99 GT Vert Build Thread - Forums at Modded Mustangs
 3Likes
post #1 of 168 Old January 7th, 2015, 09:43 PM Thread Starter
46L281GT's Avatar
So I figured that I would start one of these. Even if nobody views it, I will use it to keep progress of the build. Should be a fairly short build. I would really like to have it finished in the late spring/early summer so here goes:
Alright fellas, I guess I should start with the history of the vehicle. It is a 1999 Mustang GT Convertible Rio Red with a Charcoal Convertible top. The vehicle was purchased at Alton Blakley Ford in Somerset, KY with 82,000 miles in April of 2012. At the time I was driving 100 miles round trip to work and back so I racked up the miles (about 40,000 miles in a year). When I purchased it, all that was done was Flowmaster weld ins, drop in K&N filter, and headlight covers. Nothing at all had been done prior. Since the purchase i have added wheels, CAI, Tune, Headlights, Short Throw shifter, different radio and audio system, and sequential tail lights. The car currently has 130,200 miles and has been promoted from daily driver to weekend warrior.Current mileage a year is about 5,000.
Now for the mods to be added. (If there is something I should change please bring it to my attention since this will be my first FI build.)
I know that I have added just about every nut and bolt that I have bought, but I wanted to do this to show how it adds up quickly and try to show every single item that you might need. Below is a link to an excel spreadsheet that makes this long list of parts a little easier to read.
https://www.dropbox.com/s/x1436l4wfa...nses.xlsx?dl=0
I purchased the Procharger P1SC, 2 Core Intercooler, Procharger BOV, and a couple of Misc. tubing pieces for $750.00 shipped to my doorstep on January 7, 2015. Was originally on a v6 mustang and was told that it was only installed for 4,000-5,000 miles.
Main Bracket Assembly for 99 GT part #3fdbb-002 $266.00
ProCharger Superchargers, centrifugal supercharger kits for cars, trucks, motorcycles and marine applications.
3.5" Pulley 6 Rib $90.00
ATI Oil 3 Pack $35.00
BOV Diaphram replacement $15.00
Drain Line Kit $50.00
Inlet tube I'm going to make with pieces from Intercooler Pipe Fabrication
I was able to find a stock procharger inlet tube on another area of classifieds for 50 dollars shipped.
CXRacing 3" Intercooler Piping Kit Mustang $99.00
Cxracing 3" Intercooler Piping Kit Mustang Accord Pipe | eBay
SCT BA5000 MAF Sensor $230.00
Bought from tuner
Ford Mustang Mass Air Flow MAF pigtail $32.00
Ford Mustang Mass Air Flow MAF Pigtail 2005 and Newer | eBay
Airaid 9601 MAF Sensor Tube $59.90
Airaid 9601 MAF Sensor Tube | eBay
AEM 320 High Flow Fuel Pump $99.99
AEM 320 High Flow Fuel Pump - Justin's Performance Center
Ended up ordering this from summit racing since they offered free shipping and the install kit was included.
http://www.summitracing.com/parts/avm-50-1000
42 lbs injectors $160.00
The Corral
Steering Column Mount Single Gauge Pod $34.97
http://www.summitracing.com/parts/at.../model/mustang
PLX DM-6 Gauge and Wideband $179.99
PLX Mustang DM-6 Gauge and Wideband Air/Fuel Module Sensor Combo Kit 102107 (79-10 All) - Free Shipping
PLX Vacuum/Boost Sensor $94.99
PLX Mustang Vacuum / Boost Sensor Module 102111 (79-14 All) - Free Shipping
SCT X3 Tuner $220.00
SVTPerformance
6 Rib Drive Belt $22.80 (Note that I have a Windsor motor so the belt is different for other year models)
Fuel Injector O-Ring Set (4) $10.38
Felpro Fuel Injector O-Ring Set ES 70599: Advance Auto Parts
NGK TR6 Spark Plugs (8) $11.38
NGK V-Power Spark Plug 4177: You?ve found the best Spark Plug at Advance Auto Parts
Pack of 10 T-Bolt Clamps $24.95
Fuel Line T-Bolt Clamps $5.96
Gates 27097 Submersible Fuel Line Hose $19.57
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
3 inch Blue Silicone Hose 90 Degree Coupler (2) $22.00
3" Aluminum Pipe Joiner $11.98
Dyno Tune from Chicken Hawk Motorsports $350.00
Home
1999 Mustang GT 5 Speed Vert
Procharger P1SC @ 9 psi
382/382 STD
Tuned by Chicken Hawk Motorsports
Supercharger Build Thread: https://www.moddedmustangs.com/forums...ld-thread.html
46L281GT is offline
post #2 of 168 Old January 7th, 2015, 10:02 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Looks good so far however I would highly recommend a dyno tune or a remote tune with data logging.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
[email protected]@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #3 of 168 Old January 7th, 2015, 10:25 PM Thread Starter
46L281GT's Avatar
Actually the tune that i mention in the build sheet is a dyno tune, sorry i didn't specify.
