What Did You Do To Your GT Today? - Page 1008 - Forums at Modded Mustangs
 21Likes
post #20141 of 20258 Old November 24th, 2016, 11:01 PM
After waiting 2 months for my cam replacement, replacing all 24 lashers and roller followers...I'm back together and she's running.
http://i489.photobucket.com/albums/rr254/svtwin73/image_zpsc7776416.jpg
5.0 stroker, Roush 2300 w/3.2", 10% overcrank, Bullet-RGR spec cams, Kooks LT w/cats, FM axle back, TruTrac 3.73
Svtwin73 is offline
post #20142 of 20258 Old November 26th, 2016, 11:29 PM
RAT FINK
ghunt's Avatar
Little late but on friday, I bought the smoked Vector taillights on the black friday sale on AM. Been looking at those but wasn't crazy about the price, and they went and knocked $90 off it so I said what the hell.
Also bought a matching clear smoked LED third brake light, and today I bought some '11-14 style door panels to replace mine. Couldn't find a good price on '05-09 ones in black and the '11-14 ones are all over the place, and I read a post somewhere about making them work so I said what the hell.
2005 Mustang GT
CMS Stage 1 cams, Lito Tune, C&L Racer, CMDP, SR UDP, JBA LT's & catted H, FRPP Touring AB, Koni STR.T, BMR springs, J&M upper/mount, BMR lowers & brackets, J&M pb, Steeda Tri-Ax, Brembos
2009 Ranger XL SCab-4.0, auto, 4WD
ghunt is offline
post #20143 of 20258 Old November 27th, 2016, 12:56 AM
Resident Headbanger
Bullitt95's Avatar
Had urethane front & rear anti-sway bar bushings installed last week plus a car bubble bath/polish, engine bay cleaning, and color coded the oil catch can valve cover breather.
ID:	189810   Click image for larger version
ID:	189818   Click image for larger version
ID:	189826   Click image for larger version
ID:	189834   Click image for larger version
Bullitt95 is offline
post #20144 of 20258 Old December 2nd, 2016, 11:48 AM
RAT FINK
ghunt's Avatar
Got the door panels yesterday. These are going in my car this winter
I will post pictures and try to get some install information as well.
HOLLYWD69 likes this.
2005 Mustang GT
ghunt is offline
post #20145 of 20258 Old December 2nd, 2016, 12:55 PM
You cleaned the engine bay but not the motor?
Those look sharp. Is it just wiring and stuff that needs to be done to get those on or are there differences structurally?
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #20146 of 20258 Old December 2nd, 2016, 01:55 PM
RAT FINK
ghunt's Avatar
I found a post on AFM from a guy from a few years ago who did the swap and did most of the legwork for me in that regard- he said the plugs on the window switches are different, a couple posts on the back need cut down, a few of the mounting holes are in different places, etc. Doesn't seem too hard to figure out. He also had installed pictures and they look good, the little bump up at the back that matches the 11-14 body line is barely noticeable if you aren't looking for it.
I think these will be a nice upgrade from my panels with the saggy vinyl.
2005 Mustang GT
ghunt is offline
post #20147 of 20258 Old December 3rd, 2016, 12:15 PM
Yeah that little flip on the back would probably bother me but take pics, I wanna see. My vinyl is just starting to bubble. I was think about a syringe with some kragle might hold it for a little while.
07 Boss is offline
post #20148 of 20258 Old December 4th, 2016, 07:11 AM
Resident Headbanger
Bullitt95's Avatar
Of course I degreased the motor as well. Did you think I'd only clean the engine bay and leave the motor looking dirty?
Unfortunately the desert atmosphere where I live is often pretty dusty so it's a waste of time being anal about having the engine spotlessly clean.
post #20149 of 20258 Old December 6th, 2016, 09:30 PM
RAT FINK
ghunt's Avatar
Sooo...wasn't sure if I was gonna get these, but here's another little goodie I got today from RockAuto:
4 piston 2015 GT calipers! I've seen some posts where guys fit them up with 14" S197 rotors and they were really close, so I'm going to make them work (and upgrade to 18 or 19" wheels). I got these, including core charge, for less than I've seen people selling them on ebay. These things are freaking huge too.
Obviously I have a few winter projects planned.
Name:	2016-12-06 16.37.17.jpg
2005 Mustang GT
ghunt is offline
post #20150 of 20258 Old December 7th, 2016, 01:02 PM
I live in the desert too. Probably not as extreme, but plenty dusty and sandy here. I spend about 30 minutes every 3-4 months. Simple, spray on, let sit, rinse and a little foamy tire shine sprayed and then wiped off. Results are worth the little effort and time. Once you get it clean it is easy to maintain.
Before and after pics
07 Boss is offline
post #20151 of 20258 Old December 8th, 2016, 05:11 AM
Resident Headbanger
Bullitt95's Avatar
Aha, so tire foam is the magic formula. I'm gonna give that a try!
post #20152 of 20258 Old December 8th, 2016, 04:11 PM
Hey, what happened to my pics?
