Squeaky belt - Forums at Modded Mustangs
post #1 of 30 Old November 20th, 2012, 04:46 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
Squeaky belt
My belt was chirping really bad, so I went ahead and pulled the head unit off and replaced the belt. Initially it wasn't making any noise. Now it is starting to chirp just a little bit. I swapped the idler pulley for a little bit smaller one because my belt was extremely tight after adding a Roush tensioner.
My question, is it too tight or too loose when a brand new belt is squeaking? Also, could it be something going out, like a pulley on something seizing up that's causing the noise. It's intermittent. The car runs great even when it's making the noise.
Anything that can point me in the right direction, or any direction is appreciated.
2007 GT Convertible Build Thread
Vortech V3 trim, FRPP Intake manifold, MAC LT's, Prochamber, Ford Racing 3:73 gears, FRPP springs, Hurst Billet shifter, FRPP 62mm Throttle body, tuned by True Street Motorsports. 523 rwhp 440 lbft torque
Taxman is offline
post #2 of 30 Old November 20th, 2012, 05:32 PM
KILLER
stri8ed's Avatar
iTrader: 12 reviews
Is it squeaking only at idol? Does it speed up when you rev it?
2013 Trinity TVS Powered!!
WHP: 615
TQ: 610
Boost: 16lbs
Addicted
stri8ed is offline
post #3 of 30 Old November 20th, 2012, 06:57 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
Seems like it stops when I put a load on the engine. Squeaks at idle then stops as I take off. It's starts to squeak more initially when I rev it to take off then goes away.
Taxman is offline
post #4 of 30 Old November 20th, 2012, 08:04 PM
KILLER
stri8ed's Avatar
iTrader: 12 reviews
Try spraying a tiny bit of WD40 on each pulley one at a time and see when it stops.. If it stops squeaking on a pulley, replace that pulley. Also ive heard that pulleys can kinda get glazed over like rotors do, and that alittle bit of light sanding can fix the squeak.
I might also try putting the breaker bar on the idler and relieving a little bit of pressure on the belt and see if it stops the chirp. If it does, it just means the new belt needs to stretch alittle bit i think.
Pulley alignment might also be off. If the above doesnt fix it, id rent a laser aligner and see if a pulley is off.
WHP: 615
TQ: 610
Boost: 16lbs
Addicted
stri8ed is offline
post #5 of 30 Old November 20th, 2012, 08:10 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
My fear is this is the problem.
I'm having trouble diagnosing it because when I got home, it had stopped. FML
Taxman is offline
post #6 of 30 Old November 20th, 2012, 08:50 PM
KILLER
stri8ed's Avatar
iTrader: 12 reviews
Hmm, well i cant help u with the fact it stops when u get home lol. Also, i think i heard that if you spray the belt with a light mist of water while its squeeking and it stops, then its the belt.. If it doesnt stop, its a pulley.
WHP: 615
TQ: 610
Boost: 16lbs
Addicted
stri8ed is offline
post #7 of 30 Old November 20th, 2012, 08:57 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
I sprayed it with belt conditioner and it started then stopped.
Taxman is offline
post #8 of 30 Old November 20th, 2012, 09:02 PM
Hardon Enthusiast
jbenevides89's Avatar
drive it to a long straight low traffic road, then beat the shit out of it! usually works on my truck lol. it could break or fix itself, either way it will be fun!
no i dont do this with my car.....
i think its probably just a new belt, is it a constant like squeal or a chirp chirp chirp?
Hurst, C&L Racer, Shortys, Pypes Violators, Pypes Off Road X, CMDPs
CHE K Brace, Strange 10pt rear shocks, J&M LCAs, SCT Bama 93 Race Tune
jbenevides89 is offline
post #9 of 30 Old November 20th, 2012, 09:06 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
Chirping.
Taxman is offline
post #10 of 30 Old November 20th, 2012, 09:12 PM
Hardon Enthusiast
try a stethoscope on each of the pullies to at least find out where its coming from. once you locate it it will probably jump right out whats wrong.
post #11 of 30 Old November 20th, 2012, 09:13 PM
Sheriff Metal Face
Chris951's Avatar
Belts most likely too loose. Don't use belt conditioner. Get a tighter belt.
Chris951 is offline
post #12 of 30 Old November 20th, 2012, 09:18 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
I'm gonna swap idler pulleys back to the larger one and see if that stops it.
Taxman is offline
post #13 of 30 Old November 20th, 2012, 10:32 PM
The Despised Vert
Send a message via Yahoo to 2006greyGT
remove, clean and reinstall the idlers.. and put them in different positions. I had the same problem and I got billet idlers from Procharger and haven't had the problem since.
KB 2.6l 4.9l forged stroker 2 1/2" Exhaust Cloth Top
NUMBER 3 Official member of the "My Car Sucks And No One Likes It But Me" CLUB
2006greyGT is offline
post #14 of 30 Old November 20th, 2012, 10:44 PM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
To swap the idler pulleys I have to remove the supercharger. Ugh!
Taxman is offline
post #15 of 30 Old November 20th, 2012, 10:50 PM
Take a dab of silicone adhesive. Put it on the ribbed side of the belt. Start the car and let it idle for 4-5 minutes so it smears it all the way around. Little bird should be gone. It's a little old school, but it works, trust me.
Go try it right now and let me know what a genius I am.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #16 of 30 Old November 21st, 2012, 08:37 AM
When I did my 8 groove PS pump pulley swap, My belt ticked at 1st, then started chirping, I thought it was the alignment of the PS pulley and the 8 rib idler but then I figured out the belt was rubbing on the rear of the water pump pulley.
I shimmed the 8 rib idler with a 5/8" grade 8 washer to move the belt forward on the water pump pulley and the chirp went away.
debit_free_2010 is offline
post #17 of 30 Old November 21st, 2012, 08:43 AM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
Thanks, I'll check that out.
Taxman is offline
post #18 of 30 Old November 21st, 2012, 08:49 AM
specknowsbest's Avatar
I actually had this exact same problem with my stang a little while back. First time I replaced the belt, since it seemed like all the pulleys were good and of course, the noise went away. Eventually though, it came right back after all of about a month.
Couldn't figure it out at all until I slipped while I was underneath the hood on the alternator and I saw that it had some give to it. The pulley on the alternator itself was shot. So I went ahead and replaced the alternator altogether and now, no more squeak.
specknowsbest is offline
post #19 of 30 Old November 21st, 2012, 02:15 PM
nawagner's Avatar
As mentioned if you spray water on the ribs of the belt and it goes away then it is the belt not in-line with one of the pulleys. I'm fighting the same issue now, just can't figure out which is out of alignment a little.
The chirp is the belt catching part of the way in the pulley ribs and it chirps as it slides into place to the bottom of the pulley. It will go away as it warms because the belt becomes softer with heat.
nawagner is offline
post #20 of 30 Old December 1st, 2012, 12:34 AM Thread Starter
3v reppin'
Taxman's Avatar
iTrader: 5 reviews
You are a fucking genius. Thanks for the tip.
Taxman is offline
