What Did You Do To Your GT Today? - Page 1002 - Forums at Modded Mustangs
 21Likes
post #20021 of 20258 Old May 9th, 2016, 07:45 AM
Long overdue project finished, I moved battery to trunk, moved/mounted PCM to inside the passenger front fender and rerouted engine wire harness through the fender. I also removed the wiper fluid reservoir. It took a lot of work and "MANY" beers but well worth the trouble.
ID:	183658   Click image for larger version
[COLOR="DarkRed"]
4.6L MMR Stroker,Whipple 2.3 HO w/10-rib drive, COMP Cams,60# Inj,GT500 T/B,FRPP Radiator,Pypes Headers,X-pipe,Stingers,TCI Trans & converter,DSS driveshaft,3.73 Gears,FRPP Struts/Springs,BMR Suspen,Roush LCA,Brembo Brakes
MSVR3 is offline
post #20022 of 20258 Old May 9th, 2016, 10:39 AM
^Nicely done. That looks really good. I should have done that when I was messing with my harness but I bitched out.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #20023 of 20258 Old May 9th, 2016, 10:50 AM
Thank you kindly... About half way through the project I started hitting my head asking why I was doing it but now that it is completed I can see that it was worth it.
[COLOR="DarkRed"]
MSVR3 is offline
post #20024 of 20258 Old May 10th, 2016, 09:23 AM
Resident Diabetic...
braupe's Avatar
I drove a 14 GT track pack.... back to back with my car... then quickly realized that I was utterly wasting my time on my 3v.
2006 GT ~C&L Racer~Steeda UDP~JBA LT~Pypes O/R X Pipe~Borla S-Type A/B~MGW Shifter~FRPP K Springs~Koni STRT.S~J&M Panhard Bar~3.73.
2011 F150 4X4 Lariat Coyote. Ball Cooling Seats. Gibson Dualsport.
2011 Explorer Limited.
braupe is offline
post #20025 of 20258 Old May 10th, 2016, 03:36 PM
Insomniac
BIGCHRISS197's Avatar
Boss rods and turbo kit braupe. Cheaper than a coyote and faster.
BIGCHRISS197 is offline
post #20026 of 20258 Old May 11th, 2016, 08:31 AM
braupe's Avatar
This is very true. That would be fun. Is it sad that i don't want to go turbo because I just installed long tubes?
braupe is offline
post #20027 of 20258 Old May 11th, 2016, 01:29 PM
You can do a turbo, it just takes some work to make the headers work. You can also do one of those rear mount stealth units.
07 Boss is offline
post #20028 of 20258 Old May 12th, 2016, 12:03 AM
Darwin's Avatar
I've been look at that already, might be this next winter's project?
Originally Posted by LethalDosage View Post
Something about your avatar creeps me the fuck out.
2006 GT AUTO Mods:
Ford Racing Intake Manifold, 93 TUNE, UDPs, FRPP 4.10, LT's, catted X, LCA, Adj UCA, 3K Converter and P275/40R17 MT, HR cams and Paxton 1200sl
Darwin is offline
post #20029 of 20258 Old May 12th, 2016, 08:27 AM
braupe's Avatar
That would be interesting, but those rear mounts just have so much piping, and the added lag would make me want to just do a traditional setup.
On another note: X pipe installed! I am now running JBA long tubes, a Pypes modified X pipe, and MBRP axle backs. I will eventually swap to flow master axle backs when ever I pick up a pair.
braupe is offline
post #20030 of 20258 Old May 12th, 2016, 11:07 AM
Turbo > blower
Towelie's Avatar
No lag issues at all with my mid mount turbo. It's right next to the transmission bell housing
---------- Post added at 11:07 AM ---------- Previous post was at 11:01 AM ----------
Turbo build thread
sig by xocolleenox
Convertible Crew #27
Towelie is offline
post #20031 of 20258 Old May 12th, 2016, 03:12 PM
braupe's Avatar
Looks awesome. I am all about it being close to the manifold. Closer the better. What kit is that? Or is it custom?
braupe is offline
post #20032 of 20258 Old May 12th, 2016, 07:50 PM
//babo//'s Avatar
Diy fog light deletes ....
