Boom's 68 Restomod - Page 43 - Forums at Modded Mustangs
post #841 of 991 Old March 9th, 2015, 11:48 AM
You had one job!
TCStang's Avatar
Glad to see you got everything worked out.
1968 Coupe- Sold
2007 Premium GT- Sold
MY CO BUILD
TCStang is offline
post #842 of 991 Old March 13th, 2015, 07:44 PM Thread Starter
Edgethis's Avatar
Yeah it's nice to be able to drive the car regularly again.
UPS man just dropped off a nice box for me:
20150313_182557-1 by Edgethis, on Flickr
It came with all the bolts/studs for the axle also. I just have to get new shafts and have the center put together. I am going to drop this off at the powdercoater on Monday, I'm debating between a nice blue (similar to the cars color) or just black. The center chunk is a nice silver/aluminum color.
Edgethis is offline
post #843 of 991 Old March 14th, 2015, 09:47 AM
You're encouraging me to get off the computer and start working on my '68 Sprint B! lol
Good looking car.
Axton is offline
post #844 of 991 Old March 19th, 2015, 06:36 PM Thread Starter
Edgethis's Avatar
Got the axle housing back. It looks great!
axle housing by Edgethis, on Flickr
Now I have to get the gears and true trac differential.
Edgethis is offline
post #845 of 991 Old March 22nd, 2015, 11:16 AM Thread Starter
Edgethis's Avatar
20150322_101134 by Edgethis, on Flickr
Looking to order the gears and truetrac tomorrow. I'm debating between 3.50 and 3.70 gears.
Edgethis is offline
post #846 of 991 Old March 23rd, 2015, 10:06 AM
You had one job!
TCStang's Avatar
I think you should go 3.70 since you have a 5 speed.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
post #847 of 991 Old March 23rd, 2015, 11:29 AM
nkausch's Avatar
I don't remember do you have a t5? I have a t5 and 3.73 and it's a great combo still better than stock but it's not too high reving on the highway like 4.10's
94 GT Vert
<a href="https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html"]https://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html">70mm Turbo Build</A>
nkausch is offline
post #848 of 991 Old March 23rd, 2015, 03:02 PM
You had one job!
TCStang's Avatar
Yep he has a T5.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
post #849 of 991 Old March 23rd, 2015, 03:13 PM
nkausch's Avatar
Then I agree go 3.70
94 GT Vert
nkausch is offline
post #850 of 991 Old March 23rd, 2015, 07:21 PM Thread Starter
Edgethis's Avatar
Thanks for the tips guys. I ordered the 3.70 gears and the True trac. That Eaton differential price tag was hard to swallow.
Edgethis is offline
post #851 of 991 Old March 25th, 2015, 07:35 PM Thread Starter
Edgethis's Avatar
I got the gears and a carry case for the differential today. As well as another box!
20150325_181346 by Edgethis, on Flickr
Inside was the MTF radiator/fan combo! This thing is super awesome. I can't wait to install it!
20150325_183123 by Edgethis, on Flickr
Edgethis is offline
post #852 of 991 Old March 26th, 2015, 10:29 AM
You had one job!
TCStang's Avatar
you'll have to let me know how the MTF radiator fits in the stock mounting location. MY Champion doesn't fit very well.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
post #853 of 991 Old March 26th, 2015, 05:01 PM Thread Starter
Edgethis's Avatar
UPS man brought another package today
20150326_155641 by Edgethis, on Flickr
I have heard good things about these, so I decided to run one since my block is pretty old and the radiator is a little pricey to get clogged with gunk.
2015-03-26_03-58-40 by Edgethis, on Flickr
Edgethis is offline
post #854 of 991 Old March 27th, 2015, 05:33 PM Thread Starter
Edgethis's Avatar
Dropped the differential parts off at a shop to have them assemble the center chunk.
20150327_143322 by Edgethis, on Flickr
I feel pretty good about them doing the gears. I pulled up to their shop and they have a super clean fox body that looks showroom clean in there, they were in the middle of a gear change on a S197 and they have a couple old firebirds (~ealry 70's) sitting off to the side of the shop with new painless harness boxes ready to go in.
Edgethis is offline
post #855 of 991 Old March 27th, 2015, 10:25 PM Thread Starter
Edgethis's Avatar
Getting things ready for the radiator install tomorrow. I needed to mount the fan switch so I decided to mount it to the shroud. I removed the fan shroud so I wouldn't have any chance of damaging the radiator during the mounting.
Here's the radiator without the shroud and fans:
20150327_191046 by Edgethis, on Flickr
I was a bit surprised to see that there are 2 spots that are dented....its where the very tip of the fan motor is. Hopefully that isn't an issue.
