Boom's 68 Restomod - Page 2 - Forums at Modded Mustangs
post #21 of 991 Old March 12th, 2012, 07:14 AM Thread Starter
Edgethis's Avatar
I started with4 0 grit on my orbital sander then moved up to 220 and smoothed out the swirled by hand. Then I coated it with high temp engine spray paint. Semi gloss black. I originally used Rustoleum on the other side but it takes forever to dry.
Edgethis is offline
post #22 of 991 Old March 12th, 2012, 11:17 AM Thread Starter
Edgethis's Avatar
Score! I just won a new fuel pump for the car. A polished Edelbrock Performer pump. I want to get things ready for when I finally get a new intake and carb. I'll post some pics as soon as it arrives.
Edgethis is offline
post #23 of 991 Old March 15th, 2012, 04:50 PM Thread Starter
Edgethis's Avatar
Santa came by the house!!
My new CSRP brake disc brake and power brake set-up. Along with my Edelbrock fuel pump.
2012-03-15_15-56-18_765.jpg by Edgethis, on Flickr
2012-03-15_16-29-24_751.jpg by Edgethis, on Flickr
2012-03-15_16-29-17_781.jpg by Edgethis, on Flickr
2012-03-15_16-28-54_222.jpg by Edgethis, on Flickr
Edgethis is offline
post #24 of 991 Old March 15th, 2012, 06:05 PM Thread Starter
Edgethis's Avatar
I plan to get everything ready and hopefully be able to install the entire brake set-up next weekend. I am going to wait on the fuel pump install until I get a 4 bbl intake and carb.
Edgethis is offline
post #25 of 991 Old March 20th, 2012, 08:59 PM Thread Starter
Edgethis's Avatar
Got the new dash pad and trim piece for the cluster today. Hopefully ill be able to do that install here this week if I can find a replacement for my coolant gauge. Pics to follow!
Edgethis is offline
post #26 of 991 Old March 23rd, 2012, 09:28 AM Thread Starter
Edgethis's Avatar
Got new fittings for teh fuel pump. I'm going to upgrade the fuel line to 3/8" fromt eh pump to the carb. I plan to start doing that and begine tearing the brakes down here this afternoon. I will takes plenty of pics for everyone's veiwing pleasure.
Edgethis is offline
post #27 of 991 Old March 23rd, 2012, 01:18 PM Thread Starter
Edgethis's Avatar
OK I got started a bit earlier then planned. So far everything is going great for the brake swap. Once you pop both wheels off, theres only a 27mm spindle nut, 4 9/16" backing plates bolts and a 11mm brake line fitting and the whole assembly pops right off.
Here's the car on stands:
2012-03-23_12-31-31_850.jpg by Edgethis, on Flickr
Heres the old drum brakes:
2012-03-23_12-31-43_586.jpg by Edgethis, on Flickr
Here's the spindle with the brakes removed:
2012-03-23_13-13-26_665.jpg by Edgethis, on Flickr
I think i'll clean it off a bit beofre I install the disc set-up.
Edgethis is offline
post #28 of 991 Old March 23rd, 2012, 03:22 PM Thread Starter
Edgethis's Avatar
A bit more progress. After cleaning off the spindle a bit I mounted the new caliper bracket and dust shield.
2012-03-23_13-45-42_875.jpg by Edgethis, on Flickr
Greased up teh bearings and slid the rotor on. I thought they went the other way but CSRP shows this way.
2012-03-23_14-24-32_637.jpg by Edgethis, on Flickr
Got the caliper and pads on. Only had a bit of trouble with the cross-over tube needing massaged to go on right. Dang it looks so much better then those crap drums.
2012-03-23_15-15-13_606.jpg by Edgethis, on Flickr
Edgethis is offline
post #29 of 991 Old March 24th, 2012, 06:27 PM Thread Starter
Edgethis's Avatar
Heres a shot of the discs all done on both sides:
2012-03-23_18-24-56_860.jpg by Edgethis, on Flickr
I got the bracket mounted for the booster and new master cylinder.
