Parking Brake Light ON! - Forums at Modded Mustangs
post #1 of 15 Old February 14th, 2007, 08:53 AM Thread Starter
edmdi's Avatar
Send a message via MSN to edmdi
HI,
I have the parking brake warning light always on even when i release the parking brake. I have checked the fluid level, and it seems fine. What could be the problem? Is there any thing i can do to remove this.
I have a 2001 mustang V6
edmdi is offline
post #2 of 15 Old February 14th, 2007, 09:15 AM
mustang1072's Avatar
Send a message via AIM to mustang1072 Send a message via MSN to mustang1072
welcome to MM... i had that same problem with my 00... as odd as this my sound i changed a couple of my fuses and it turned off... its annoying ant it
mustang1072 is offline
post #3 of 15 Old February 14th, 2007, 09:26 AM
MM's Resident Ricer
GreenFaleen's Avatar
Does it drive like the break in on or when you turn i off does it turn off?
If the break isn't staying on it is probably a short if the break is staying engaged it is something in your P-break linkage.
NCMM #9
GreenFaleen is offline
post #4 of 15 Old February 14th, 2007, 09:31 AM Thread Starter
edmdi's Avatar
When i release the hand brake, it drives OK, the brake is not stock, but the light is on...When i engage the hand brake the car stops perfectly ...Which fuses have you changed?
edmdi is offline
post #5 of 15 Old February 14th, 2007, 09:32 AM
blown96stang's Avatar
Send a message via AIM to blown96stang
sometimes my e-brake stays on even when its not engaged cuz i turn my key to far forward in my ignition
MM Cobra Club #35
blown96stang is offline
post #6 of 15 Old February 14th, 2007, 09:39 AM
MM's Resident Ricer
If you can get to the wires just jiggle them lightly and see if it flashes if so you have a short.
NCMM #9
post #7 of 15 Old February 14th, 2007, 09:45 AM Thread Starter
edmdi's Avatar
This means its not a serious issue? the mechanical system is working fine and only some electronics and wiring need to bec checked out ! ... This is my first Mustang i used to drive Holden --> Commadore
edmdi is offline
post #8 of 15 Old February 14th, 2007, 10:07 AM
Juggalo_X's Avatar
don't worry your not going to die lol its either one of 2 things a short in the ebrake switch in the the center console, or your ebrake is seized and is not disengaging fully in the rear end so get the rear drum breaks checked.
Juggalo_X is offline
post #9 of 15 Old February 14th, 2007, 08:09 PM
Look Ma! My First Post!
I had this exact problem after my dad drove my car. what i found after a day of trying to figure out what was wrong was that some how he knocked the sensor off the break. on my 98 mustang there is a clip kinda that connects to the break and it was unhooked and that tells the lights to go on and off. so i would check under the dash where the break pad and make sure every thing is connected right. good luck
gioakjoe is offline
post #10 of 15 Old February 15th, 2007, 10:49 AM
Juggalo_X's Avatar
the sensor for the e-break is no located under the dash your issue was totally unrelated to this one please read more carefully it will help prevent confusion.. now the sensor to the emergency break is located inside the center console connected to the emergency break lever assembly.
post #11 of 15 Old February 15th, 2007, 10:53 AM
wraitherx's Avatar
iTrader: 13 reviews
check out your switch at the ebrake, make sure that it is not loose
1999 Ford Mustang SVT Cobra Built
2011 Ford Taurus SHO TT AWD
Originally Posted by Towelie View Post
he spent all the time
thinking about if it could be done, and not thinking about if it should be done
wraitherx is offline
post #12 of 15 Old February 15th, 2007, 11:30 AM
MM's Resident Ricer
As long as it is driving fine and the e-brake isn't staying engaged your fine.
NCMM #9
post #13 of 15 Old February 21st, 2007, 08:07 AM
ok so i too have a 98 mustang my brake light won't come on anyone know anything and how would i take the center console out.
markanthonymuns is offline
post #14 of 15 Old February 21st, 2007, 10:29 AM
The Shogun of Harlem
neckbonekat's Avatar
If the brake is not stock it sound like they forgot to hook up the sensor that controls the light.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
neckbonekat is offline
post #15 of 15 Old September 2nd, 2015, 07:43 AM
2008 Mustang Coupe
My Son has a V-6 coupe, 2008, that has the audible e-brake alarm and it won't shut off. I have checked the fuses, I tried to remove the fuse but then not able to shift out of park. Is there a way to disable the alarm?
Boss Man is offline
