Boom's 68 Restomod - Page 3 - Forums at Modded Mustangs
post #41 of 991 Old April 2nd, 2012, 10:52 PM Thread Starter
Edgethis's Avatar
Thanks! I love how much better it looks. Unfortunately my points decided to take a crap on me tonight. I've tried replacing the points and condenser without luck. I decided to go ahead and orders Pertronix kit to be done with the points. Everyone seems to like them and say that its a new car after the install. Just gotta wait tho as they're on backorder.
Edgethis is offline
post #42 of 991 Old April 5th, 2012, 05:05 PM Thread Starter
Edgethis's Avatar
New lenses came in for the dash. Gonna wait till the weather gets a bit better to put them in. I also got a new thermostat and gasket. Replaced the rad cap with one with a built in temp gauge because my dash temp gauge isn't working.
Edgethis is offline
post #43 of 991 Old April 10th, 2012, 03:41 PM Thread Starter
Edgethis's Avatar
Got my new Flame thrower coil, hopefully the mailman brings my ignitor today!
My local Advance originally gave me the 0.6 ohm Flamethrower 2 since they had it on the shelf. Luckily I wasn't sure and read the instrusctions, they are NOT compatible with the orignal Ignitor. So they easily took the 2 model back and had the proper one for me the next day.
Edgethis is offline
post #44 of 991 Old April 12th, 2012, 04:01 PM
mustanggarage's Avatar
looks like you are doing some great work here. one bit of advice. make sure you read the instructions well on the ignitor. I don't know about the 68 wiring harness or what ignitor you ordered, but the 65 wiring harness with the original ignitor requires a true 12 volts. In the 65 there is a pink resistor wire in the harness that has to be bypassed or it won't run right.
It sounds like your parts store is helping you out. I had a lot of problems with my ignitor when I swapped to the new flamethrower coil, it kept burning the tips of my rotor. I finally ended up replacing the whole thing with an MSD unit, I realize I just had the wrong coil for my application after I got sick of it and ordered the msd digital e-curve.
anyway cool project. I have a 67 that I am building for my daughter and I am just about done with it. I look forward to following your progress.
89 Fox convertible https://www.moddedmustangs.com/forums...y-new-toy.html
67 for my daughterhttps://www.moddedmustangs.com/forums...pic-heavy.html
I also have a supercharged 65 65 myway
mustanggarage is offline
post #45 of 991 Old April 13th, 2012, 02:44 PM Thread Starter
Edgethis's Avatar
Good news! I got the new Pertronix ignition installed today. Car runs alot smoother. However I was puzzled when the instructions told me NOT to bypass any resistor in the stock system. Everywhere I read say to bypass that wire/resistor to run a full 12V....anyone else seen this?
Edgethis is offline
post #46 of 991 Old April 14th, 2012, 05:29 PM Thread Starter
Edgethis's Avatar
Cleaned up some wiring tonight. Had to run a new coil wire because the old one was cracked and u shortened the oil pressure wire because it was way too long and just looped and taped :/ .
Edgethis is offline
post #47 of 991 Old April 14th, 2012, 09:26 PM
well glad everything is working for you. and as far as bypassing the resistor wire, maybe they have fixed that problem since I installed mine many years ago. I have heard that the resistor wire will cause intermittent failures though, but hopefully that will not be an issue for you. keep posting up the pictures so we can vicariously enjoy your restoration.
post #48 of 991 Old April 15th, 2012, 08:52 AM Thread Starter
Edgethis's Avatar
Thanks! I was unsure at first but the instructions listed install for both with and without a resistor wire. We'll see how it goes *fingers crossed*
As I mentioned yesterday I cleaned up some wiring. Its hard to see in this pic, but this is what I started with:
2012-04-14_15-11-10_400.jpg by Edgethis, on Flickr
The after picture will come once I'm done wiring up the tach, I also hate that I had to use blue wire loom...I wanted black to be subtle but it was either red or blue. Though if my neighbor with the Honda is right it should add to my aerodynamics...
I plan to swap to a nice 4 bbl intake and carb here soon so please excuse the grime covered intake...It has like 5 layers of different paint.
I also went ahead and got a Tachometer. I hated not knowing where my RPMs were. So I snagged this one from my local Advance for about $40 (Sun-Pro) , I already had a number of holes along the lower dash so I figured it was as good a spot as any, since I just redid the dash, why hide it with a giant tach on the column?