382/382 STD
46L281GT is offline
post #4 of 168 Old January 8th, 2015, 08:51 PM Thread Starter
46L281GT's Avatar
Supercharger, BOV, misc. tubing, inlet tube, and other small pieces shipped should arrive Monday!
382/382 STD
46L281GT is offline
post #5 of 168 Old January 8th, 2015, 09:17 PM
Nice man! I'll be following along here. I plan on running a similar set up on my 02 GT.
hammer925 is offline
post #6 of 168 Old January 8th, 2015, 09:35 PM Thread Starter
46L281GT's Avatar
Thanks hammer, I hope it helps a bit. Most of the remaining parts won't be purchased until tax time but I have a little bit of spending money to shop around with once I inspect the kit that I receive to make sure that it is all okay and no physical issues. Don't want to buy all these parts if it's not the way it was described. I'm 99% sure it will be but you never know better to be safe than sorry
382/382 STD
46L281GT is offline
post #7 of 168 Old January 9th, 2015, 01:22 AM
macuser27's Avatar
FI is sweet! Are there any plans for the suspension/chassis/rear end?
1999 GT Dark Green Satin
macuser27 is offline
post #8 of 168 Old January 9th, 2015, 03:29 AM
I know what you mean man. Im in the same boat lol. Where did you find the procharger at?
post #9 of 168 Old January 9th, 2015, 09:08 AM Thread Starter
46L281GT's Avatar
found it on corral classifieds for sale at 900 ended up getting all in the description above for 750 after talking to the guy on the phone. No plans currently for any supporting mods, I do have a heavier clutch that I installed when mine went out. I had put a stage 2 excedy in thinking that I probably would go FI. I would like to upgrade the rear suspension eventually and FLSFCs are in the near future for this car especially since it is a convertible. I plan on making it a garage queen/weekend warrior and street driving only so I hadn't really looked at the rear end in terms of 31 spline or anything like that, I do have 3.73s though.
On another note, if anybody knows someone that needs a diablo predator and currently has a SCT let me know. Would rather have the X3 instead of the X4 since I've heard of a few data logging issues. The tuner I'm going to only does SCT so the predator has to go.
382/382 STD
46L281GT is offline
post #10 of 168 Old January 9th, 2015, 09:08 PM
Nice man that's a solid deal. I actually seen that on corral too and messaged the guy but I was obviously too late lol.
post #11 of 168 Old January 12th, 2015, 07:53 PM Thread Starter
46L281GT's Avatar
Alright all, i received the Head Unit, intercooler, bov, and inlet tube. From what you can see, is there anything else I'll need to finish the build? I'm super excited to get this thing on!
ID:	133017   Click image for larger version
382/382 STD
46L281GT is offline
post #12 of 168 Old January 13th, 2015, 04:06 PM
Not sure if you're missing anything else, but is that AEM 320 fuel pump a direct replacement? Or is some modification needed that you know of?
post #13 of 168 Old January 13th, 2015, 04:41 PM Thread Starter
46L281GT's Avatar
i plan on following this guide to install it. looks like it shouldn't need much modifying to make it work.
https://www.moddedmustangs.com/forums...all-guide.html
---------- Post added at 03:41 PM ---------- Previous post was at 03:31 PM ----------
Just purchased 42 Lb injectors for $160. Should be here next week.
382/382 STD
46L281GT is offline
post #14 of 168 Old January 13th, 2015, 04:54 PM
Cool man thanks for the info. The more I linger around this site, the better it gets lol. Everyone is so helpful.
What kind of power goals do you have after the build?
post #15 of 168 Old January 13th, 2015, 04:58 PM Thread Starter
46L281GT's Avatar
Anytime! I plan on keeping the stock bottom end so my goal is 400 or just a hair under.
382/382 STD
46L281GT is offline
post #16 of 168 Old January 13th, 2015, 05:10 PM
Same here my friend. I think 400 is plenty for a fun time tearing up the streets
post #17 of 168 Old January 13th, 2015, 08:40 PM
5rand0n7's Avatar
Cool man! Can't wait to see how it comes along! Would be interesting to compare our numbers when you and I get done.
Vortech v3, 3.33" Pulley, CX Racing FMIC, DIY Power Pipe, SAE Corrected: 404rwhp/397rwtq @10psi and 16* of timing
5rand0n7 is offline
post #18 of 168 Old January 13th, 2015, 10:37 PM Thread Starter
46L281GT's Avatar
I agree they should be pretty darn close
382/382 STD
46L281GT is offline
post #19 of 168 Old January 15th, 2015, 05:58 PM Thread Starter
46L281GT's Avatar
Will a 98 bracket fit my 99?
382/382 STD
46L281GT is offline
post #20 of 168 Old January 15th, 2015, 06:25 PM
5rand0n7's Avatar
I think 99-04 stangs have different timing covers but I can't be for sure. If you don't get a more confident answer, post in 99-04 forum to see if someone with more knowledge can help you. OR call procharger. They should be able to help you out for sure.
5rand0n7 is offline