2012-03-24_09-34-48_93.jpg by Edgethis, on Flickr
There was not very much room at all once this was all mounted. I made the lines and have everything for the front plumbed up. I need to add a prop valve for the rear, that'll be tomorrows project.
2012-03-24_14-02-57_49.jpg by Edgethis, on Flickr
I also got a sweet new air cleaner to replace the old factory set-up. I grab a picture of that soon.
Edgethis is offline
post #30 of 991 Old March 25th, 2012, 03:10 PM Thread Starter
Edgethis's Avatar
I bled the front brakes and had to fix the vacuum line as the factory tree wouldn't fit the hose without another fitting. I decided to wait to add the prop valve since I would like to redo the rear shoes and pads. I also got a new line for the rear frame to axle. I am going to mount the adjustable prop valve back above the rear axle. Not sure if anyone has tried that but looks like it'll fit and I don't see any reason it wouldn't be a good spot.
Anyway even without the rear brakes the car stops so much better then with the manual drums all around.
Edgethis is offline
post #31 of 991 Old March 25th, 2012, 04:01 PM
green67stang's Avatar
That CSRP kit looks really good. Were you satisfied with the quality of the parts? I plan on doing the front disc/power setup when I swap out my axle.
green67stang is offline
post #32 of 991 Old March 25th, 2012, 05:09 PM Thread Starter
Edgethis's Avatar
Everything was top notch. Everything bolted on just fine and the kit came with braided stainless lines for the wheels. Only thing I had to fab was the lines from the new master cylinder to the distribution block. My local advance had lines in stock complete with fittings already flared. I just had to bend them into shape. I haven't found any reason yet to say anything but great things about CSRP.
Edgethis is offline
post #33 of 991 Old March 28th, 2012, 06:08 PM Thread Starter
Edgethis's Avatar
Got a few new parts to show you guys. I got a nice deal on a sweet new air cleaner. This is an Edelbrock Elite series cleaner the I picked up for about $70 new.
2012-03-28_16-59-21_343.jpg by Edgethis, on Flickr
I finally got around to installing my new fuel pump. I replaced the fuel lines and filter at the same time.
2012-03-28_16-59-36_907.jpg by Edgethis, on Flickr
Here are a few parts that just came in for CJs Pony Parts. A new battery trya and a handle for my parking brake.
2012-03-28_17-21-07_260.jpg by Edgethis, on Flickr
The car does seems to have alot more pickup now with the air cleaner. i think the factory housing was too restrictive. I also had to shorten my throttle return spring because the throttle wouldn't close all the way and I'd have to lift the pedal with my foot. It feels a bit stiff now but it snaps back nice and quick, so I'm happy with that. I've been having a similar issue with my brake pedal. I found out the master was loose on the booster so I tightened that up and got a better fitting for the vacuum tree. Those seemed to help alot but I need to get a vacuum gauge and see if maybe my engine just inst putting out enough vacuum.
Till next time guys!
Edgethis is offline
post #34 of 991 Old March 29th, 2012, 10:33 PM Thread Starter
Edgethis's Avatar
Replaced my starter tonight. Found out my flywheel isn't in the best shape tho . I did find out that my engine is a 72, so that pretty much confirms it as a 302 and not the 289. I found one of my plug wires was broke so that would probably explain why the performance seems a bit lacking. So a good tune-up here tomorrow and it should be running great.
Edgethis is offline
post #35 of 991 Old March 29th, 2012, 11:19 PM
Carving corners
MineralGreyGT's Avatar
iTrader: 18 reviews
Nice ride man.
Follow me on Instagram! Username:whistles._
https://www.instagram.com/whistles._/
MineralGreyGT is offline
post #36 of 991 Old March 30th, 2012, 07:41 AM Thread Starter
Edgethis's Avatar
Thanks man! I've got alot of plans for this car.
Edgethis is offline
post #37 of 991 Old March 30th, 2012, 04:32 PM Thread Starter
Edgethis's Avatar
I got new wires and a new coil. I tried the MSD 8202 but it wouldn't fit with the wires so I took it back and got a stock replacement. I also put a new trans filter on, the internals looked great on the trans but the bottom of the pan had a thin layer of slimey almost metallic tinted gel so I may still look into a quality rebuild.
