LED's dim when turning on and off - Forums at Modded Mustangs
post #1 of 4 Old November 14th, 2015, 10:24 PM Thread Starter
I was changing out my bulb for my turning signal when I noticed that my driver side LED headlight was dimmer than my passenger side. Confused, I checked the connections and everything was connected correctly. Unplugged the 9007 connector and plugged it back in and the light when back to being bright. I then turned off the lights to check and when I turned them back on the same thing happened. Could it possibly be a relay or something? Thanks for the help
Davidlee93 is offline
post #2 of 4 Old December 8th, 2015, 06:01 PM
MoNoLimit's Avatar
I would try some Dielectric grease on the connectors and make sure the pins are still locked in good Hope its nothing too serious
Lots of parts. Still Slow
MoNoLimit is offline
post #3 of 4 Old December 9th, 2015, 06:20 PM
Clippity clop
Are u using the LED upgrade kit as well or just LED bulbs? Wal-Mart sells a part that's basically located in the same area as the bulbs. It's supposed to stop them from cutting out. I just happened to see it last night. Just an idea.
CritterSnatch is offline
post #4 of 4 Old December 20th, 2015, 11:03 AM
chicoman's Avatar
Try swapping headlights left to right and see if the problem follows or stays with that headlight assy. Then you will know if it is in the car wiring or headlight set up.
1999 MUSTANG GT COUPE DARK SATIN GREEN,
VORTECH V2 TREADSTONE FMIC
chicoman is offline