2012-04-15_08-38-28_555.jpg by Edgethis, on Flickr
I still have to finish up the wiring, all I need to do is wire up the light actually. I couldn't find a fuse or a good spot to tie it into before it started getting dark. But the Tach works just fine with my Pertronix, I was a bit worried at first after reading issues with Autometer tachs and Pertronix.
And heres a shot I took of the car this morning. I had cleaned it off a bit yesterday since it was well into the 70's after a week of 40's.
2012-04-15_08-39-10_679.jpg by Edgethis, on Flickr
Edgethis is offline
post #49 of 991 Old April 20th, 2012, 10:20 AM Thread Starter
Edgethis's Avatar
I got an Edelbrock performer intake on the way. I got a good deal and picked one off Ebay. I'll snap some pics once I get it and clean it up real good. I am looking at going with an Edelbrock 1406, 600cfm carb w/ electric choke. I think that will be a great boost in performance for the car.
Edgethis is offline
post #50 of 991 Old April 22nd, 2012, 10:56 PM
Dang that car just looks tuff. I love it.
post #51 of 991 Old April 24th, 2012, 07:08 PM Thread Starter
Edgethis's Avatar
Thanks Buddy!
Update: I am getting a great deal on an Explorer motor so I plan to get that motor and strip the excess (smog) crap off put it in my 68. My current engine has a tapping/knocking sound so I figure i'll swap for this with a roller cam.
After my vacation here to Afghanistan I plan to have the 5.0 rebuilt new cam and add fuel injection to the 68.
Here's a link to my thread on this conversion
Boom's explorer swap thread
Edgethis is offline
post #52 of 991 Old April 24th, 2012, 07:12 PM Thread Starter
Edgethis's Avatar
Here's a quick video with my new exhaust. I like the way it sounds. I got rid of the shroud , that is what you hear rattling as I give it some gas.
68 coupe rev | Flickr - Photo Sharing!
Edgethis is offline
post #53 of 991 Old April 25th, 2012, 05:25 PM Thread Starter
Edgethis's Avatar
FedEx man just dropped off a new present, my Edelbrock performer intake!
2012-04-25_17-13-40_145.jpg by Edgethis, on Flickr
Edgethis is offline
post #54 of 991 Old April 26th, 2012, 04:30 PM Thread Starter
Edgethis's Avatar
I did some sanding on the manifold today. It's far from done but it looks alot better then the cast look IMHO. Just need to find a Dremel to borrow so I can get into those nooks.
2012-04-26_11-28-12_210.jpg by Edgethis, on Flickr
Edgethis is offline
post #55 of 991 Old April 28th, 2012, 12:43 PM Thread Starter
Edgethis's Avatar
Here's a few pictures of my new motor.
2012-04-28_09-30-43_376.jpg by Edgethis, on Flickr
2012-04-28_09-30-26_39.jpg by Edgethis, on Flickr
It is a 5.0 out of a 2000 Explorer, It had the GT40P heads. It'll be a pain to get headers but it was such a good deal I couldn't pass it up. $250 for everything!
Here's the motor after I removed most of the EFI and wiring.
2012-04-28_12-06-40_979.jpg by Edgethis, on Flickr
Edgethis is offline
post #56 of 991 Old April 30th, 2012, 01:29 PM Thread Starter
Edgethis's Avatar
Took a short drive on my lunch break to my favorite thinking spot.
2012-04-30_12-21-07_345.jpg by Edgethis, on Flickr
2012-04-30_12-21-40_679.jpg by Edgethis, on Flickr
Edgethis is offline
post #57 of 991 Old May 2nd, 2012, 06:00 PM
are you really Ted Nugent? lol. That zebra paint job on the truck has got to stand out in a crowd. looks like a great project for an upgrade. I love the one piece rear main seal and the roller cam. some day I think I will switch my daughters car back to efi. but the carb was cheaper and easier in the short term. looks like the stang is really coming along.
post #58 of 991 Old May 13th, 2012, 10:49 AM Thread Starter
Edgethis's Avatar
Thanks! I got the truck from a guy who worked at a zoo. It actually has a cutom made soft top so you can run open roof and sides while still having seat belts and rolll protection. I never have to look hard to find where I parked, thats for sure.
