What Did You Do To Your GT Today? - Page 993 - Forums at Modded Mustangs
 21Likes
post #19841 of 20258 Old November 12th, 2015, 04:36 PM
riverwabbit703's Avatar
Just installed Steeda Spherical Lower Control Arm. This was expensive but it is well worth it. Car just hooks and takes off now.
Word to the wise, American Muscle recommended I need relo brackets since my car is lowered. It hooks fine and no wheel hop without them. Saved 150 bucks on re-lo brackets.
riverwabbit703 is offline
post #19842 of 20258 Old November 12th, 2015, 04:50 PM
I love to skydive
Durr4456's Avatar
I think your more the exception than the norm there for the brackets, but glad to hear it's workin for ya. What springs are you lowered on?
MM is awful. Don't ever come here if you haven't been sucked in already!
Durr4456 is offline
post #19843 of 20258 Old November 12th, 2015, 05:05 PM
Roush stage 2 suspension package. I have no idea what springs it's using. Probably Ford Racing (it's blue)?
post #19844 of 20258 Old November 12th, 2015, 05:14 PM
I love to skydive
Durr4456's Avatar
I think they're like 1.5f 1r but I am not positive.
Durr4456 is offline
post #19845 of 20258 Old November 12th, 2015, 07:36 PM
Backbone
SGT T's Avatar
I think the need for brackets hinges on what the angle of the arms ends up at after lowering. Am I correct?
2009 Colorado Red Mustang GT
FRPP Stingers, FRPP 85mm CAI, FRPP 3.73s, FRPP K-Springs, FRPP/GT500 upper strut mounts, Shelby Adjustable Panhard Bar, Tokico Str.t, Shelby CS40, GT/CS Front and Rear Bumpers, GT500 Spoiler, Jegs O/R H, fuzzy dice.
SGT T is offline
post #19846 of 20258 Old November 12th, 2015, 08:20 PM
I think you are correct. My neighbor who is a home grown Ford lover and a restorer stated that bracket is necessary if angle downward is excessive. If LCA is pretty straight with little slight angle, bracket is not really needed.
SGT T likes this.
post #19847 of 20258 Old November 12th, 2015, 09:11 PM
Well the brackets can be very useful as a tuning tool to dial in your suspension. For the street, if it doesn hop you probably don't want to mess with them. But at the track you can use it to dial in anti squat %. This will effect if your car squats or lifts when you launch it. Adjusting the angle and changing the instant center will determine how hard or soft your tires will hit. So depending on track conditions and how your car is set up, having the adjustability of the brackets can make a huge difference in 60' times.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #19848 of 20258 Old November 13th, 2015, 07:36 PM
Backbone
SGT T's Avatar
Normally, I would say this is not-related, but with the new IRS of the S550, I think it matters...
What methods would you use to dial in the suspension for launches when using an IRS?
I had an IRS car, and my biggest headache was keeping the camber from being excessively negative on launch when the car would squat.
SGT T is offline
post #19849 of 20258 Old November 18th, 2015, 04:19 PM
AR Stang's Avatar
Installed my sound deadening material over my weekend. I did the inside of the doors that I could reach behind the speakers. Ford already did a lot of that area though, so it that saved material. I did some areas in the trunk, on the rear speakers deck underside, and will do under the back seat and trim this weekend. I put some on the backs of the door panels as well, and wedged some cardboard between the switch plates and trim. All the rattle's I was having issue's with before are gone. I ordered 9 sheets of the stuff and so far used 4. So I have a lot left to do wherever I want. Not a bad 35 or so bucks spent in my opinion.
