Our 8.8 - Forums at Modded Mustangs
post #1 of 12 Old February 27th, 2012, 01:45 PM Thread Starter
Our 8.8
31 spline, trac-lok differential.... Other than the size of the pinion bearing, is there ANY difference from our rear than the older 8.8's? (28 spline rear end, but that is negligible here)
So far it seems like 2 different shops now go retarded when installing gears in my car and I'm getting fed the hell up with it.
zinc02GT is offline
post #2 of 12 Old February 27th, 2012, 01:48 PM
Priest of the Car Gods
ReverendDexter's Avatar
I wasn't aware of any change in the differential itself... I thought it was the same good ol' 8.8 that's been in every V8 Mustang (including IRS cars) since the mid-'80s.
What are they telling you is different?
Function > Form, always
ReverendDexter is offline
post #3 of 12 Old February 27th, 2012, 01:53 PM Thread Starter
No I'm basically educating myself. They haven't told me anything except that they installed it within spec and are blaming it on my driveshaft, suspension, and even the FRPP 3.73's themselves... Which I laughed about because NONE of those would cause the whine that I've got.
It whined before the rear suspension work, before the driveshaft, before anything. The suspension/etc is just bringing their mistakes into daylight instead being hidden.
zinc02GT is offline
post #4 of 12 Old February 27th, 2012, 02:16 PM
Zip's half naked helper
Marc's Avatar
No difference at all. I'm sure you know what a rear end whine is (you are no idiot). Could you maybe have this shop pull the cover and do a paint pattern for you? That will tell you if the pinion depth is right and the backlash is in spec.
Originally Posted by narleycarley
I have an amazing mullet.
Originally Posted by Jordang View Post
If Marc's car was a woman, she would be in short skirt and a G string and he would tell her to bend over whenever people walked by.
Marc is offline
post #5 of 12 Old February 27th, 2012, 02:20 PM Thread Starter
That's what the plan is. They were supposed to call me back to set up an appointment, but it looks like I'll have to take it into my own hands... I know it's not a bearing since the pitch doesn't increase with speed. It's blatantly obvious it's the rear end. The head mechanic rode with me this morning. Right now it's boiling down to their "Mustang guy" thinking he knows everything and blaming it all on the driveshaft... Basically he told me I wasted my money to which I found a polite way to tell him he was an idiot without saying he was an idiot. Basically I pointed out that stock V6 Mustangs were blowing out the same driveshaft under regular conditions, while some were racing, a few were regular operation. God forbid it be a modded GT pushing 200 more wheel horsepower than a stock V6.
zinc02GT is offline
post #6 of 12 Old February 27th, 2012, 03:19 PM
Alejandro5.0's Avatar
I was having that problem.
Ford changed their gear manufacturer and they channged something up to where oreillys shim or pinion bearing (forgot which 1) didn't match with the gears so they got all the little parts directly from ford and wala it went away,
2012 Gt/Cs: steeda cold air, tune, 3.73
404whp
388torque
Alejandro5.0 is offline
post #7 of 12 Old March 1st, 2012, 12:08 PM Thread Starter
After a little more research I found that the pinion depth on the newer 8.8's is slightly different than those of the old which pinion depth is my issue and problem with my current gears.
Dunno where to go from there or how to present that to the the shop.
zinc02GT is offline
post #8 of 12 Old March 1st, 2012, 01:14 PM
Morty8833's Avatar
I just had my gears installed Tuesday, and the guy did a great job, granted I only have about 30-40 miles on them they are quite as can be. Hope you get your situation fixed.
2011 GT 5.0 N/A GMR #00195
Bassani Axle-back/X-pipe/Resonator delete
Eibach Pro-kit
Airaid CAI
BAMA 91R Tune
FR 3.73
BMR LCA's & Relo. Brackets
Morty8833 is offline
post #9 of 12 Old March 1st, 2012, 01:16 PM Thread Starter
This shop has gone as far as blaming the gear cut (FRPP) as the problem...
zinc02GT is offline
post #10 of 12 Old March 1st, 2012, 02:00 PM
What you need to do is stop dealing with that shop and go with someone who knows what they are doing
404whp
388torque
post #11 of 12 Old March 1st, 2012, 02:01 PM Thread Starter
And pay more money? I've dumped $1300 between doing what you just said trying to get this right. I'm tired of dealing with it.
zinc02GT is offline
post #12 of 12 Old March 1st, 2012, 03:40 PM
FiK
FiK's Avatar
Actually the V6 driveshaft is very, very different.
Also, the 8.8's pinion bearing is supposed to be different but the old one compatible... Don't doubt this could be causing your whining.
2011 3.7L Perf Pack (3.31 rear); BMR Springs, Adj Panhard, UCAM, UCA, CABs, LCAs; Tokico DSP-12s; GT500 Strut Mounts; JLT Oil Can; TSW Interlagos 20x8.5 & Falken 255/35R20 x 4; Audio Sys; AMSOil Sig Series 5W-30/EAO17; Pypes 3" Catback
FiK is offline
