MM daily chat thread v2.0 - Page 783 - Forums at Modded Mustangs
 6887Likes
post #15641 of 19134 Old September 28th, 2018, 11:53 AM
PSN alphadong11
dr.gonzo!'s Avatar
And yeah, some of them are alive
dr.gonzo! is offline
post #15642 of 19134 Old September 28th, 2018, 12:19 PM
Powered by LSx tears
69fastback's Avatar
Craig are you still using the uflymike?
Rachel has one on her QC25 (IIRC) and it works incredibly well.
Also, I had chicken nuggets for dinner last night and it turned my stomach into whatever feeds Niagara falls.
I am. I'm using the QC15s with the ufltmike, and it does work well. I like them a lot better than the Aviation X's because I hate the clamp headband on the X's, plus they're heavy. I got my QC15s warrantied about a year ago (even though they don't make them anymore), because the battery tray messes up on them, and they no longer work. It's the third pair it's happened to and is a common issue. They're starting to mess up again, and Bose will no longer support them and force me to upgrade to the 25s, and then I'll have to buy another mic too. If you ever tell them you are using the QCs and the uflymike, Bose will no longer support, or warranty, your headsets because they want you buying the aviation headsets. I think this time I'd like to try the ones I linked, just because Bose will support them when they break, since I'm going to have to buy a new mic and everything.
Austin likes this.
I tell the truth. Deal with it.
69fastback is offline
post #15643 of 19134 Old September 28th, 2018, 12:42 PM
Troy McClure
WickedSnake00's Avatar
How your average NFL football player lives and left the apartment when he's cut from the team.
What is Lake Erie? Which is probably still more disgusting than what is in your stomach.
I wager Suck it Trebek.
INFORMAL POLL TIME.
What do with fox?
Option A:
2.3T swap. Throw SVO pistons, bearings and gaskets into the old motor, turbo manifold, intercooler, Turbocoupe ECU, VAM, used turbo, and run 20-25psi of boost for ~250hp.
Everything drops right in, little to no fabrication.
Bonus: If I decide that isn't enough I can get QH and tune the ECU. See what 25+psi does on E85.
Cost: ~$500-1000.
Option B:
350 SBO swap. New gaskets and bearings in the 350, new cam. Fabricate mounting brackets. Use old Jetaway transmission, extended yoke, new shifter. Put old carb'ed pickup in the tank.
Cost: ~$300-500
More fabricating work, especially if I can't get the driver's manifold to clear the steering shaft. But if people can shoehorn in 460s I ought to be able to do this.
Either way, I have both engines just sitting around waiting in the garage.
WickedSnake00 is offline
post #15644 of 19134 Old September 28th, 2018, 12:50 PM
Mississippi roolz
socialist's Avatar
Canadians?
---------- Post added at 09:50 AM ---------- Previous post was at 09:48 AM ----------
Option A:
Cost: ~$500-1000.
This would be more unique and cool. Like a hopped up 60's 200 I-6
socialist is offline
post #15645 of 19134 Old September 28th, 2018, 12:57 PM
69fastback's Avatar
INFORMAL POLL TIME.
What do with fox?
Option A:
Cost: ~$500-1000.
Option B:
Cost: ~$300-500
The answer is obvious.......
Option C:
SBF SWAP
post #15646 of 19134 Old September 28th, 2018, 01:46 PM
PSN alphadong11
dr.gonzo!'s Avatar
Fire hammer dumpster
---------- Post added at 12:46 PM ---------- Previous post was at 12:05 PM ----------
post #15647 of 19134 Old September 28th, 2018, 05:31 PM
Troy McClure
Option C:
SBF SWAP
Sure I'll take one of the spares you have just lying around taking up space then.
Sadly SBFs aren't nearly as cheap or plentiful as they used to be. Everybody wants an arm and a leg for a pile of parts that was once their 5.0.
Well to be fair there's plenty of turbo 2.3s running around. To my knowledge it would be the only SBO Mustang ever though.
...and with me having a junkyard 2.3T that would make me arummel 3.0. And I don't think @xocolleenox would like that very much.
post #15648 of 19134 Old September 28th, 2018, 05:43 PM
69fastback's Avatar
https://www.youtube.com/watch?v=r861P1CqZeY
I gave $2K for my 331. Performer RPM heads, AD Performance stroker kit, Perfomer RPM intake, brand new, never fired, all new parts.
post #15649 of 19134 Old September 28th, 2018, 06:49 PM
PSN alphadong11
dr.gonzo!'s Avatar
post #15650 of 19134 Old September 28th, 2018, 08:17 PM
Troy McClure
That's a smoking deal. I can't get a worn out stock one for $1500.
Have you guys had pizza logs before? I didn't realize they were a regional thing.
Someone in Buffalo had an egg roll and said - "You know, this wouldn't be bad if we took out all the vegetable bullshit and stuffed it with pizza instead. And then replaced the sweet and sour sauce with marinara."
post #15651 of 19134 Old September 28th, 2018, 08:40 PM
iTrader: 8 reviews
Never heard of them but they do sound good.
BA Mustang is online now
post #15652 of 19134 Old September 29th, 2018, 12:44 AM
PSN alphadong11
dr.gonzo!'s Avatar
Taste like chicken, if chicken was a candy.
post #15653 of 19134 Old September 29th, 2018, 12:57 PM
Troy McClure
You see, no one is around or posting.
socialist likes this.
post #15654 of 19134 Old September 29th, 2018, 01:35 PM
PSN alphadong11
dr.gonzo!'s Avatar
I'm running a space heater in the bathroom. Neighbor has AC on.
post #15655 of 19134 Old September 29th, 2018, 01:37 PM
iTrader: 8 reviews
I'm watching Live PD instead of cleaning the house
post #15656 of 19134 Old September 29th, 2018, 02:46 PM
PSN alphadong11
dr.gonzo!'s Avatar
Real life sound https://9gag.com/gag/aZLqxp3
post #15657 of 19134 Old September 29th, 2018, 04:00 PM
Troy McClure
You're gonna make a tornado.
post #15658 of 19134 Old September 29th, 2018, 05:30 PM
PSN alphadong11
dr.gonzo!'s Avatar
My whispering eye
post #15659 of 19134 Old September 29th, 2018, 07:36 PM
Troy McClure
Niagara Falls: "You know, this wouldn't be bad if we took out all the vegetable bullshit and stuffed it with pizza instead. And then replaced the sweet and sour sauce with marinara."
Also Niagara Falls: We should dump toxic chemicals in a canal.
...and then build a school on it.
...and then build residential homes on it.
...and breach the containment with all kinds of construction.
Yeah.
Also Niagara Falls: Let's go steal some steak to sell on the street.
...and then drive away. Drunk.
...while carrying a bunch of drugs.
Niagara Falls (NY)- Come here for the waterfalls...
...stay here because you got robbed.
Tolls are $7.50 to enter or leave.
post #15660 of 19134 Old September 29th, 2018, 08:09 PM
PSN alphadong11
dr.gonzo!'s Avatar
Studies say there are fewer post because there are fewer people posting.
