Boom's 68 Restomod - Page 9 - Forums at Modded Mustangs
post #161 of 991 Old May 28th, 2013, 07:44 PM Thread Starter
Edgethis's Avatar
Holy crap I haven't updated this in forever!
I will get some pics up ASAP! The T5 swap has been pushed back and the roller motor is getting ready to go in here shortly.
To clean things up and be a bit more reliable I installed an electric fuel pump. I went with a Holley red and a Fram filter set-up. Made a bracket from some metal and mounted it in front of the gas tank.
Untitled by Edgethis, on Flickr
The roller block had been sitting in my kitchen for months. This is what I had to start with.
The timing chain looked ok, but figured I might as well upgrade so I ordered a new Edelbrock double roller timing set. The factory lifter guides from Ford were made of plastic and mostly broken. So in comes a new Ford Racing lifter kit with dogbones. I also cleaned up the pistons and made sure everything still turned smoothly.
Since the new roller block is 50oz I needed a new flexplate to mate to the C4, thanks to TCI, thats taken care of too.
I wanted to keep the factory look with serpentine and the passenger side coolant hoses, so in comes a Scott Drake balancer made to look period correct but balanced for 50 oz.
Also to come are pictures of the console I made.
Edgethis is offline
post #162 of 991 Old May 29th, 2013, 03:52 PM Thread Starter
Edgethis's Avatar
Got the bolts for the timing cover and water pump today. Went to Lowes and picked up some stainless bolts. I wanted an aluminum water pump but didn't wanna shell out $150+ for one right now, so I settled for a standard iron pump. Painted it aluminum to match the rest of the theme.
Also I got a good deal on a polished aluminum oil pan so that is going on the motor too. Looks like I have a buyer lined up for the motor currently in my car. Makes it easy as I'm going to be moving to Austin, TX here in July.
---------- Post added at 03:52 PM ---------- Previous post was at 03:50 PM ----------
I also plasti-dipped my wheels awhile back. Wanted to see how it looked with black rims. Nice, but I think I'll go chrome in the future.
Edgethis is offline
post #163 of 991 Old May 29th, 2013, 04:13 PM
Send a message via Skype™ to smilts
Damn nice build nice work.
Unkillable
1994 Black GT
2001 Honda shadow
smilts is offline
post #164 of 991 Old May 29th, 2013, 05:32 PM Thread Starter
Edgethis's Avatar
Thanks!
Here's a few shots of the console I built. It's made of MDF covered in marine grade vinyl. It has a Pioneer CD player and a pair of 6.5" kickers on the sides. The shifter is a pro-matic 2 by Hurst.
The radio panel is held to the console base with snaps, pull on it and the panel pops off. All of the wiring is tucked inside and labeled. I coated the ends of the wires with liquid electrical tape after this photo. Just to be safe. This set-up was quick, cheap, and simple. Down the line I'd like to get OEM connectors that can be mounted to the rear/side so I can unhook the connector and pull the console.
Heres a shot of my timing cover and water pump before I mount it on the block.
Edgethis is offline
post #165 of 991 Old May 30th, 2013, 11:27 PM Thread Starter
Edgethis's Avatar
Got a box from Cj Pony today. New weatherstriping for around the window frame on the doors. It was on sale and was only like $20 should have gotten the Scottdrake stuff like I normally do but this stuff works. I only had time to put the drivers side on but it seems to be working alright so far. Put a good bead of Black RTV on it and its stuck like glue.
I also got the new manual steering link in. Just have to order my roller idler from Opentracker and I'll be able to swap out the clunk power steering linkage for a much tighter set-up.
Edgethis is offline
post #166 of 991 Old June 2nd, 2013, 06:01 PM Thread Starter
Edgethis's Avatar
I got the new timing cover and water pump installed on the engine today. There is one bolt that didn't wanna line up properly so I am gonna have to try and use a different bolt and/or take the water pump off and redo it. I dont want to force the bolt in and strip the new bolt hole.
Edgethis is offline
post #167 of 991 Old June 3rd, 2013, 09:43 PM Thread Starter
Edgethis's Avatar
I picked up a PMGR starter for a 93 GT. I plan to have that installed when I do the motor swap. Didn't want to have a crappy old starter eating up my new flexplate. Plus the PMGR starters are smaller, lighter, and sound much smoother when starting.
Edgethis is offline
post #168 of 991 Old June 4th, 2013, 04:12 PM Thread Starter
Edgethis's Avatar
OK picture time!
The wheels are MB Old Schools in Chrome. 17x8 and 17x9.5 Tires are BFG Sport Comp 2 235/45R17 and 275/40R17
I just barely have room for that tire in the rear since it sits so low. I plan to shave the panel lip a bit on the top side to make sure it wont rub.
I have plenty of room up front. Still have to do the Shelby drop and cut the coils. I'd like to get it level with the rear as long as it doesn't rub.
Edgethis is offline
post #169 of 991 Old June 5th, 2013, 12:59 AM
Do you have power steering? I've got 245/45/r18 up front with manual steer, and it is hell on my shoulder.
ajzride is offline
post #170 of 991 Old June 5th, 2013, 07:03 AM Thread Starter
Edgethis's Avatar
I had power steering but it didnt work. Im converting to manual linkage with a roller idler this weekend.
