTrader: 13 reviews
this thread delivers
315hp/300tq
Full Boltons, MHS Stage 3R cams, Stage 2 Heads, Built rear/4.30 gears
Sonic Blue Crew
PapaSmurf is offline
post #17 of 63 Old February 24th, 2012, 01:17 AM
that is sick! where did you order your engine from??
Kenshin1393 is offline
post #18 of 63 Old February 24th, 2012, 12:17 PM Thread Starter
rktsci25's Avatar
My boss has some fantastic contacts in the racing industry with companies like steeda, rpp, chassis shop. That's what has made this swap feasibile.
Work vehicle:
rktsci25 is offline
post #19 of 63 Old February 24th, 2012, 08:30 PM
Your Resident Badass
I want to swap a 5.0 into mine as well, maybe down the road.
Former Hellion 2013 GT Owner
Houston Crew
mikeyfitz is offline
post #20 of 63 Old February 24th, 2012, 08:55 PM
I love to skydive
Durr4456's Avatar
Yeah when they've been mass produced for years and are everywhere!
Durr4456 is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251086-rktsci25s-01-gt-coyote-swap-440rwhp-30-mpg.html
99-04 Coyote Swap - Mustang Evolution This thread Refback November 12th, 2016 06:48 PM
2001 Ford Mustang GT Coyote Build by rktsci25 This thread Refback July 4th, 2015 12:46 AM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback April 1st, 2015 06:31 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback January 8th, 2015 10:16 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback January 2nd, 2015 11:04 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback December 14th, 2014 12:02 AM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback November 10th, 2014 11:23 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback November 6th, 2014 03:53 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback April 10th, 2014 12:26 AM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback April 5th, 2014 07:42 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback March 17th, 2014 01:12 AM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback February 23rd, 2014 08:43 PM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback January 24th, 2014 09:36 AM
Coyotify Forums ? View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback December 28th, 2013 02:33 PM
Coyotify Forums &bull; View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback November 23rd, 2013 04:21 PM
Coyotify Forums &bull; View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback October 28th, 2013 02:37 AM
Coyotify Forums &bull; View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback October 7th, 2013 03:28 PM
Coyotify Forums &bull; View topic - Rktsci25's 01 GT Coyote Swap 440rwhp, 30 mpg This thread Refback November 29th, 2012 03:01 PM