//babo// is offline
post #20033 of 20258 Old May 12th, 2016, 10:18 PM
Insomniac
S&H Stealth Single Turbo kit 05-10 - S197 Mustang Forum - S197Forum.com
post #20034 of 20258 Old May 12th, 2016, 11:33 PM
Turbo > blower
Towelie's Avatar
This right here
Turbo build thread
sig by xocolleenox
Towelie is offline
post #20035 of 20258 Old May 13th, 2016, 08:34 AM
MassMustang's Avatar
Originally Posted by Rankus06 View Post
Not sure what look you want Mass, but looks great to me!
Since we are posting new wheel pics, I just put mine on too. I am running 285 all around with 5mm spacer in the front. I am thinking I would like to add the same spacer to the rear. I like the slightly bulging tire look, don't know if that's considered cool or not.
Looks good to me! A nice square setup!
2005 Mustang GT w/ 4.56s, Hurst shifter, Kooks & Pype-Bombs, Stage II cams, CMDPs, C&L Street CAI, FRPP Springs, Koni STR.Ts, BMR PHB, FRPP LCAs & FCAs
MassMustang is offline
post #20036 of 20258 Old May 15th, 2016, 03:14 PM
Turbo > blower
Towelie's Avatar
So I found out my drivers side axle is slightly bent. It's nothing serious but it just means my rear is probably gonna get built soon. I'm in the middle of buying a house so I can't do anything huge right now. That bent axle has been the source of the squeak I've had in the rear since I bought the car. I took off the brake pads and sanded of the edges so at least it stopped squeaking. The car also got new street wheels and tires today, in prep for the mm meet. No more amazing traction everywhere I go :/. My Mickeys are almost done for so I'm probably gonna get some Hoosiers to replace them. I'm also gonna be putting on some maximum motorsports caster camber plates and a new hub when my buddy gets here.
Anyway here's the new wheels. 19x10 square with 275/40/19's wrapped around them. Surprisingly my car sits almost an inch higher even though the wheels are supposedly the same diameter.
BIGCHRISS197 likes this.
Turbo build thread
sig by xocolleenox
Towelie is offline
post #20037 of 20258 Old May 16th, 2016, 09:27 AM
braupe's Avatar
^ the car looks great. What diff do you plan on using? I went with the GT500 diff, I wish I had spent the beans on a torsen.
On another note, I drifted the heck out of it this weekend.
braupe is offline
post #20038 of 20258 Old May 16th, 2016, 09:55 AM
Turbo > blower
Towelie's Avatar
I'm looking at going with an Eaton trutrac or maybe even a Detroit locker. Not sure yet
Turbo build thread
sig by xocolleenox
Towelie is offline
post #20039 of 20258 Old May 16th, 2016, 11:57 AM
braupe's Avatar
I remember the tru trac being good value at the time.
braupe is offline
post #20040 of 20258 Old May 16th, 2016, 11:27 PM
Insomniac
The true trac was nice while i had it, but when it failed i went with the Eaton posi. Been great so far.
LinkBack to this Thread: https://www.moddedmustangs.com/forums/modular-mustangs/218011-what-did-you-do-your-gt-today.html
Five in the corral : Mustang This thread Refback August 21st, 2013 01:40 PM
What Did You Do To Your GT Today? This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? - Page 441 This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? This thread Refback May 24th, 2012 10:42 AM
What Did You Do To Your GT Today? - Page 9 This thread Refback May 24th, 2012 10:41 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback May 2nd, 2012 10:23 AM
Popular parking lot for sale | Downtown Devil This thread Refback November 16th, 2011 02:36 PM