Edgethis is offline
post #171 of 991 Old June 5th, 2013, 03:42 PM
Bo Baustin
Austin's Avatar
Its looking awesome man.
Austin is offline
post #172 of 991 Old June 6th, 2013, 07:24 PM
69Restomod's Avatar
great build
69Restomod is offline
post #173 of 991 Old June 6th, 2013, 08:48 PM Thread Starter
Edgethis's Avatar
Thanks guys. I got the roller idler in from opentracker. I plan to install that along withthe manual linkage tomorrow.
I also got the intake mounted on my engine. I went over and double checked the torque on teh head bolts and rocker arms. I am not sure about the thermostat housing. The thermostat seems to be a bit loose inside even when the bolts are tightened down.
Anyways, heres a quick picture. The intake is an Edelbrock Performer RPM. I got it used on Ebay for $38 and had to fix a crack on a water port. Hopefully it holds up.
I really just need to set the base timing and get ready to swap! Still debating on going ahead and getting new pullies.
Edgethis is offline
post #174 of 991 Old June 6th, 2013, 09:24 PM
69Restomod's Avatar
i have the same intake on mine. like the way the oil pressure sending unit and nipple are painted. wished i did that to mine now
post #175 of 991 Old June 6th, 2013, 09:51 PM
I painted mine an is has all flaked off
Need to take it back off and try some powder coat.
ajzride is offline
post #176 of 991 Old June 6th, 2013, 10:32 PM Thread Starter
Edgethis's Avatar
Thats what I'm afraid of, I made sure to give it a couple coats of primer, couple layers of paint and then cleared everything a few times. Spaced it out over a couple weeks to give plenty of dry time. Powder coating would be awesome if I had an oven to bake parts in.
I like the clean look when almost everything is paint matched in colors.
Edgethis is offline
post #177 of 991 Old June 7th, 2013, 12:20 AM
DEC '12 ROTM CO-Winner
Blue67coupe's Avatar
those wheels look great on there man. And will look even better after you do the drop. And it would be a good idea to cut that lip on the fender. I still have mine and am running a 275 rear and if I hit a hard enough bump with more than just me in the car the tires hit.
67 Coupe
03 Roush: sold
02 Roush 360R
Blue67coupe is offline
post #178 of 991 Old June 7th, 2013, 07:04 AM Thread Starter
Edgethis's Avatar
Thanks Blue, thats on the plan for today. I need to run by the local Advance and pick up a pitman arm puller for the steering swap and then later I plan to shave that lip down.
Quick question for anyone that's done timing. Would it be possible for me to turn the distributor housing around so the vacuum advance is pointed towards the carb, so the hose isn't doing a 180 out the front? I figured as long as I set base timing (10* BTD) with the housing like that then it shouldn't be an issue. Maybe i'm overlooking something tho.
Edgethis is offline
post #179 of 991 Old June 7th, 2013, 12:36 PM Thread Starter
Edgethis's Avatar
Alright, I switched out the power linkage for the manual steering set-up. If I want to do power steering in the future I'll prolly do the Borgenson box.
Swapping it out was pretty straight-forward, the center link holes are tapered so it all only goes on one way. My tie rod ends all looked ok so I didn't replace them. Thought about it, but i am more focused on getting the motor swap done first.
Everything came off nice and smooth, save for the damn nut on the pitman arm. I needed the big gun lol, 1" electric impact:
The old center link might be worth something to someone, I have the cylinder too, so I'll clean it up and put it in the classifieds:
Here's the new roller idler, sorry the pic is so dark:
I haven't driven it yet, so I can't make any comparisions. I am gonna start looking at the rear quarter panel lip.
I'll post pics up soon, my work computer doesn't work for pictures.