Here's a shot all put back together with the switch mounted. I'm thinking of sticking the probe in the lower hose vs stabbing the fins with it.
20150327_210229 by Edgethis, on Flickr
I also have a new aluminum water pump and Gano filter that I will be installing. hopefully it all goes fairly smoothly.
Edgethis is offline
post #856 of 991 Old March 28th, 2015, 10:06 PM Thread Starter
Edgethis's Avatar
It was a long day. I finally got it all together. Still have a few things to fix. The water pump and thermostat swap went pretty pain free.
20150328_123350 by Edgethis, on Flickr
Any idea what causes the timing cover to get like this:
20150328_100240 by Edgethis, on Flickr
It was also on the pump:
20150328_105113 by Edgethis, on Flickr
I didn't get a good shot of the radiator installed, they all came out blurry.
The radiator install was rather tame compared to my usual projects lol. I forgot to get new hose clamps, that was a nightmare. Those clamps you get at the auto houses are pretty much one time use it seems.
I was lucky that the four bolts that hold the 20" radiator also can be used to hold the 24"s brackets. I did have to slot the holes slightly to allow me to slide the lower brackets back a bit so the radiator wasn't against the the radiator support.
The shroud is very nice, though i did have to adjust it to be able to slide the upper hose on all the way. Not a big deal, four bolts and its done. The only issue I have to resolve is that I couldn't get the fans to come on. I have everything wired up, but after working at it for 10 hours I had to settle for no leaks. I'll double check the wiring in the morning. I'm not sure how to adjust the fan switch, hopefully thats all it needs.
Edgethis is offline
post #857 of 991 Old March 29th, 2015, 09:49 AM Thread Starter
Edgethis's Avatar
Here's a few pitcures of the radiator. You can't really notice it through the grille. I've read that some people don't like aluminum radiators because they show through the grille. Here's a shot dead on.
20150329_084148 by Edgethis, on Flickr
Here's a couple shots witht eh hood up. It is definitely a tight fit. I need to get the inserts for the upper mount. Currently it just has foam weatherstriping in it.
20150329_084202 by Edgethis, on Flickr
20150329_084212 by Edgethis, on Flickr
The reason for the hose clamps on the middle of the upper hose is there is a Gano coolant filter in there.
Edgethis is offline
post #858 of 991 Old March 30th, 2015, 11:11 AM
You had one job!
TCStang's Avatar
That looks like a nice clean fit. As far as what causes that on the back of the water pump I always thought it came from some water getting in there. I've had it on several water pumps I removed.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
post #859 of 991 Old March 30th, 2015, 02:58 PM Thread Starter
Edgethis's Avatar
It is a very nice fit. i jsut have to figure out what size mount to put in the upper bracket and it will be perfect.
I figured thats what could cause that rust, wanted to double check.
Edgethis is offline
post #860 of 991 Old March 31st, 2015, 12:00 AM
Dude!!!
I thought you quit working on your car. Turns out your thread just got moved to the projects section. Things are looking great. I'll have to remember to stop by more often.
ajzride is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251801-booms-68-restomod.html
Doors make 2 different shutting noises - Vintage Mustang Forums This thread Refback April 22nd, 2018 10:44 PM
67-68 parts - Vintage Mustang Forums This thread Refback April 18th, 2018 10:22 PM
New FITECH EFI Tank - Vintage Mustang Forums This thread Refback April 9th, 2018 01:04 AM
Which T5, T5z shifter - feedback, Pro 5.0, Tri-Ax, MGW, UPR in VM's? - Vintage Mustang Forums This thread Refback March 16th, 2018 12:12 PM
The Great EFI Debate - Vintage Mustang Forums This thread Refback February 3rd, 2018 12:04 AM
FI Tech EFI - Page 8 - Vintage Mustang Forums This thread Refback January 30th, 2018 04:40 PM
68 Coupe Pro Touring Build Pic Heavy - Page 2 - Vintage Mustang Forums This thread Refback January 17th, 2018 02:10 AM
Novi 2000 conversion complete - Vintage Mustang Forums This thread Refback January 15th, 2018 05:02 PM
What brakes to use? - Vintage Mustang Forums This thread Refback January 3rd, 2018 10:59 PM
LED Headlights with DRL - Vintage Mustang Forums This thread Refback December 29th, 2017 04:55 PM