Been working a bit on my motor. Ground the grime off and shot it over with a coat of primer. I have the Performer intake and serp brackets sanded down and painted with an aluminum color and clearcoated. I'll try to get pics of them shortly.
2012-05-13_10-32-25_597.jpg by Edgethis, on Flickr
I'm primering a bit at a time so I can see where I need to go over again with the wire wheel. The block/heads will eventually be painted Ford Blue and the timing cover, brackets and intake will be painted Aluminum. Topped with my Edelbrock Elite air cleaner and a matching set of valve covers.
Edgethis is offline
post #59 of 991 Old May 15th, 2012, 12:53 PM Thread Starter
Edgethis's Avatar
I had a bolt break on the extra motor when I took the EFI intake off. I tried to drill it out but no luck. Looks like I'm gonna have to have it re-tapped and put a helicoil in. I did put a quick coat of Ford Blue on the engine. Pics to come soon.
Edgethis is offline
post #60 of 991 Old May 19th, 2012, 09:30 AM
Item one..... DEFINITELY get rid of that awful slave cylinder and get a power steering gear box. You can get a complete change over for about 1G from "Mustang Depot.com" You might want to try this little trick, I have just finished (18 May) putting an 8.8 rear end from a 2000 Explorer into my '67 stang, why you ask, because parts and repairs for 8.8 are cheaper and more plentyful than the nine incher. The install was slick, just wash everything of the housing with a gas hacksaw (cutting torch) except the torsion bar mounts, buy new spring perches for 15 dollars a pair and get ready to have some fun. The Explorer 8.8 comes factory with 3.73 gears and 11" disc brakes that have low profile calipers that fit inside your factory 14" wheels. The 3.73's were what I needed to keep my engine running in the power band of my cam, I have installed a late model 5.0 roller block with a 347 stroker kit and a T-5 tranny with a .64 top gear. My addition of a "Trick Flow" "Stage Three" cam means I needed my 70 mph rpm to be in the 2100 to 2350 range...........Using the "Explorer" rear is a MUST because I have the same center of pinion offset that your factory 8 inch has so remember to offset your spring perches one half to five eighths inch toward the drivers side. The 8.8 in the '79-'04 Mustangs won't work because they are equal distant side to center.
nailbender5327 is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251801-booms-68-restomod.html
Doors make 2 different shutting noises - Vintage Mustang Forums This thread Refback April 22nd, 2018 10:44 PM
67-68 parts - Vintage Mustang Forums This thread Refback April 18th, 2018 10:22 PM
New FITECH EFI Tank - Vintage Mustang Forums This thread Refback April 9th, 2018 01:04 AM
Which T5, T5z shifter - feedback, Pro 5.0, Tri-Ax, MGW, UPR in VM's? - Vintage Mustang Forums This thread Refback March 16th, 2018 12:12 PM
The Great EFI Debate - Vintage Mustang Forums This thread Refback February 3rd, 2018 12:04 AM
FI Tech EFI - Page 8 - Vintage Mustang Forums This thread Refback January 30th, 2018 04:40 PM
68 Coupe Pro Touring Build Pic Heavy - Page 2 - Vintage Mustang Forums This thread Refback January 17th, 2018 02:10 AM
Novi 2000 conversion complete - Vintage Mustang Forums This thread Refback January 15th, 2018 05:02 PM
What brakes to use? - Vintage Mustang Forums This thread Refback January 3rd, 2018 10:59 PM
LED Headlights with DRL - Vintage Mustang Forums This thread Refback December 29th, 2017 04:55 PM
GT500 Brembo brakes on 68 Mustang - Vintage Mustang Forums This thread Refback December 20th, 2017 01:23 AM
Coyote - Now I get it - Vintage Mustang Forums This thread Refback November 28th, 2017 09:04 PM
8" rear axle from 68 complete - Vintage Mustang Forums This thread Refback October 12th, 2017 09:01 PM
Hello! - Vintage Mustang Forums This thread Refback September 30th, 2017 10:30 AM
