Wyatt's 97 Cobra "Ashley" - Page 7 - Forums at Modded Mustangs
 9Likes
post #121 of 147 Old November 10th, 2015, 02:29 PM Thread Starter
Formerly whyxitx
HiMyNameIsWyatt's Avatar
iTrader: 8 reviews
Don't say that! .
I also got my MM quadrant and firewall adjuster put in last night too. Getting the pawl out was a pain.
1997 Cobra - 4.10s , UPR x pipe , Magnapacks, Maximum Motorsports K Member, A Arms, C/C Plates, LCAs and Coil Overs. S/S Brake lines. Needs put together.
2006 Ninja ZX-6R
2004 Subaru Forester XT - STI Goodies.
HiMyNameIsWyatt is offline
post #122 of 147 Old December 14th, 2015, 09:49 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
Man i really haven't worked on this a whole lot in a month.. Car is coming along pretty smoothly. I replaced the rear main seal a couple of days ago and began reinstalling the flywheel and the clutch. A nice pointer for the flywheel.. if you can't remember what position it goes on, there are 2 extra holes that are not used that will show up on the rear of the crank shaft. These holes make the end of the crank dirty and will show you where you need to align your flywheel up!
I got my rear suspension all mocked up and ready to go. I should be able to slap the rear wheels on soon. Front suspension needs to be tweaked still, but that's a job for another day/week/month.
I got my brakes bled for the most part. Will need to do some more bleeding but it works for now and i chased down a couple of leaks that were at the ABS block.
Got my tranny back together and replaced the TOB retaining sleeve. If i wouldn't have lost a bolt to my pressure plate i could have had my transmission mounted back onto the engine! But, since i lost a bolt, i'm waiting on my order from AM to get here so i can get back to work. If all goes well, i should have the engine and transmission back in the car during winter break. I started my new job and will be working 8-5 M-Fri which is going to be AWESOME.
townaj likes this.
2006 Ninja ZX-6R
post #123 of 147 Old December 15th, 2015, 05:08 PM
Broke as F*ck!!
townaj's Avatar
You've done a lot more work in the last month than I've done in 3 haha
Black 2003 Cobra
Turbos in progress.
Twin Turbo Cobra Build
townaj is offline
post #124 of 147 Old January 13th, 2016, 12:37 AM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
It's January and it's cold as fuck here so I haven't been able to do much of anything. Tranny is bolted to the motor and I should be able to drop it in the next time I have a niceish day. My old phone Shit out on me so I lost all of my pictures that I took unfortunately.
2006 Ninja ZX-6R
post #125 of 147 Old January 31st, 2016, 01:32 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
So...uhh...
Sent from my LG-H810 using Tapatalk
2006 Ninja ZX-6R
post #126 of 147 Old January 31st, 2016, 09:03 PM
the U of A
paulyboy928's Avatar
baller!
2011 GT | M6 | Brembo | 3.73 | Sterling Grey Metallic | Bravado Tributes | MPSS | BMR Suspension | MGW Race Spec | Mach 500 + Lightened Flywheel | Lund Tune | Ported Boss IM | Steeda CAI | Jegs Cat Deletes | GT-500s | M50A1 Long Block | MT-82 #2
paulyboy928 is offline
post #127 of 147 Old February 8th, 2016, 01:12 AM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
So i figured i would give a little bit of an update. Things are going decent! I might have to pull the dash for the heater core but that's another project for another...year. Picture time!
All my accessories are all mounted up i believe. Got my A/C and Powersteering all hooked up. There are a couple brackets that i can't remember where they go so i will have to do some more research on them.
My oil filter relocation mounted! I think it worked out fairly slick. Had to use some washers to space it out enough so i can still access my fog light.
Stifflers tranny crossmember installed. I cleaned the underside of the car and it is looking much better than it was before.
Driveshaft installed! i have a complete drive train in the car now. I haven't had one for almost a year and a half.
Basically, that's all i have to offer at the moment. I only get to work on it one day a week as it sits. Hopefully i will have all the wiring put back in and mocked by up next weekend.
2006 Ninja ZX-6R
post #128 of 147 Old March 1st, 2016, 12:40 AM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
It's late and i need to post an update.
