Jumped ship, now own an LSx... - Page 8 - Forums at Modded Mustangs
 84Likes
post #141 of 170 Old January 6th, 2019, 01:14 AM
Pawsitively sexy
Sixpointslow's Avatar
How was the aux fuel kit? Good quality? I'm making just over 650whp since the cam on pump and I need to either do this aux kit or go with a fore system to run e85.
2012 CTS-V
Not stock
Sixpointslow is offline
post #142 of 170 Old January 6th, 2019, 01:25 AM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
My friend is making more hp than you and has run the DSX Caddy setup on stock CTSV Pump no issues.
If you run the DSX Flex sensor, youíll need injector to go with the pump.
I think he went from ID850ís to ID1050ís to run e85.
Sent from my iPhone using Tapatalk
2010 CGM Camaro 2SS RS 6L90
Stage II ProCharger D1X
760rwhp @ 14 PSI
JohnC is online now
post #143 of 170 Old January 7th, 2019, 12:54 AM
Pawsitively sexy
If you run the DSX Flex sensor, you’ll need injector to go with the pump.
I think he went from ID850’s to ID1050’s to run e85.
I've already got 1050's so that's no issue. My end goal is 800whp boost only. Just don't want to have this aux pump fail on me down in Mexico.
2012 CTS-V
Not stock
post #144 of 170 Old January 7th, 2019, 08:33 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
3.9Ē pulley it made 723rwhp @ 12psi on 93 pump has with timing dialed way back to 13 degrees peak.
Shop said e85 will be around 800rwhp.
T-Lee. 30 and Sixpointslow like this.
760rwhp @ 14 PSI
JohnC is online now
post #145 of 170 Old January 8th, 2019, 08:20 AM
ZEN357's Avatar
I did the same thing about a year ago. Went from an 01 Bullitt to a 2016 Challenger R/T Plus Blacktop Edition. Challenger runs circles around the Bullitt.
JohnC likes this.
ZEN357 is offline
post #146 of 170 Old January 8th, 2019, 01:18 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
He said I was going to run out of injector.
Went to ID1300's for overkill so I can stop buying expensive injectors.
760rwhp @ 14 PSI
JohnC is online now
post #147 of 170 Old January 8th, 2019, 08:22 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Final #ís
T-Lee. 30, Sixpointslow and ZEN357 like this.
760rwhp @ 14 PSI
JohnC is online now
post #148 of 170 Old January 9th, 2019, 11:51 AM
ZEN357's Avatar
Final #ís
Nice Ride Bro!!! Here's what I ended up going to after my 01 Bullitt.
JohnC and Sixpointslow like this.
ZEN357 is offline
post #149 of 170 Old January 9th, 2019, 04:55 PM
T-Lee. 30's Avatar
Send a message via Yahoo to T-Lee. 30
Final #ís
Nice numbers and project! Question for you I see you built the top end and have a cam in there but are you still running a stock bottom end?
-03 GT V1S trim 5psi, 3xxhp/3xxtq
-06 TBSS LS3H,cam,f.exhaust 4xxrwhp/4xxrwtq
-03 Dakota SLT Quad cab 2wd stock
Iraq and Afghanistan War Vet . Convoys and convoy security. My Wife is also a Army and Afghanistan war vet.
T-Lee. 30 is online now
post #150 of 170 Old January 10th, 2019, 02:49 AM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Itís still a stock bottom end L99.
I asked my tuner how much HP the stock bottom ends could take and he told me 1,000.
Itís more or less all in the tune if they can take it or not.
Any detonation on boost and itís not going to live.
You might survive some lite detonation with a forged short block, but no engine will take sustained detonation for long under a lot of boost.
I watch my AFR wide bands like a hawk and I listen for any cutout or breaking up in the exhaust as well as feeling power loss.
Any of that and I will lift quick!
---------- Post added at 03:49 AM ---------- Previous post was at 03:48 AM ----------
Time for a blower?
760rwhp @ 14 PSI
JohnC is online now
post #151 of 170 Old January 10th, 2019, 10:02 AM
T-Lee. 30's Avatar
Gotcha thanks for the info on that bc I was kinda curious on what that stock bottom end could handle but you covered it.
post #152 of 170 Old January 31st, 2019, 07:16 AM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Trans is not happy with the new power.