AR Stang is offline
post #19850 of 20258 Old November 18th, 2015, 04:28 PM
Turbo > blower
Towelie's Avatar
Found a boost leak. Sealed it up and now the car goes way too lean under throttle. Have to start all the way over with tuning
Turbo build thread
sig by xocolleenox
Convertible Crew #27
Towelie is offline
post #19851 of 20258 Old November 18th, 2015, 04:37 PM
Well basically you don't want your car to squat. When your car squats in the rear you are actually unweighting the tires. You want your axle to push down which actually means the rear of your car is lifting. This is done by manipulating your anti-squat % by changing the angles of your control arm which changes your instant center. Now too much anti-squat is not good either because usually the harder your tires hit the shorter the amount of time they will hold that hit. It's a balancing act. So with good relocation brackets you will have some adjust-ability with the angles to dial it in wherever you need it to be.
I've never set up an IRS car for drag racing but I'm assuming the same basic principles apply, but how to go about changing that may be different. Either way you want the rear to stay level or lift on launch, not squat down.
07 Boss is offline
post #19852 of 20258 Old December 5th, 2015, 05:52 PM
Developed a driver side exhaust leak on Thurs, spent 3 hours wrapping that up today.
http://i489.photobucket.com/albums/rr254/svtwin73/image_zpsc7776416.jpg
5.0 stroker, Roush 2300 w/3.2", 10% overcrank, Bullet-RGR spec cams, Kooks LT w/cats, FM axle back, TruTrac 3.73
Svtwin73 is offline
post #19853 of 20258 Old December 5th, 2015, 06:44 PM
Beat my previous PB by .012 seconds.
07 Boss is offline
post #19854 of 20258 Old December 6th, 2015, 12:05 PM
Mind linking what you used? How much weight do you think you added?
2012Boss is offline
post #19855 of 20258 Old December 6th, 2015, 12:50 PM
Turbo > blower
Towelie's Avatar
Drove it for the last time this year. I fucking hate winter.
Turbo build thread
sig by xocolleenox
Towelie is offline
post #19856 of 20258 Old December 7th, 2015, 09:32 AM
I had messaged him about this. This is the stuff he used. I just bought some myself and will be doing it over the winter.
2007 GT Windveil Blue (WBR 099)
Detroit Rockers,Kooks LT w/Catted H-pipe and Boss 302 Side Exit Exhausts, Pypes Pype Bomb muffler deletes, FRPP 4.10 Gears, C&L Racer CAI, MGW Shifter, BMR Suspension, Steeda Spyders, NITTO 275/35 & 315/35
sdonaghey is offline
post #19857 of 20258 Old December 7th, 2015, 09:46 AM
http://www.amazon.com/gp/product/B01...iglink22914-20
hey thanks for the link. This should help quiet up the rear end!
2012Boss is offline
post #19858 of 20258 Old December 7th, 2015, 09:58 AM
No problem.
Check here on ebay for it. This is where I actually got it from. It ships fast.
1 5 More Effective 80 Mil 36 sqft Noico Sound Deadener Dynamat Deadening SMPL | eBay
post #19859 of 20258 Old December 8th, 2015, 12:42 AM
I love to skydive
Durr4456's Avatar
Well I didn't do anything. But I snagged a blower, elbow, throttle body, h/e. And Jlt intake for the dob. Good deal on it too. 650.
HOLLYWD69 and Towelie like this.
Durr4456 is offline
post #19860 of 20258 Old December 8th, 2015, 07:16 PM
Backbone
SGT T's Avatar
developed a gear whine between 20-40 mph. Super annoying
SGT T is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/modular-mustangs/218011-what-did-you-do-your-gt-today.html
Five in the corral : Mustang This thread Refback August 21st, 2013 01:40 PM
What Did You Do To Your GT Today? This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? - Page 441 This thread Refback March 26th, 2013 06:09 AM
What Did You Do To Your GT Today? This thread Refback May 24th, 2012 10:42 AM
What Did You Do To Your GT Today? - Page 9 This thread Refback May 24th, 2012 10:41 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback May 2nd, 2012 10:23 AM
Popular parking lot for sale | Downtown Devil This thread Refback November 16th, 2011 02:36 PM