GT500 Brembo brakes on 68 Mustang - Vintage Mustang Forums This thread Refback December 20th, 2017 01:23 AM
Coyote - Now I get it - Vintage Mustang Forums This thread Refback November 28th, 2017 09:04 PM
8" rear axle from 68 complete - Vintage Mustang Forums This thread Refback October 12th, 2017 09:01 PM
Hello! - Vintage Mustang Forums This thread Refback September 30th, 2017 10:30 AM
Anyone using the Holley Sniper EFI yet? - Page 2 - Vintage Mustang Forums This thread Refback August 30th, 2017 10:35 PM
1967 coup GW coil over instructions - Vintage Mustang Forums This thread Refback August 28th, 2017 04:13 PM
RIP Jerry Lewis - Vintage Mustang Forums This thread Refback August 26th, 2017 11:05 AM
craigslist alert for 69 fastback finally hit after 3 years lol - Vintage Mustang Forums This thread Refback August 24th, 2017 04:53 PM
Repro door hinge plate issue - Vintage Mustang Forums This thread Refback August 12th, 2017 01:41 PM
Fox Coilovers Front & Rear? - Vintage Mustang Forums This thread Refback August 7th, 2017 07:51 AM
Adding a cam to 1968 stock 302 - Vintage Mustang Forums This thread Refback August 1st, 2017 03:50 PM
289 efi kits - Vintage Mustang Forums This thread Refback July 22nd, 2017 12:51 AM
1968 Ford Mustang Restomod Muscle Car Build by Edgethis This thread Refback July 19th, 2017 10:31 AM
Questions regarding USS Fitzgerald - Vintage Mustang Forums This thread Refback July 18th, 2017 08:42 PM
FiTech EFI tuning - Vintage Mustang Forums This thread Refback July 13th, 2017 02:26 AM
THINKING of selling my fitech system - Vintage Mustang Forums This thread Refback July 13th, 2017 01:26 AM
'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums This thread Refback July 10th, 2017 08:11 PM
Just ordered the new TMI Full Length Center Console. Can't wait! Looks gorgeous! - Vintage Mustang Forums This thread Refback July 3rd, 2017 07:07 PM
Law of Armed Conflict Question - Navy - Vintage Mustang Forums This thread Refback June 28th, 2017 01:32 AM
Borgeson PS conversion box and pump - Vintage Mustang Forums This thread Refback June 4th, 2017 01:35 AM
Vintage Venom out of business? - Vintage Mustang Forums This thread Refback June 3rd, 2017 07:39 PM
does anyone have the global west adjustable monte carlo bar? - Vintage Mustang Forums This thread Refback June 1st, 2017 08:08 PM
What did you do to/for your Mustang today? - Page 122 - Vintage Mustang Forums This thread Refback May 12th, 2017 01:20 PM
Help ... Ignition or Fuel related - Vintage Mustang Forums This thread Refback April 20th, 2017 07:21 PM
At a loss for words on this one - Vintage Mustang Forums This thread Refback April 19th, 2017 09:19 AM
Front Suspention Recommendations for 67-68 - Vintage Mustang Forums This thread Refback April 16th, 2017 10:08 PM
69 mustang with 6R80 tranny/ Driveshaft? - Vintage Mustang Forums This thread Refback April 16th, 2017 06:57 PM
Thumbs up to MSD Service. - Vintage Mustang Forums This thread Refback April 13th, 2017 10:15 AM
'65 Front brakes - bigger rotors or better pads? - Vintage Mustang Forums This thread Refback April 12th, 2017 01:06 PM
What did you do to/for your Mustang today? - Page 116 - Vintage Mustang Forums This thread Refback April 11th, 2017 09:15 AM
About to set this car on fire - Vintage Mustang Forums This thread Refback March 29th, 2017 02:43 PM
What did you do to/for your Mustang today? - Page 114 - Vintage Mustang Forums This thread Refback March 22nd, 2017 08:34 AM
MTF One Piece Headliner Install - Vintage Mustang Forums This thread Refback January 29th, 2017 11:08 AM
Front drums off a 68, freshly rebuilt - Vintage Mustang Forums This thread Refback December 25th, 2016 09:51 AM
1968 Grabber Blue V8 4spd coupe - Vintage Mustang Forums This thread Refback December 23rd, 2016 02:54 PM
My 1968 Coupe trans-am tribute project - Page 14 - Vintage Mustang Forums This thread Refback December 14th, 2016 11:36 AM
Fuel Pressure Regulator - Vintage Mustang Forums This thread Refback December 13th, 2016 01:04 AM
671 blower - Vintage Mustang Forums This thread Refback December 12th, 2016 10:07 AM
SAVE 10% on Street or Track products! - Page 5 - Vintage Mustang Forums This thread Refback December 1st, 2016 11:48 AM
Where to look for your first classic? - Vintage Mustang Forums This thread Refback November 24th, 2016 08:04 PM
