Boom's 68 Restomod - Page 49 - Forums at Modded Mustangs
post #961 of 991 Old January 22nd, 2016, 11:05 PM Thread Starter
Edgethis's Avatar
Had a nice big box show up today. It'll be awhile before its installed but damn it looks nice.
2016-01-22_10-02-20 by Brett, on Flickr
2016-01-22_10-02-33 by Brett, on Flickr
Its the 1967 Shelby style nose from MTF.
Edgethis is offline
post #962 of 991 Old January 24th, 2016, 08:23 PM
You had one job!
TCStang's Avatar
That's awesome, it's going to look great.
1968 Coupe- Sold
2007 Premium GT- Sold
MY CO BUILD
TCStang is offline
post #963 of 991 Old January 26th, 2016, 09:37 PM
You'll love the MTF nose.
And mind those plug wires, you saw what a shorted wire did to my car :/
ajzride is offline
post #964 of 991 Old January 27th, 2016, 05:46 PM Thread Starter
Edgethis's Avatar
Thanks! I already addressed the wires.
I am contemplating doing the full MTF subframe, but that on top of the cost of a coyote......sweet jeebus it adds up quick.
Edgethis is offline
post #965 of 991 Old February 8th, 2016, 10:24 PM
Well don't even contemplate the Coyote without the MTF subframe.
ajzride is offline
post #966 of 991 Old February 9th, 2016, 07:01 PM Thread Starter
Edgethis's Avatar
Yeah. I def wouldn't do a coyote swap without alot fo MTF parts. I just don't see that swap happening. I am still slowly building a 351w to hopefully put in the car. The next mod is going to be some sort of EFI conversion from FItech.
Products
I'm really liking the Meanstreet 800 HP kit and their fuel command center. I don't see myself ever having more then that and its high enough that it'll support a built 408w down the road.
Edgethis is offline
post #967 of 991 Old February 29th, 2016, 08:33 AM Thread Starter
Edgethis's Avatar
A couple packages showed up at the door. I cant wait to start this install.
2016-02-29_07-29-21 by Brett, on Flickr
I plan to make a separate install thread in the classics forum so people can find this information easier. I will post plenty of pictures.
Edgethis is offline
post #968 of 991 Old February 29th, 2016, 10:12 AM
iTrader: 8 reviews
Awesome! I've been looking at that for my truck so I'll be keeping an eye out to see how it goes for you.
BA Mustang is offline
post #969 of 991 Old March 10th, 2016, 07:28 PM Thread Starter
Edgethis's Avatar
For those wondering, here is a link to my FiTech EFI install:
https://www.moddedmustangs.com/forums...l#post11409890
The EFI is the main project currently. I also nabbed a new relay upgrade headlight harness. I'll post that install here after the EFI is done.
Edgethis is offline
post #970 of 991 Old March 10th, 2016, 10:30 PM
You had one job!
TCStang's Avatar
Can't wait to see how the install turns out. Should make it a whole different animal.
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
post #971 of 991 Old March 25th, 2016, 10:03 AM Thread Starter
Edgethis's Avatar
Ran into a few snags while doing the EFI install. I decided to replace the distributor with a nice unit. I nabbed an MSD Billet distributor:
MSD Pro-Billet Street Distributors 84791 - Free Shipping on Orders Over $99 at Summit Racing
It looks great and went it without too many issues. However, it is quite a bit larger then the OEM distributors. Here's a few shots showing the clearance I have with a standard air cleaner size.
20160324_205125 by Brett, on Flickr
20160321_182903 by Brett, on Flickr
I was also having an issue with the cleaner base hitting the fuel line, so I got a nice 1/2" billet spacer.
20160324_205101 by Brett, on Flickr
For those that haven't seen the other thread, here's a shot of the engine bay (minus the shiny new distributor)
20160311_145537 by Brett, on Flickr
Edgethis is offline
post #972 of 991 Old April 6th, 2016, 10:10 AM
MM's Caller of Bullshit
Destination S197's Avatar
I had rubbing issues with a plug wire on my MSD distributor and the Edelbrock air cleaner. One of the reason I switched to a slightly smaller air cleaner.
Destination S197 is offline
post #973 of 991 Old April 7th, 2016, 10:42 PM Thread Starter
Edgethis's Avatar
Yeah I'm going to get a smaller air cleaner soon. I'm just worried about airflow, kind of silly I guess.
I noticed while chasing down a popping in the exhaust that I was missing a header bolt and a number of others were loose. I picked up some Ford Racing Stage 8 locking bolts. They look nice, however, I will need to trim the lock washer before any of them will fit with my headers. Another awesome plus is they have an allen key on the top, makes tightening them a breeze.
