05-09 Dash Removal Writeup - Forums at Modded Mustangs
post #1 of 40 Old May 20th, 2011, 06:10 PM Thread Starter
GTman05's Avatar
EDIT: Mods, maybe post a link to this in one of the S197 stickys? That way it doesn't get lost in the back pages as time goes on...
Ok so I spent some time today taking off all the interior dash pieces so I can paint them, and I wanted to do a write-up so anyone who wants to do this can have some steps instead of piecing together shit from around the web...
Tools: Ratchet with 7mm & 8mm sockets; flathead screwdriver.
Step 1. Ok so the first thing to do is to take off the trim around the arm-rest/center console, mine had no bolts on the trim piece with the cupholders, so it lifted off, but there should be some bolts on a normal vehicle. The E-brake must be pulled all the way up for it to lift off.
Step 2. Once thats off there are two pieces to the left and right of the radio cluster just pull off, though you might have to use a screwdriver to help a little. (ignore my hobbit feet )
Step 3. The dash piece that is overlayed on top of the gauge cluster simply pulls of, just grab the left and right vents and pull firm and steady
After it pulls off, behold...
Step 4. Ok, so this is where things start to seem difficult, but I promise, they're not. The next few steps will require depowering the Supplemental Restraint System, and removing the passenger side airbag, which will require the removal of the fuse, and some other goodies.
Located on the floor of the passenger side is the Smart Junction Box (SJB). Remove the two panels to get to the fuses and remove fuse 17
After removing the fuse, turn the key into the on position and make sure that the airbag indicator light stays on for 30 seconds...that means the correct fuse is out.
Step 5. Next is to unplug the Negative terminal of the battery, I don't think anyone on here needs a picture or measurements to do that...
Step 6. Next is removing the glovebox to give you access to the airbag...There are four bolts on the underside of the glovebox, mine came off with a 7mm socket. The picture isn't the best, couldn't really nail the angle, but its easy to figure out.
Glovebox just kinda wiggles out, you may have to push the sides in to get it to fully drop...
Step 7. There is a plug that goes into the rear of the airbag, which will need to be unplugged. Also, the two bolts in the picture must come off as well, I used 8mm socket.
Step 8. Once you're under there, you'll see that the airbag is hooked onto the dash trim, so the whole thing comes out as one. The clips that hold the dash trim onto it, (pictured below) are easily pushed out with either your finger or a screwdriver...
This is the view from the outside once the whole unit starts to come out...
The whole thing takes some wiggling to get out, but pull the bottom, then the top, then the bottom, etc, and this is what you will have come out...
Step 9. Now that the airbag is out, the rest is easy as hell. While on the passengers side, the rightmost vent is held on by these two bolts, for which I used a 7mm socket, after which the vent comes right off.
Step 10. Lastly, the center dash piece. Four bolts hold down this sucker, all the same 7mm as the passenger vent.
Once those are off, same thing as the others, work it out.
End result:
I'll be painting all of these tonight/tomorrow, and once I have everything back on, I'll post some pics of the finished work...
I hope that this helps anyone, it took me a while to figure out the exact procedure for getting the airbag out safely, as no one spot had a whole write-up...till now!!
Happy Modding!!
-Nick
2014 White Mustang GT; 3.73s, Recaro Cloth Seats
2005 Black Mustang GT SOLD
GTman05 is offline
post #2 of 40 Old May 20th, 2011, 06:12 PM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
Good write-up, appreciate the time it took you to do this. Reps!
Nasty is offline
post #3 of 40 Old May 20th, 2011, 06:14 PM
brianm's Avatar
I agree a fair bit of work went into this.
vmp tvs 85mm pulley
steeda lcas
forgstar cf5s
dynotech d/s
558rwhp/452 rwtq
brianm is offline
post #4 of 40 Old May 20th, 2011, 06:16 PM Thread Starter
GTman05's Avatar
Thanks! I saw someone on here had theirs painted, but no write-up...The hardest part was my damn back giving me trouble...just had surgery so this was pretty uncomfortable!!