I use the F-22 turtle wax tire foam. Just spray it on and let it sit for a couple and wipe off any excess.
07 Boss is offline
post #20153 of 20258 Old December 8th, 2016, 05:00 PM
01GTsmackntickle's Avatar
Installed a Raxiom third led brake light today
01GTsmackntickle is offline
post #20154 of 20258 Old December 24th, 2016, 01:23 AM
RAT FINK
ghunt's Avatar
So I did a little work on my '11+ door panels today (just the driver's side).
For the most part they slip right on. I put the panels up side by side and these are the only real huge differences ('11+ panel on left, original on right). The '11+ panel has the front post moved forward (circled on left) which has to be cut off. Also the back of whatever this huge plastic thing is (is that a resonance chamber for the sub or something?) is larger than the original one which will probably cause some problems with the vapor barrier. I'm trying to see if I can find '11-14 vapor barriers somewhere because mine are all jacked up anyway. One thing that isn't circled, the rearmost mounting screw holes are in different spots, that will be something else to figure out as I really don't want to just drill holes in the panel.
I got them mostly fitting up but something is hitting along the bottom of the panel keeping them from sitting flush against the door- can't figure out what it is. Hopefully I can because these door panels look awesome.
One last tidbit- the S550 caliper retrofit might be easier than I originally thought. This is an '05-14 standard (non-brembo) brake line, bolts right up to the S550 caliper.
2005 Mustang GT
ghunt is offline
post #20155 of 20258 Old January 3rd, 2017, 02:45 PM
Ordered a couple of cheap replacement HID bulbs since I've been driving with the fog lights for the last couple of days.
A few weeks ago I had to replace my timing cover so I painted it to match the valve covers and threw some cool pulleys on it.
The crinkle paint is pretty cool.
Goes on and looks like regular paint though a little thicker. When I first looked at it I said that looks like shit. And then as soon as it dried it got the crinkle look. But it is smooth to the touch. Weird stuff.
07 Boss is offline
post #20156 of 20258 Old January 3rd, 2017, 04:56 PM
RAT FINK
ghunt's Avatar
I hope you have better luck with the wrinkle paint than I did in the past. I painted the aluminum valve cover on my old 2.3 Turbo with wrinkle black, it held up great for a year or so, then started to peel in spots- which I suspect was due to oxidation forming on the aluminum under the paint.
2005 Mustang GT
ghunt is offline
post #20157 of 20258 Old January 3rd, 2017, 06:05 PM
I'm not too worried about it. It was a brand new cover so the surface should have been pretty good with my simple prep/cleaning. I just couldn't throw it on there naked.
07 Boss is offline
post #20158 of 20258 Old January 4th, 2017, 10:21 PM
Darwin's Avatar
I found that prep is most important for any paint on alum. I tried 3 different brands of paint till I got duplicolor to work. I am going to redo my engine paints this coming spring and want to know if anyone knows of Ford Blue Wrinkle paint?
Originally Posted by LethalDosage View Post
Something about your avatar creeps me the fuck out.
2006 GT AUTO Mods:
Ford Racing Intake Manifold, 93 TUNE, UDPs, FRPP 4.10, LT's, catted X, LCA, Adj UCA, 3K Converter and P275/40R17 MT, HR cams and Paxton 1200sl
Darwin is offline
post #20159 of 20258 Old January 5th, 2017, 10:39 AM
I know VHT makes a blue wrinkle paint but I don't know how close it is to Ford blue. I know there is a Ford blue powder coat product out there.
07 Boss is offline
post #20160 of 20258 Old January 14th, 2017, 10:59 PM
oooo2stang's Avatar
Just had my 3rd led from superbrightleds.com burn out. Changing the license plate light can be a bitch getting it back in.
I also have had a set of bmr lower control arms and relocation brackets sitting in my basement for a month, but haven't had good enough weather to want to crawl around on the ground to replace them yet
http://i672.photobucket.com/albums/vv90/b5hobsons4/2006%20Mustang%20GT/10da490b-40e7-4152-a493-50c169a655b1_zpsed967b1f.jpg
Mac Long Tubes | O/R Prochamber | Bassani Race Axlebacks | Hurst | Bama 93 | 4.10's | K Springs | Koni's
oooo2stang is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/modular-mustangs/218011-what-did-you-do-your-gt-today.html
Five in the corral : Mustang This thread Refback August 21st, 2013 01:40 PM
What Did You Do To Your GT Today? This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? - Page 441 This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? This thread Refback May 24th, 2012 10:42 AM
What Did You Do To Your GT Today? - Page 9 This thread Refback May 24th, 2012 10:41 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback May 2nd, 2012 10:23 AM
Popular parking lot for sale | Downtown Devil This thread Refback November 16th, 2011 02:36 PM