20160407_204910 by Brett, on Flickr
20160407_204927 by Brett, on Flickr
Edgethis is offline
post #974 of 991 Old April 10th, 2016, 12:21 PM Thread Starter
Edgethis's Avatar
I took the car out today for it maiden voyage with the EFI. Just went around the complex here and then took it out around the block. The exhaust made some pops here and there. I think it got a bit better as I drive, so maybe the EFI learning is part to blame. The car had a slight hesitation when I was just puttering around the lot. This may also be due to the linkage not being as smooth as a cable set-up (future project lol)
When I got the car out on the access road and punched the throttle, I was amazed. The car took off like a rocket with no hesitation, I couldn't believe how smooth the rpms climbed. With the Edelbrock carb it always had a bit of a bog as the secondaries opened then it went. I still need to keep an eye on it and take it for a few longer drives but right now I'd say the conversion was worth every bit of head ache I ran into.
Edgethis is offline
post #975 of 991 Old July 26th, 2016, 12:55 PM
How has the fuel injection gone so far since it's been a few months. Hows the computer learned your driving well enough at this point to tell a difference?
post #976 of 991 Old July 31st, 2016, 10:49 PM Thread Starter
Edgethis's Avatar
The car runs very well, super smooth. There's only a couple of things that I still have to work with and what I've read its most likely due to the dual plane intake manifold I have. TBI based systems can work with them, but not super well, something about the air/fuel mixture never being quite right at certain times.
I haven't had alot of time to work on it lately, been out of town the last few weeks. But I have been daily driving it to work since the EFI install.
Edgethis is offline
post #977 of 991 Old August 2nd, 2016, 08:35 AM
RAT FINK
ghunt's Avatar
I found this beautiful 68 coupe in Arizona and had it shipped out here to WV where I'm currently stationed.
I just happened to see this, are/were you stationed at camp dawson?
2005 Mustang GT
CMS Stage 1 cams, Lito Tune, C&L Racer, CMDP, SR UDP, JBA LT's & catted H, FRPP Touring AB, Koni STR.T, BMR springs, J&M upper/mount, BMR lowers & brackets, J&M pb, Steeda Tri-Ax, Brembos
2009 Ranger XL SCab-4.0, auto, 4WD
ghunt is offline
post #978 of 991 Old August 5th, 2016, 09:59 PM Thread Starter
Edgethis's Avatar
I was down in Bluefield. Wonderful town down on the border of Virginia.
Edgethis is offline
post #979 of 991 Old August 7th, 2016, 06:55 PM
RAT FINK
ghunt's Avatar
Gotcha, didn't know there was a base in Bluefield!
2005 Mustang GT
ghunt is offline
post #980 of 991 Old August 9th, 2016, 08:46 PM
You had one job!
TCStang's Avatar
When is the MTF front end going on?
1968 Coupe- Sold
MY CO BUILD
TCStang is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251801-booms-68-restomod.html
Doors make 2 different shutting noises - Vintage Mustang Forums This thread Refback April 22nd, 2018 10:44 PM
67-68 parts - Vintage Mustang Forums This thread Refback April 18th, 2018 10:22 PM
New FITECH EFI Tank - Vintage Mustang Forums This thread Refback April 9th, 2018 01:04 AM
Which T5, T5z shifter - feedback, Pro 5.0, Tri-Ax, MGW, UPR in VM's? - Vintage Mustang Forums This thread Refback March 16th, 2018 12:12 PM
The Great EFI Debate - Vintage Mustang Forums This thread Refback February 3rd, 2018 12:04 AM
FI Tech EFI - Page 8 - Vintage Mustang Forums This thread Refback January 30th, 2018 04:40 PM
68 Coupe Pro Touring Build Pic Heavy - Page 2 - Vintage Mustang Forums This thread Refback January 17th, 2018 02:10 AM
Novi 2000 conversion complete - Vintage Mustang Forums This thread Refback January 15th, 2018 05:02 PM
What brakes to use? - Vintage Mustang Forums This thread Refback January 3rd, 2018 10:59 PM
LED Headlights with DRL - Vintage Mustang Forums This thread Refback December 29th, 2017 04:55 PM
GT500 Brembo brakes on 68 Mustang - Vintage Mustang Forums This thread Refback December 20th, 2017 01:23 AM
Coyote - Now I get it - Vintage Mustang Forums This thread Refback November 28th, 2017 09:04 PM