I am looking into upgrading from the points system to a set-up like what Pertronix offers. Supposed to perform better and less maintenance. I could notice an improvement right away with the parts I did change. I plan to get my new exhaust put together next week.
Edgethis is offline
post #38 of 991 Old March 31st, 2012, 08:10 PM Thread Starter
Edgethis's Avatar
Ok, di some interior work today. The plan was to install the new dash pad. Here's what I started out with:
2012-03-31_15-18-57_705.jpg by Edgethis, on Flickr
The pad was a pain to get out because it seemed like it was glued to the dash, but it finally came out and I cleaned up the frame a bit.
2012-03-31_15-41-09_252.jpg by Edgethis, on Flickr
The new dash pad looks great but it did require trimming in a few spots to fit right, mainly at the back corners. I also installed the dash trim and am currently putting the cluster together. Decided to replace all the bulbs while I had the cluster out.
Anyway heres a pic of the dash as it sits currently.
2012-03-31_17-28-34_773.jpg by Edgethis, on Flickr
I think it looks alot better then the old cracked dash. All my parts came from CJs Pony Parts with their 20% off sales.
Edgethis is offline
post #39 of 991 Old April 2nd, 2012, 01:56 PM Thread Starter
Edgethis's Avatar
I got my exhaust done today. I had all new pipes from the headers back. Had them put an H crossover too. I went with Magnaflow and it sounds great. I'll try to post a video shortly.
Heres a picture of my new dash cluster. I didn't have the new lenses in from CJs yet. I hate that steering wheel, I plan to replace it.
2012-04-02_13-53-50_431.jpg by Edgethis, on Flickr
Edgethis is offline
post #40 of 991 Old April 2nd, 2012, 10:32 PM
Car is looking great. That new dash pad did wonders for the interior!
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251801-booms-68-restomod.html
Doors make 2 different shutting noises - Vintage Mustang Forums This thread Refback April 22nd, 2018 10:44 PM
67-68 parts - Vintage Mustang Forums This thread Refback April 18th, 2018 10:22 PM
New FITECH EFI Tank - Vintage Mustang Forums This thread Refback April 9th, 2018 01:04 AM
Which T5, T5z shifter - feedback, Pro 5.0, Tri-Ax, MGW, UPR in VM's? - Vintage Mustang Forums This thread Refback March 16th, 2018 12:12 PM
The Great EFI Debate - Vintage Mustang Forums This thread Refback February 3rd, 2018 12:04 AM
FI Tech EFI - Page 8 - Vintage Mustang Forums This thread Refback January 30th, 2018 04:40 PM
68 Coupe Pro Touring Build Pic Heavy - Page 2 - Vintage Mustang Forums This thread Refback January 17th, 2018 02:10 AM
Novi 2000 conversion complete - Vintage Mustang Forums This thread Refback January 15th, 2018 05:02 PM
What brakes to use? - Vintage Mustang Forums This thread Refback January 3rd, 2018 10:59 PM
LED Headlights with DRL - Vintage Mustang Forums This thread Refback December 29th, 2017 04:55 PM
GT500 Brembo brakes on 68 Mustang - Vintage Mustang Forums This thread Refback December 20th, 2017 01:23 AM
Coyote - Now I get it - Vintage Mustang Forums This thread Refback November 28th, 2017 09:04 PM
8" rear axle from 68 complete - Vintage Mustang Forums This thread Refback October 12th, 2017 09:01 PM
Hello! - Vintage Mustang Forums This thread Refback September 30th, 2017 10:30 AM
Anyone using the Holley Sniper EFI yet? - Page 2 - Vintage Mustang Forums This thread Refback August 30th, 2017 10:35 PM
1967 coup GW coil over instructions - Vintage Mustang Forums This thread Refback August 28th, 2017 04:13 PM
RIP Jerry Lewis - Vintage Mustang Forums This thread Refback August 26th, 2017 11:05 AM