Anyone using the Holley Sniper EFI yet? - Page 2 - Vintage Mustang Forums This thread Refback August 30th, 2017 10:35 PM
1967 coup GW coil over instructions - Vintage Mustang Forums This thread Refback August 28th, 2017 04:13 PM
RIP Jerry Lewis - Vintage Mustang Forums This thread Refback August 26th, 2017 11:05 AM
craigslist alert for 69 fastback finally hit after 3 years lol - Vintage Mustang Forums This thread Refback August 24th, 2017 04:53 PM
Repro door hinge plate issue - Vintage Mustang Forums This thread Refback August 12th, 2017 01:41 PM
Fox Coilovers Front & Rear? - Vintage Mustang Forums This thread Refback August 7th, 2017 07:51 AM
Adding a cam to 1968 stock 302 - Vintage Mustang Forums This thread Refback August 1st, 2017 03:50 PM
289 efi kits - Vintage Mustang Forums This thread Refback July 22nd, 2017 12:51 AM
1968 Ford Mustang Restomod Muscle Car Build by Edgethis This thread Refback July 19th, 2017 10:31 AM
Questions regarding USS Fitzgerald - Vintage Mustang Forums This thread Refback July 18th, 2017 08:42 PM
FiTech EFI tuning - Vintage Mustang Forums This thread Refback July 13th, 2017 02:26 AM
THINKING of selling my fitech system - Vintage Mustang Forums This thread Refback July 13th, 2017 01:26 AM
'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums This thread Refback July 10th, 2017 08:11 PM
Just ordered the new TMI Full Length Center Console. Can't wait! Looks gorgeous! - Vintage Mustang Forums This thread Refback July 3rd, 2017 07:07 PM
Law of Armed Conflict Question - Navy - Vintage Mustang Forums This thread Refback June 28th, 2017 01:32 AM
Borgeson PS conversion box and pump - Vintage Mustang Forums This thread Refback June 4th, 2017 01:35 AM
Vintage Venom out of business? - Vintage Mustang Forums This thread Refback June 3rd, 2017 07:39 PM
does anyone have the global west adjustable monte carlo bar? - Vintage Mustang Forums This thread Refback June 1st, 2017 08:08 PM
What did you do to/for your Mustang today? - Page 122 - Vintage Mustang Forums This thread Refback May 12th, 2017 01:20 PM
Help ... Ignition or Fuel related - Vintage Mustang Forums This thread Refback April 20th, 2017 07:21 PM
At a loss for words on this one - Vintage Mustang Forums This thread Refback April 19th, 2017 09:19 AM
Front Suspention Recommendations for 67-68 - Vintage Mustang Forums This thread Refback April 16th, 2017 10:08 PM
69 mustang with 6R80 tranny/ Driveshaft? - Vintage Mustang Forums This thread Refback April 16th, 2017 06:57 PM
Thumbs up to MSD Service. - Vintage Mustang Forums This thread Refback April 13th, 2017 10:15 AM
'65 Front brakes - bigger rotors or better pads? - Vintage Mustang Forums This thread Refback April 12th, 2017 01:06 PM
What did you do to/for your Mustang today? - Page 116 - Vintage Mustang Forums This thread Refback April 11th, 2017 09:15 AM
About to set this car on fire - Vintage Mustang Forums This thread Refback March 29th, 2017 02:43 PM
What did you do to/for your Mustang today? - Page 114 - Vintage Mustang Forums This thread Refback March 22nd, 2017 08:34 AM
MTF One Piece Headliner Install - Vintage Mustang Forums This thread Refback January 29th, 2017 11:08 AM
Front drums off a 68, freshly rebuilt - Vintage Mustang Forums This thread Refback December 25th, 2016 09:51 AM
1968 Grabber Blue V8 4spd coupe - Vintage Mustang Forums This thread Refback December 23rd, 2016 02:54 PM
My 1968 Coupe trans-am tribute project - Page 14 - Vintage Mustang Forums This thread Refback December 14th, 2016 11:36 AM
Fuel Pressure Regulator - Vintage Mustang Forums This thread Refback December 13th, 2016 01:04 AM
671 blower - Vintage Mustang Forums This thread Refback December 12th, 2016 10:07 AM
SAVE 10% on Street or Track products! - Page 5 - Vintage Mustang Forums This thread Refback December 1st, 2016 11:48 AM
Where to look for your first classic? - Vintage Mustang Forums This thread Refback November 24th, 2016 08:04 PM
