FRPP intake manifold with CDC shaker hood? - Forums at Modded Mustangs
post #1 of 6 Old October 14th, 2012, 05:48 AM Thread Starter
Can I use the FRPP intake manifold in conjunction with the CDC shaker hood? Thanks
JustcruisinGT is offline
post #2 of 6 Old October 14th, 2012, 08:52 AM
Eat Springs, Shit Valves
AnotherS197GT's Avatar
iTrader: 11 reviews
No.
AnotherS197GT is offline
post #3 of 6 Old October 17th, 2012, 05:20 PM
I asked that question also. The FRPP Intake manifold sites about 3/4" higher than the stock manifold. The scoop will stick up a bit more with it, but the main thing, is that to get the shaker secured to the manifold, you will have to epoxy the holder thingy to the manifold. I might try it when I get the car home from the shop. Right now the Shaker seems a little low in the hole. Maybe the FRRP manifold will fix it.
2007 GT Windveil Blue (WBR 099)
Detroit Rockers,Kooks LT w/Catted H-pipe and Boss 302 Side Exit Exhausts, Pypes Pype Bomb muffler deletes, FRPP 4.10 Gears, C&L Racer CAI, MGW Shifter, BMR Suspension, Steeda Spyders, NITTO 275/35 & 315/35
sdonaghey is offline
post #4 of 6 Old October 17th, 2012, 05:57 PM
iTrader: 11 reviews
There isn't 3/4 of an inch to be had with the shaker. Mine is rubbing on the trim ring with a stock manifold and motor mounts. You're gonna have to cut the hell out of the shaker.
post #5 of 6 Old October 17th, 2012, 06:11 PM
Then get lower engine mounts.
post #6 of 6 Old October 17th, 2012, 06:50 PM
iTrader: 11 reviews
Not everyone wants stiffer motor mounts. I also had someone measure the FRPP piece and a stock manifold and they said the difference was a good bit more than 3/4 of inch. That would be cool if you could get it to work, but I think its probably more of a pain in the ass than anything. If you want a different intake with a shaker, get a Super Shaker
