Winter car storage - Page 2 - Forums at Modded Mustangs
post #21 of 58 Old October 13th, 2014, 06:36 PM
Moderator
03SonicBoom's Avatar
Originally Posted by Supra View Post
It can become acidic over time. You could do a PH level test to get an idea.
Buddies delorean had a coolant leak under the intake manifold, coolant sat in the valley there for god knows how long and it ate the aluminum block. Little pin holes everywhere
Yes it can become acidic. You can also measure the voltage between the coolant and the negative battery terminal. But if the coolant good enough to drive around with, it's going to be fine to sit for a winter.
Like I said, everyone will have their own way of winterizing a vehicle and justified however they can. The truth is with modern cars, if you stay up with regular maintenance then winterizing probably isn't a huge issue.
03SonicBoom is offline
post #22 of 58 Old October 13th, 2014, 07:08 PM
gtscrewd
faym 08's Avatar
Put stabil in 3/4 tank drive home put on lift battery tender up she goes.
---------- Post added at 07:08 PM ---------- Previous post was at 07:06 PM ----------
Changing coolant is overkill IMO
July 2013 rotm winner
faym 08 is offline
post #23 of 58 Old October 13th, 2014, 07:42 PM
SlowFiveOh
Supra's Avatar
I'm always hesitant to use stabilizer. Esp after finding it developing little white flakes in the fuel and plugging everything up. My boss ran in to the same issue with his snowmobile, thought it was his fuel tank or lines degrading and plugging up the fuel filter/carbs, but again it was the stabilizer.
Premium fuel with no ethanol is 100% fine, no need for stabilizer. Run a little isopropyl in the first tank or two to rid of any potential moisture and continue on with life
2013 5.0 / Roush TVS 82mm / VMP Twin 67mm TB / ID1000's /JPC Longtubes / Kooks AB's / 1 piece aluminum DS / BMR Suspension + Strange struts/shocks
Instagram ~ @slowfiveoh
Supra is offline
post #24 of 58 Old October 13th, 2014, 08:02 PM
I love to skydive
Durr4456's Avatar
Man, storing the car must suck.
MM is awful. Don't ever come here if you haven't been sucked in already!
Durr4456 is offline
post #25 of 58 Old October 13th, 2014, 08:05 PM
foxfive's Avatar
The only benefit of having to store your car is it gives you down time to work on things and it also you have something to look forward to in the Spring. Your car is more fun to drive when you can't get in it every day.
foxfive is offline
post #26 of 58 Old October 13th, 2014, 08:11 PM
Turbo > blower
Towelie's Avatar
Originally Posted by 03SonicBoom View Post
Please go into some detail on this because it sounds like hear say passed from forum to forum as a fact. Do you have any actual information to back up this claim?
I've had the same coolant in my Jeep since I bought it (4 years ago) w/out any problems. I also checked the antifreeze bottle and I don't see a shelf life. If it would break down over time, there should be a shelf life on the bottle.
Learning Coolant Fundamentals
Cooling System Electrolysis Corrosion
Turbo build thread
sig by xocolleenox
Convertible Crew #27
Towelie is offline
post #27 of 58 Old October 13th, 2014, 08:31 PM
Moderator
Where do you find fuel w/out any ethanol? I would agree it would be great to use if you can find it because ethanol absorbs water. The only place around here I find it is the marina at $6/gallon. That's all I run through the boats but I still put Stabil in them. Trying to start up a carb boat motor after winter w/out Stabil sucks. Ever since I started using Stabil, it starts right up and that's why I use it on everything that gets stored (mowers, snow blowers, etc).
What you've just provided says it wears out because the corrosion inhibitors coat the passages and an explanation of electrolysis. Thus, storing an engine over the winter would mean your coolant would last longer. First, you're not circulating coolant for many months so you're not wearing it out. Second, there's no battery connected during the winter months so there's no electrolysis.