Totally worth it though
Plus I haven't really posted any tech knowledge in a long time, so I figured I'd put something useful in here besides opinions...
GTman05 is offline
post #5 of 40 Old May 22nd, 2011, 10:35 AM
An82Mustang's Avatar
Can't wait to see the finished product... I've been thinking of painting mine... Just havn't gotten off my lazy ass to do it...
An82Mustang is offline
post #6 of 40 Old May 22nd, 2011, 06:11 PM
Unklbuck62's Avatar
OK, it's been 3 days (LOL) let see the results...nice job on the write-up...should help those in need...
2008 GT/CS Convertible-Saleen Super Shaker-Roush Stage III Suspension & Short Throw Shifter-Cervini B2 Hood Kit-Shelby CS67 Wheels, Nittos, much more to come!!
Unklbuck62 is offline
post #7 of 40 Old May 23rd, 2011, 11:02 AM Thread Starter
GTman05's Avatar
Ok so the paint got done late saturday night and I was at a car show all day sunday, but heres the final result
Before:
After:
Light kinda sucks but the flash made everything look blue =/
GTman05 is offline
post #8 of 40 Old May 27th, 2011, 11:58 AM
RZNCAIN's Avatar
need better after pic
2007 Shelby GT- Hardparked
1988 LX 5.0- Umm...Driver?
RZNCAIN is offline
post #9 of 40 Old May 27th, 2011, 12:45 PM Thread Starter
GTman05's Avatar
Inside Garage
Outside
Better? haha
GTman05 is offline
post #10 of 40 Old May 27th, 2011, 01:09 PM
RLz
RLz's Avatar
Great write up! Im sure a lot of people could appreciate this.
The blacked out look is much better IMO.
You should think about painting those A/C bezels tho, gray maybe. just to give it a bit of life.
RLz is offline
post #11 of 40 Old May 27th, 2011, 01:42 PM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
What did you paint it with?
Nasty is offline
post #12 of 40 Old May 27th, 2011, 02:09 PM Thread Starter
GTman05's Avatar
I used Krylon Fusion Flat black, and then a Matte Clearcoat overtop
GTman05 is offline
post #13 of 40 Old May 27th, 2011, 02:12 PM
Pretty awesome! Well done sir.
2005 Mineral Grey Mustang GT (auto)
JLT CAI w/ SCT SF3 Tuner, Pypes Mid Muffler System, Boost Brothers Long Tube Headers, Thunderbolt High Flow Cats, PA Performance 130A Alternator.
adj86 is offline
post #14 of 40 Old May 27th, 2011, 03:49 PM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
It almost looks like it has a texture to it even on the smooth parts. Any reason? .. or is it just my eyes??
Nasty is offline
post #15 of 40 Old May 27th, 2011, 05:26 PM Thread Starter
GTman05's Avatar
What parts are you referring to? Theres lines in the aluminum on the middle and passenger side...thats still there, but the paint went on smooth...only spots that are a little "textured" are the vent rings that used to be chrome, they were a bitch.
GTman05 is offline
post #16 of 40 Old May 28th, 2011, 12:10 AM
Who makes the Matte Clearcoat? I have been looking for it, but have only found very small cans of it in a local hobby store.
sdonaghey is offline
post #17 of 40 Old May 28th, 2011, 12:50 AM
BWAL Is My Hero
JakeM's Avatar
Very coool! Reps foh the write up!
JakeM is offline
post #18 of 40 Old May 28th, 2011, 02:14 AM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
That's exactly what I was talking about.
I know about the lines as I've got the same dash.
Nasty is offline
post #19 of 40 Old May 28th, 2011, 09:48 AM Thread Starter
GTman05's Avatar
haha yup. for some reason that was the only bitch of it...everything else came out perfect...
