shorty v.s. long tube->??? - Forums at Modded Mustangs
post #1 of 6 Old June 14th, 2007, 12:48 AM Thread Starter
this may be an old topic but hy, it needs to be brough back up. why are there shorty headers and long tube headers. whats the difference, before you say it obviously ones longer than the other lol, but what else. is there a better application for each one? what are they? i don't know anything about them so dont be brief, im sure im not the only person wondering
98 GT, K&N Cold Air, Steeda Timing Adjuster & Underdrive Pulleys, MSD Spark Control
3.73 Gears, MagnaFlow Highflow Cats, X-Pipe, and Mufflers, Tri-Ax Short Throw , King Cobra Clutch, W Gauges, Bullitt Wheels
Tokiko 5-Way with C/C Plates, sub-frame con.
sleezy is offline
post #2 of 6 Old June 14th, 2007, 01:02 AM
Send a message via AIM to droppedbass87
same here..
droppedbass87 is offline
post #3 of 6 Old June 14th, 2007, 10:59 AM
Ryan Paymaster's Avatar
From what I understand if your going to put the time into putting headers on then go with the long tubes. I believe it's a long tube is just better all around issue.
However, I don't know if there is anything with emissions and long tube headers.
Ryan Paymaster is offline
post #4 of 6 Old June 14th, 2007, 11:30 AM
longtubes are better then shorties in the HP and torque department
but usually require O2 extensions and a matching midpipe.They can also get in the way if you gotta pull the trans out.You 4.6 people also have
another option Midlengths which does not get in the way of the trans
if you need to take it down.If you buy one of those Bassani or JBA modular midpipes that work with shorties or mids.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Racinjason81 is offline
post #5 of 6 Old June 14th, 2007, 12:08 PM
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
This rule applies in general, however it is not just the matter of the header. Overall the engine itself could make more power with one or the other depending on several things on a N/A engine.
1. Primary sizing of the tubes
2. Primary length
3. Cylinderhead efficiency
4. Camshaft selection
The list could go for a while, but you see what I'm getting at.
Alot of people make the bigger is always better mistake, which leads to the I put this on and lost power thread....LOL
If you are looking into headers you'll want to find something that fits your application. It is obvious that a 1 3/4"stepped to a 1 7/8" L/T is not going to work well on a fairly stock to mild build and will probably net less power than a stock manifold. A equal length shorty header would be a better choice for a mild build, a heavily modified car (Blower or nitrous) with a tuned equal length L/T header would be best. I have heard alot of good things about mid length and have seen then work well on almost any application....
Boomer is offline
post #6 of 6 Old June 14th, 2007, 01:57 PM
i say shorties personally..although im going turbo so i wont be getting aftermarket shortied..