8" rear axle from 68 complete - Vintage Mustang Forums This thread Refback October 12th, 2017 09:01 PM
Hello! - Vintage Mustang Forums This thread Refback September 30th, 2017 10:30 AM
Anyone using the Holley Sniper EFI yet? - Page 2 - Vintage Mustang Forums This thread Refback August 30th, 2017 10:35 PM
1967 coup GW coil over instructions - Vintage Mustang Forums This thread Refback August 28th, 2017 04:13 PM
RIP Jerry Lewis - Vintage Mustang Forums This thread Refback August 26th, 2017 11:05 AM
craigslist alert for 69 fastback finally hit after 3 years lol - Vintage Mustang Forums This thread Refback August 24th, 2017 04:53 PM
Repro door hinge plate issue - Vintage Mustang Forums This thread Refback August 12th, 2017 01:41 PM
Fox Coilovers Front & Rear? - Vintage Mustang Forums This thread Refback August 7th, 2017 07:51 AM
Adding a cam to 1968 stock 302 - Vintage Mustang Forums This thread Refback August 1st, 2017 03:50 PM
289 efi kits - Vintage Mustang Forums This thread Refback July 22nd, 2017 12:51 AM
1968 Ford Mustang Restomod Muscle Car Build by Edgethis This thread Refback July 19th, 2017 10:31 AM
Questions regarding USS Fitzgerald - Vintage Mustang Forums This thread Refback July 18th, 2017 08:42 PM
FiTech EFI tuning - Vintage Mustang Forums This thread Refback July 13th, 2017 02:26 AM
THINKING of selling my fitech system - Vintage Mustang Forums This thread Refback July 13th, 2017 01:26 AM
'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums This thread Refback July 10th, 2017 08:11 PM
Just ordered the new TMI Full Length Center Console. Can't wait! Looks gorgeous! - Vintage Mustang Forums This thread Refback July 3rd, 2017 07:07 PM
Law of Armed Conflict Question - Navy - Vintage Mustang Forums This thread Refback June 28th, 2017 01:32 AM
Borgeson PS conversion box and pump - Vintage Mustang Forums This thread Refback June 4th, 2017 01:35 AM
Vintage Venom out of business? - Vintage Mustang Forums This thread Refback June 3rd, 2017 07:39 PM
does anyone have the global west adjustable monte carlo bar? - Vintage Mustang Forums This thread Refback June 1st, 2017 08:08 PM
What did you do to/for your Mustang today? - Page 122 - Vintage Mustang Forums This thread Refback May 12th, 2017 01:20 PM
Help ... Ignition or Fuel related - Vintage Mustang Forums This thread Refback April 20th, 2017 07:21 PM
At a loss for words on this one - Vintage Mustang Forums This thread Refback April 19th, 2017 09:19 AM
Front Suspention Recommendations for 67-68 - Vintage Mustang Forums This thread Refback April 16th, 2017 10:08 PM
69 mustang with 6R80 tranny/ Driveshaft? - Vintage Mustang Forums This thread Refback April 16th, 2017 06:57 PM
Thumbs up to MSD Service. - Vintage Mustang Forums This thread Refback April 13th, 2017 10:15 AM
'65 Front brakes - bigger rotors or better pads? - Vintage Mustang Forums This thread Refback April 12th, 2017 01:06 PM
What did you do to/for your Mustang today? - Page 116 - Vintage Mustang Forums This thread Refback April 11th, 2017 09:15 AM
About to set this car on fire - Vintage Mustang Forums This thread Refback March 29th, 2017 02:43 PM
What did you do to/for your Mustang today? - Page 114 - Vintage Mustang Forums This thread Refback March 22nd, 2017 08:34 AM
MTF One Piece Headliner Install - Vintage Mustang Forums This thread Refback January 29th, 2017 11:08 AM
Front drums off a 68, freshly rebuilt - Vintage Mustang Forums This thread Refback December 25th, 2016 09:51 AM
1968 Grabber Blue V8 4spd coupe - Vintage Mustang Forums This thread Refback December 23rd, 2016 02:54 PM
My 1968 Coupe trans-am tribute project - Page 14 - Vintage Mustang Forums This thread Refback December 14th, 2016 11:36 AM
Fuel Pressure Regulator - Vintage Mustang Forums This thread Refback December 13th, 2016 01:04 AM
671 blower - Vintage Mustang Forums This thread Refback December 12th, 2016 10:07 AM
SAVE 10% on Street or Track products! - Page 5 - Vintage Mustang Forums This thread Refback December 1st, 2016 11:48 AM
Where to look for your first classic? - Vintage Mustang Forums This thread Refback November 24th, 2016 08:04 PM