So yes, you should change your coolant on some sort of regular interval. But there's not need to specially change it just for winter storage.
post #28 of 58 Old October 13th, 2014, 08:36 PM
'Murica
jdmpwr07's Avatar
Truth, all around season driving FTW.
2009 Chevrolet Corvette
jdmpwr07 is offline
post #29 of 58 Old October 13th, 2014, 08:50 PM
better than clockWise
xkape's Avatar
I was under the impression jacking your car up for the winter screwed with the suspension. I don't know.
I just bring mine into the garage with a tank of gas, change the rims/tires to other ones, stick it on a tender, toss the car cover on and call it a day.
xkape is offline
post #30 of 58 Old October 13th, 2014, 09:40 PM
foxfive's Avatar
I've done it with all my cars and haven't had any issues with the suspension.
foxfive is offline
post #31 of 58 Old October 13th, 2014, 09:51 PM
Woodman's Avatar
Originally Posted by Towelie View Post
the thing with the coolant, that it breaks down over time and will cause the aluminum to corrode. If im gonna leave it sitting i want some fresh stuff in there.
I get that, but coolant doesn't go bad in a year, or often even in two. Use a coolant checker to make sure it's in good shape, and if it's good, it's good. I have an issue throwing an extra $50 a year at it for 3 months of storage.
woodman: achieving the impossible since 1967. 1973? 1980? 1985? 1976? whatever, you get my point
ford's advertising slogan was literally "you can pay for all of it today or you can go fuck yourself"
Woodman is offline
post #32 of 58 Old October 13th, 2014, 09:59 PM
BWAL's Avatar
Ethanol-free gas stations in the U.S. and Canada
'65 Fastback
'89 LX 5.0
'90 LX 5.0
'92 LX 5.0
'92 LX 5.0
'97 Cobra
BWAL is offline
post #33 of 58 Old October 13th, 2014, 09:59 PM
Basically nothing. There are always a few nice days during winter that I can drive a quick lap around town!
My03Gt is offline
post #34 of 58 Old October 13th, 2014, 10:04 PM
Certified Bwaloligisit
Mach Stang!'s Avatar
I just park it in the garage. Add some Stable or STP fuel shit in there to keep the gas fresh. They say to have at least a half a tank when doing that. Also you dont want really any less than that so that moister doesn't build in the tank,
-Rocco
Mach Stang! is offline
post #35 of 58 Old October 13th, 2014, 10:25 PM
PhD in Procrastinology
1BDSTNG's Avatar
I'm more likely to store my fox for the summer...no A/C
1991 GT- 347ci
2014 GT/CS
Instagram: @1bad_5oh
Originally Posted by Imran View Post
i clamp it with my teeth and hold it in my mouth.
1BDSTNG is offline
post #36 of 58 Old October 13th, 2014, 10:27 PM
I live without AC. Hardly used it in the car.
-Rocco
post #37 of 58 Old October 13th, 2014, 10:33 PM
GreenShift's Avatar
Yeah but no AC in Texas in the summer is like having no heat in Ohio in the winter. Maybe youll be fine but it sure as hell wont be comfortable.
GreenShift is offline
post #38 of 58 Old October 13th, 2014, 10:48 PM
true lol
-Rocco
post #39 of 58 Old October 14th, 2014, 12:19 AM Thread Starter
Pawsitively sexy
Sixpointslow's Avatar
Well I just replaced the radiator in May, and obviously it's pretty fresh coolant, so I'll probably just do an oil change, hook up the battery maintainer, and park it on carpet in the garage with a full tank of gas and some stabil. I appreciate the input guys.
Delaware is a fucking abyss of only E10 gas... At least if we can't get any ethanol free gas, we could get some E85...
2012 CTS-V
Not stock
Sixpointslow is offline
post #40 of 58 Old October 14th, 2014, 01:11 AM
sev
sev's Avatar
This. Might not drive it for a few weeks, but I can find a day where I can drive it around my (country) block a few times
sev is offline