Edgethis is offline
post #180 of 991 Old June 7th, 2013, 01:28 PM
looks like a good start
6stangin5 is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/clubhouse/251801-booms-68-restomod.html
Doors make 2 different shutting noises - Vintage Mustang Forums This thread Refback April 22nd, 2018 10:44 PM
67-68 parts - Vintage Mustang Forums This thread Refback April 18th, 2018 10:22 PM
New FITECH EFI Tank - Vintage Mustang Forums This thread Refback April 9th, 2018 01:04 AM
Which T5, T5z shifter - feedback, Pro 5.0, Tri-Ax, MGW, UPR in VM's? - Vintage Mustang Forums This thread Refback March 16th, 2018 12:12 PM
The Great EFI Debate - Vintage Mustang Forums This thread Refback February 3rd, 2018 12:04 AM
FI Tech EFI - Page 8 - Vintage Mustang Forums This thread Refback January 30th, 2018 04:40 PM
68 Coupe Pro Touring Build Pic Heavy - Page 2 - Vintage Mustang Forums This thread Refback January 17th, 2018 02:10 AM
Novi 2000 conversion complete - Vintage Mustang Forums This thread Refback January 15th, 2018 05:02 PM
What brakes to use? - Vintage Mustang Forums This thread Refback January 3rd, 2018 10:59 PM
LED Headlights with DRL - Vintage Mustang Forums This thread Refback December 29th, 2017 04:55 PM
GT500 Brembo brakes on 68 Mustang - Vintage Mustang Forums This thread Refback December 20th, 2017 01:23 AM
Coyote - Now I get it - Vintage Mustang Forums This thread Refback November 28th, 2017 09:04 PM
8" rear axle from 68 complete - Vintage Mustang Forums This thread Refback October 12th, 2017 09:01 PM
Hello! - Vintage Mustang Forums This thread Refback September 30th, 2017 10:30 AM
Anyone using the Holley Sniper EFI yet? - Page 2 - Vintage Mustang Forums This thread Refback August 30th, 2017 10:35 PM
1967 coup GW coil over instructions - Vintage Mustang Forums This thread Refback August 28th, 2017 04:13 PM
RIP Jerry Lewis - Vintage Mustang Forums This thread Refback August 26th, 2017 11:05 AM
craigslist alert for 69 fastback finally hit after 3 years lol - Vintage Mustang Forums This thread Refback August 24th, 2017 04:53 PM
Repro door hinge plate issue - Vintage Mustang Forums This thread Refback August 12th, 2017 01:41 PM
Fox Coilovers Front & Rear? - Vintage Mustang Forums This thread Refback August 7th, 2017 07:51 AM
Adding a cam to 1968 stock 302 - Vintage Mustang Forums This thread Refback August 1st, 2017 03:50 PM
289 efi kits - Vintage Mustang Forums This thread Refback July 22nd, 2017 12:51 AM
1968 Ford Mustang Restomod Muscle Car Build by Edgethis This thread Refback July 19th, 2017 10:31 AM
Questions regarding USS Fitzgerald - Vintage Mustang Forums This thread Refback July 18th, 2017 08:42 PM
FiTech EFI tuning - Vintage Mustang Forums This thread Refback July 13th, 2017 02:26 AM
THINKING of selling my fitech system - Vintage Mustang Forums This thread Refback July 13th, 2017 01:26 AM
'67 rear quarter panel extension, the $64 question - Vintage Mustang Forums This thread Refback July 10th, 2017 08:11 PM
Just ordered the new TMI Full Length Center Console. Can't wait! Looks gorgeous! - Vintage Mustang Forums This thread Refback July 3rd, 2017 07:07 PM
Law of Armed Conflict Question - Navy - Vintage Mustang Forums This thread Refback June 28th, 2017 01:32 AM
Borgeson PS conversion box and pump - Vintage Mustang Forums This thread Refback June 4th, 2017 01:35 AM
Vintage Venom out of business? - Vintage Mustang Forums This thread Refback June 3rd, 2017 07:39 PM
does anyone have the global west adjustable monte carlo bar? - Vintage Mustang Forums This thread Refback June 1st, 2017 08:08 PM
What did you do to/for your Mustang today? - Page 122 - Vintage Mustang Forums This thread Refback May 12th, 2017 01:20 PM
Help ... Ignition or Fuel related - Vintage Mustang Forums This thread Refback April 20th, 2017 07:21 PM
At a loss for words on this one - Vintage Mustang Forums This thread Refback April 19th, 2017 09:19 AM
Front Suspention Recommendations for 67-68 - Vintage Mustang Forums This thread Refback April 16th, 2017 10:08 PM
69 mustang with 6R80 tranny/ Driveshaft? - Vintage Mustang Forums This thread Refback April 16th, 2017 06:57 PM
Thumbs up to MSD Service. - Vintage Mustang Forums This thread Refback April 13th, 2017 10:15 AM
'65 Front brakes - bigger rotors or better pads? - Vintage Mustang Forums This thread Refback April 12th, 2017 01:06 PM
What did you do to/for your Mustang today? - Page 116 - Vintage Mustang Forums This thread Refback April 11th, 2017 09:15 AM
About to set this car on fire - Vintage Mustang Forums This thread Refback March 29th, 2017 02:43 PM
What did you do to/for your Mustang today? - Page 114 - Vintage Mustang Forums This thread Refback March 22nd, 2017 08:34 AM
MTF One Piece Headliner Install - Vintage Mustang Forums This thread Refback January 29th, 2017 11:08 AM
Front drums off a 68, freshly rebuilt - Vintage Mustang Forums This thread Refback December 25th, 2016 09:51 AM
1968 Grabber Blue V8 4spd coupe - Vintage Mustang Forums This thread Refback December 23rd, 2016 02:54 PM
My 1968 Coupe trans-am tribute project - Page 14 - Vintage Mustang Forums This thread Refback December 14th, 2016 11:36 AM
Fuel Pressure Regulator - Vintage Mustang Forums This thread Refback December 13th, 2016 01:04 AM
671 blower - Vintage Mustang Forums This thread Refback December 12th, 2016 10:07 AM
SAVE 10% on Street or Track products! - Page 5 - Vintage Mustang Forums This thread Refback December 1st, 2016 11:48 AM
Where to look for your first classic? - Vintage Mustang Forums This thread Refback November 24th, 2016 08:04 PM