Found it at lowes
GTman05 is offline
post #20 of 40 Old July 1st, 2011, 05:45 PM
dalton2021's Avatar
Thanks to your write up i did this!
dalton2021 is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/modular-mustangs/219269-05-09-dash-removal-writeup.html
Great News for KITT Mustang Replica Builders! - Page 38 - knight rider online This thread Refback January 6th, 2018 11:36 PM
????????? ?????? ??????. - ??? ????????? 2005+ - Russian Mustang Club This thread Refback May 15th, 2015 04:44 AM
knight rider online ? View topic - Great New for KITT Mustang Replica Builders! This thread Refback December 24th, 2013 04:49 AM
????????? ?????? ??????. - ??? ????????? 2005+ - Russian Mustang Club This thread Refback November 16th, 2013 10:58 AM
????????? ?????? ??????. - ??? ????????? 2005+ - Russian Mustang Club This thread Refback October 3rd, 2013 11:34 PM
????????? ?????? ??????. - ??? ????????? 2005+ - Russian Mustang Club This thread Refback August 31st, 2013 05:30 AM
Untitled document This thread Refback June 7th, 2013 03:23 PM
Untitled document This thread Refback May 20th, 2013 08:43 AM
Untitled document This thread Refback April 29th, 2013 02:17 PM
Untitled document This thread Refback April 22nd, 2013 05:48 AM
Untitled document This thread Refback January 16th, 2013 10:51 PM
Untitled document This thread Refback December 30th, 2012 07:59 AM
Untitled document This thread Refback October 2nd, 2012 06:37 PM
Untitled document This thread Refback September 24th, 2012 11:07 PM
Untitled document This thread Refback September 21st, 2012 03:56 AM
Untitled document This thread Refback September 6th, 2012 11:08 PM
Untitled document This thread Refback August 28th, 2012 12:10 PM
Untitled document This thread Refback July 18th, 2012 06:46 PM
Untitled document This thread Refback July 2nd, 2012 02:06 PM
Untitled document This thread Refback July 1st, 2012 11:31 AM
Untitled document This thread Refback June 28th, 2012 05:57 AM
Untitled document This thread Refback June 25th, 2012 03:03 PM
Untitled document This thread Refback June 24th, 2012 11:21 PM
Untitled document This thread Refback June 13th, 2012 01:23 PM
Untitled document This thread Refback June 12th, 2012 10:17 AM
Untitled document This thread Refback June 10th, 2012 01:55 PM
Untitled document This thread Refback June 7th, 2012 09:46 AM
Untitled document This thread Refback June 6th, 2012 08:38 PM
Untitled document This thread Refback June 6th, 2012 03:19 PM
Untitled document This thread Refback June 2nd, 2012 02:09 PM
Untitled document This thread Refback May 29th, 2012 10:43 AM
Untitled document This thread Refback May 29th, 2012 01:53 AM
Untitled document This thread Refback May 22nd, 2012 11:12 PM
Untitled document This thread Refback May 19th, 2012 03:24 PM
Untitled document This thread Refback May 10th, 2012 07:05 PM
Untitled document This thread Refback May 8th, 2012 04:53 PM
Untitled document This thread Refback April 23rd, 2012 01:14 PM
Untitled document This thread Refback April 20th, 2012 05:57 PM
Untitled document This thread Refback April 10th, 2012 09:10 AM
Just a late night project... - Ford Mustang Forums This thread Refback April 6th, 2012 12:39 PM
Untitled document This thread Refback April 6th, 2012 12:46 AM
Untitled document This thread Refback April 5th, 2012 10:55 PM
Untitled document This thread Refback April 5th, 2012 07:44 PM
Untitled document This thread Refback April 5th, 2012 06:10 PM
Untitled document This thread Refback April 5th, 2012 05:22 PM
Untitled document This thread Refback April 5th, 2012 04:37 PM
