91 GT Gunna Be The Death Of Me.Help ! - Forums at Modded Mustangs
post #1 of 2 Old June 9th, 2015, 09:57 PM Thread Starter
Look Ma! My First Post!
Ive been fighting power window problem for at least a month on and off.Passenger window will go down but not up.Ive replaced all window switches with new ones and tried a different window motor.Both leads to the motor are hot when pushing the up side of switch,only one lead hot pushing the down side.Ive tried all i know to try.Does anyone have any suggestions ?Please help me.TIA
r_u_the_king is offline
post #2 of 2 Old June 10th, 2015, 11:26 AM
fb93's Avatar
When you say switch are you referring to the buttons or the side with all the wires on it? If you only replaced the buttons, i would suspect the side with all the wires as being the problem. Using Fords terminology, the buttons are switches and the side with all the wiring is the master switch, or master window/door lock control switch. I always found that a little confusing.
fb93 is offline