craigslist alert for 69 fastback finally hit after 3 years lol - Vintage Mustang Forums This thread Refback August 24th, 2017 04:53 PM
Repro door hinge plate issue - Vintage Mustang Forums This thread Refback August 12th, 2017 01:41 PM
Fox Coilovers Front & Rear? - Vintage Mustang Forums This thread Refback August 7th, 2017 07:51 AM
Adding a cam to 1968 stock 302 - Vintage Mustang Forums This thread Refback August 1st, 2017 03:50 PM
289 efi kits - Vintage Mustang Forums This thread Refback July 22nd, 2017 12:51 AM
1968 Ford Mustang Restomod Muscle Car Build by Edgethis This thread Refback July 19th, 2017 10:31 AM
Questions regarding USS Fitzgerald - Vintage Mustang Forums This thread Refback July 18th, 2017 08:42 PM
FiTech EFI tuning - Vintage Mustang Forums This thread Refback July 13th, 2017 02:26 AM
THINKING of selling my fitech system - Vintage Mustang Forums This thread Refback July 13th, 2017 01:26 AM
'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums This thread Refback July 10th, 2017 08:11 PM
Just ordered the new TMI Full Length Center Console. Can't wait! Looks gorgeous! - Vintage Mustang Forums This thread Refback July 3rd, 2017 07:07 PM
Law of Armed Conflict Question - Navy - Vintage Mustang Forums This thread Refback June 28th, 2017 01:32 AM
Borgeson PS conversion box and pump - Vintage Mustang Forums This thread Refback June 4th, 2017 01:35 AM
Vintage Venom out of business? - Vintage Mustang Forums This thread Refback June 3rd, 2017 07:39 PM
does anyone have the global west adjustable monte carlo bar? - Vintage Mustang Forums This thread Refback June 1st, 2017 08:08 PM
What did you do to/for your Mustang today? - Page 122 - Vintage Mustang Forums This thread Refback May 12th, 2017 01:20 PM
Help ... Ignition or Fuel related - Vintage Mustang Forums This thread Refback April 20th, 2017 07:21 PM
At a loss for words on this one - Vintage Mustang Forums This thread Refback April 19th, 2017 09:19 AM
Front Suspention Recommendations for 67-68 - Vintage Mustang Forums This thread Refback April 16th, 2017 10:08 PM
69 mustang with 6R80 tranny/ Driveshaft? - Vintage Mustang Forums This thread Refback April 16th, 2017 06:57 PM
Thumbs up to MSD Service. - Vintage Mustang Forums This thread Refback April 13th, 2017 10:15 AM
'65 Front brakes - bigger rotors or better pads? - Vintage Mustang Forums This thread Refback April 12th, 2017 01:06 PM
What did you do to/for your Mustang today? - Page 116 - Vintage Mustang Forums This thread Refback April 11th, 2017 09:15 AM
About to set this car on fire - Vintage Mustang Forums This thread Refback March 29th, 2017 02:43 PM
What did you do to/for your Mustang today? - Page 114 - Vintage Mustang Forums This thread Refback March 22nd, 2017 08:34 AM
MTF One Piece Headliner Install - Vintage Mustang Forums This thread Refback January 29th, 2017 11:08 AM
Front drums off a 68, freshly rebuilt - Vintage Mustang Forums This thread Refback December 25th, 2016 09:51 AM
1968 Grabber Blue V8 4spd coupe - Vintage Mustang Forums This thread Refback December 23rd, 2016 02:54 PM
My 1968 Coupe trans-am tribute project - Page 14 - Vintage Mustang Forums This thread Refback December 14th, 2016 11:36 AM
Fuel Pressure Regulator - Vintage Mustang Forums This thread Refback December 13th, 2016 01:04 AM
671 blower - Vintage Mustang Forums This thread Refback December 12th, 2016 10:07 AM
SAVE 10% on Street or Track products! - Page 5 - Vintage Mustang Forums This thread Refback December 1st, 2016 11:48 AM
Where to look for your first classic? - Vintage Mustang Forums This thread Refback November 24th, 2016 08:04 PM