My seats are in! GT500 seats straight out of rainbows corn hole.
I need to make brackets for them to fit my car, which i should be tackling this weekend if the weather permits.
I mocked up the front bumper because i haven't seen her with a face in forever.
I"m really close. I need to fine-tune the suspension. Run my S/S lines for my oil filter relocation. Fill her up with oil. Siphon the tank and put new gas in her and hopefully she'll be ready to start.. i'll post a more updated update in a couple days when i have the time to sit down and check it out in depth with more pictures.
townaj likes this.
2006 Ninja ZX-6R
post #129 of 147 Old March 1st, 2016, 10:55 AM
Cruising the backroads
Lariat's Avatar
Saw car in person. 10/10 would bang.
paulyboy928 likes this.
You only got one nom nom. One nom or two nom nom. Only one nom.
GO GO POWER RANGER!
Lariat is offline
post #130 of 147 Old March 1st, 2016, 12:57 PM
You had one job!
TCStang's Avatar
Looking good!
1968 Coupe- Sold
2007 Premium GT- Sold
MY CO BUILD
TCStang is offline
post #131 of 147 Old March 1st, 2016, 07:57 PM
the U of A
i feel like this car has been worked on since i joined the forum lol. glad to see it coming together!!
post #132 of 147 Old March 7th, 2016, 02:13 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
September of 2014 is when i started pulling her apart! Brackets are a pain in the ass to make for the S197 seats when your welder is halfway across town. My AN fittings should be here sometime this week. I hope to get oil in it and get it started up by next weekend. *crossing my fingers*
2006 Ninja ZX-6R
post #133 of 147 Old March 8th, 2016, 02:23 AM
Goose!'s Avatar
I got ride in the car once. 2 years ago.
Haha
2000 V6 - Turbo
2005 Tahoe LT - DD
1994 GT - Parting Out
1998 GT - Parting Out
1995 GT - SOLD
Insta :@Southfour6[/CENTER]
Goose! is offline
post #134 of 147 Old March 8th, 2016, 07:58 AM
Lariat's Avatar
He had issues with a "rubber o-ring" when i was there. Lol, just when you get to drive it, keep it AWAY frommthe deer in the first 2 miles of drive time.
GO GO POWER RANGER!
Lariat is offline
post #135 of 147 Old March 8th, 2016, 12:11 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
It's filled up and no coolant leaks.. Waiting to see if the heater core is fucked or not . an fittings should be here this weekend so I can run my oil lines and get it filled up.
2006 Ninja ZX-6R
post #136 of 147 Old March 8th, 2016, 12:17 PM
Still slow.
1996 GT's Avatar
Looking good! Lots of work being put in.
HiMyNameIsWyatt likes this.
1996 GT is offline
post #137 of 147 Old March 8th, 2016, 03:16 PM
Broke as F*ck!!
townaj's Avatar
Not enough work if you ask me...
Trollololol
Black 2003 Cobra
Turbos in progress.
townaj is offline
post #138 of 147 Old March 8th, 2016, 03:51 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
Trollololol
2006 Ninja ZX-6R
post #139 of 147 Old March 16th, 2016, 08:40 PM Thread Starter
Formerly whyxitx
iTrader: 8 reviews
Alright guys i have not taken a whole lot of pictures but i figured i would post an update...
The car is......running! But there have been some hiccups along the way. I am using the red monster's COP conversion harness and something isn't wanting to work with my car and the harness because it is not firing up with the harness connected. With the coil packs and wires, the car is running. He has been very helpful and i need to send the harness back to him for an inspection.
MM's oil filter relocation kit is not labeled "In/Out" on their ports. If you mix these up.. you will not get oil pressure. I mixed these up and had one hell of a time trying to figure out what was going on. Luckily, it didn't mess my car up (that i know of). No shavings in the oil. Woot!
*Insert video later of start up*
Basically the car is almost ready.. need to tune the suspension up and try to get the car pieced back together. I'm excited.
2006 Ninja ZX-6R
post #140 of 147 Old April 10th, 2016, 09:26 PM
Damn, nice build and that supercharger though hummina hummina
tbayarea is offline