It started slipping at WOT.
I knew the 6L80 would be on borrowed time, but had no idea it would die this quick!
I'm hunting for a built 6L90 now and will go custom length drive shaft.
Looking at a new multi disc/billet converter too.
760rwhp @ 14 PSI
JohnC is online now
post #153 of 170 Old February 1st, 2019, 10:54 AM
Powered by LSx tears
69fastback's Avatar
Converter is everything. It’s the most important piece that you can buy in the whole combination.
It still won’t keep it from sounding like a fart in a megaphone though, or any of the other issues that come with owning a poorly built plastic machine.
socialist likes this.
I'll toss that dude's salad
69fastback is offline
post #154 of 170 Old February 5th, 2019, 09:47 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Got a Stage 2 Tim King / TK Performance built Cadillac CTSV 6L90E that is 1,000hp capable.
A custom Driveshaft Shop 3.5Ē Aluminum 1 piece DS.
Circle D 3400 Pro III Billet multi disc converter.
BMR Driveshaft Safety Loop Black Hammertone
Should be a nice setup that will hold power and last if I can find a good trans tuner.
Working on getting larger trans cooler, trans mount, and trans cross member.
---------- Post added at 10:47 PM ---------- Previous post was at 10:41 PM ----------
2012 CTSV 6L90 trans I bought for the core.
Really wanted to keep it as a spare since it was a good condition 42k mike takeout, but wanted that $1500 core charge back!
760rwhp @ 14 PSI
JohnC is online now
post #155 of 170 Old February 23rd, 2019, 01:15 AM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Got my Tim King @ TK Performance Stage II 1,000 HP built 6L90 along with the Circle D LS Series Pro Billet Triple Disc 3200-3400 stall.
Can’t tell much by the outside of the trans, but there it is.
---------- Post added at 01:14 AM ---------- Previous post was at 01:12 AM ----------
The DSS driveshaft came today...
---------- Post added at 02:15 AM ---------- Previous post was at 01:14 AM ----------
Trans cooler
Trans cooler mounts
Earls -6AN 20ft
Earls fittings and Bowler -6AN cooler manifold
BMR drive shaft safety loop
ZL1 trans cross member
With ZL1 trans support, cross member and DS loop
Sixpointslow likes this.
760rwhp @ 14 PSI
JohnC is online now
post #156 of 170 Old February 25th, 2019, 09:34 AM
ZEN357's Avatar
Did the same thing a while back. Went from 2001 Bullit to 2016 Challenger R/T. Love the 6-Speed.
ID:	203503   Click image for larger version
ZEN357 is offline
post #157 of 170 Old February 28th, 2019, 03:28 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Changed it up a bit...
Oil cooler with fans showed up...
It’s 4.5” thick with the fans vs 2” without. So I’ll need some spacers to go with the mounting brackets to make it work.
Oil cooler thermostat
Fan wiring harness:
I have a cooler 1/8 NPT fan sending unit coming (160F-180F).
All the fittings I have so far. Still have a few shipping to me...
Real main seal and rear main cover gasket.
New valve cover gaskets. Only need to replace one side, so I’ll have a spare leftover.
A case of Dexron VI.
760rwhp @ 14 PSI
JohnC is online now
post #158 of 170 Old March 6th, 2019, 12:22 AM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
Picked up some front CTSV 6 piston Brembo brake calipers.
Going to do the vented Corvette pistons....
Thinking I will powder coat them...
Not sure on color yet.
760rwhp @ 14 PSI
JohnC is online now
post #159 of 170 Old April 9th, 2019, 10:52 PM Thread Starter
7.62x39 CO2 Cannon
JohnC's Avatar
And so it begins...
760rwhp @ 14 PSI
JohnC is online now
post #160 of 170 Old April 11th, 2019, 09:16 AM
ZEN357's Avatar
Got rid of the 1997 GT and got a low mile (16k mile) Camaro SS.
It's an L99 with A6 2SS RS package.
I think it's cyber gray if I recall correctly.
It was garage kept and hardly driven.
Damn thing still smells new.
Nice Ride! I jumped ship last year and bought a Challenger and sold my 2001 Bullitt.
ZEN357 is offline
