Shaftmasters Aluminum Driveshaft Review - Forums at Modded Mustangs
post #1 of 29 Old July 2nd, 2013, 08:48 AM Thread Starter
Yagermeister's Avatar
Check out my review of the Shaftmasters 3.5 aluminum driveshaft at:
Shaftmasters Aluminum Driveshaft Review for my 2011 Mustang GT California Special
2011 GT/CS 6R80
Yagermeister is offline
post #2 of 29 Old July 2nd, 2013, 05:56 PM
scottmach's Avatar
Excellent write up. On my to do list when the converter goes in.
2015 Mustang GT Premium Automatic Ingot Silver
2011 Mustang GT Automatic Grabber Blue Sold
scottmach is offline
post #3 of 29 Old July 2nd, 2013, 07:44 PM
SlowFiveOh
Supra's Avatar
I just put mine in a month ago. It shakes like crazy around 100 mph and faster. The car is lowered, so i'm going to assume its the pinion angle. Parked the car and now waiting on an adjustable uca, hopefully that will fix it up
2013 5.0 / Roush TVS 82mm / VMP Twin 67mm TB / ID1000's /JPC Longtubes / Kooks AB's / 1 piece aluminum DS / BMR Suspension + Strange struts/shocks
Instagram ~ @slowfiveoh
Supra is offline
post #4 of 29 Old July 2nd, 2013, 11:47 PM
MM elder
casper gt's Avatar
nice write up Brent...........
MM BRACKET RACING CREW CO-FOUNDER
2012 300a GT A6......10.78 @ 124.........sold
2014 301a GT A6.............12.73 @ 112........d/r only
casper gt is offline
post #5 of 29 Old July 3rd, 2013, 09:56 AM Thread Starter
Thanks CasperGT
2011 GT/CS 6R80
post #6 of 29 Old July 5th, 2013, 07:39 PM
blackbeast12's Avatar
I got a dss cv joint d/s on the way to replace my shaftmasters d/s. i have vibrations even with the pinion angle set right...there's no concern with pinion angle with the dss cv joint! Cant wait should be delivered next tuesday! The shaftermasters is an ok d/s when you don't modify your suspension set up, therefore i will sell my shaftmasters after i get the dss installed!
2012 GT Premium, 6speed 3:31 gears modded- to much to list!
blackbeast12 is offline
post #7 of 29 Old July 5th, 2013, 09:25 PM
MM elder
casper gt's Avatar
my suspension is as much so if not more modified than anyones on here, I have 0 vibrations.
I read thru your post on svt, IMO, it's the whiteline parts.
think it thru logically, you had no vibration with the springs & shaftmasters d/s, you install the whiteline ah, products I guess we will call them (certainly not a fan of theirs) & bam, vibration.
ok, loose their junk upper & replace it with a steeda adj unit (depending in which steeda unit, it may have made it worse) & then set the pinion angle too shallow at -1.
still have vibration & blame the d/s....................?
post #8 of 29 Old July 5th, 2013, 09:32 PM
Loud Exhaust Enthusiast
UDEAFBRO?'s Avatar
How much would a shop typically quote to install this piece time wise?
Originally Posted by TheUNZippee!
Dude if you had a vagina I would end you
UDEAFBRO? is offline
post #9 of 29 Old July 5th, 2013, 09:37 PM
gtscrewd
faym 08's Avatar
I've looked at it nice write up! I like to do it has anyone ever dynoed one of these to see what the actual gain is. Until I go forged I don't want to add any hp at all. Is it really 14 or is it more like 4 or 5 ?
July 2013 rotm winner
faym 08 is offline
post #10 of 29 Old July 5th, 2013, 09:41 PM
MM elder
casper gt's Avatar
a shaftmasters unit is a direct swap so I would be in the 1 hour range, price will vary though depending on mechanical labor rates in your location.
as to the dss one, it would be simular.
---------- Post added at 09:41 PM ---------- Previous post was at 09:39 PM ----------
a driveshaft doesn't add any h/p, it may show a few on the dyno by freeing up some loss in the drivetrain, but thats it.
post #11 of 29 Old July 5th, 2013, 09:45 PM
gtscrewd
faym 08's Avatar
I'm in! I hate that clunky factory one. So if I'm lowered now with the eaibach pro kit and don't have any vibrations. I should be good to go with this one?
faym 08 is offline
post #12 of 29 Old July 5th, 2013, 10:01 PM
MM elder
casper gt's Avatar
not nessesarily, you most likely will find an adjustable upper control arm will come in handy.
post #13 of 29 Old July 5th, 2013, 10:06 PM
gtscrewd
faym 08's Avatar
Thanks^^
faym 08 is offline
post #14 of 29 Old July 5th, 2013, 11:04 PM
The vibration was always there hidden by the rubber of the oem mount. I upgraded my entire suspension, the vibration that was there was magnified just a little bit. There's a reason why i have 0 vibration during wide open throttle and vibrations during normal driving its because the d/s is at 0 pinion angle where it likes to be. The steeda mount which is a harder bushing then the Whiteline mount magnified the normal driving vibrations even more. It is a pre existing condition magnified by harder parts. It is no secret that these cars suffer from harmonic and balance issues from the factory. Its why the back end of the oem driveshaft has 9lbs of weight on it, its why the oem uca mount and the hydro motor mounts are so soft. ford was more concerned about minimizing noise and vibration then wheel hop and driveline deflection. When ever you change what ford has done with new and different parts it throws the balance and harmonics off. Dss is the only driveshaft company that has engineered into to its product the elimination of these issues. Different parts create different harmonics and in balance and dss is aware of this. There are countless threads of people saying that the shaftmaster shaft is vibration free until they modded their suspension, those guys went to dss and never had an issue afterwards! You have no vibration well you lucked out! Me i have to solve the problem and going from -1 to -2 on the pinion angle wont change it. The fact is there are more threads about shaftmasters vibrating then there are threads about whiteline suspension parts causing vibration. Vibration is caused by rotating moving parts not stationary parts, all my suspension did was magnify what was already there it didn't cause it.
post #15 of 29 Old July 6th, 2013, 04:41 AM
UDEAFBRO?'s Avatar
Looks like I'll be buying one with a watts link as well. Car should feel entirely different after this.
post #16 of 29 Old July 6th, 2013, 10:34 AM
Don't BAAAAH 'Til Goatsday
xXFallout's Avatar
You haven't had your car for a month.
Yeah I think I'll be getting one after mustang week.
From here to infirmary......
0-60mph 0.5 sec. And we have liftoff!
xXFallout is offline
post #17 of 29 Old July 6th, 2013, 11:13 AM Thread Starter
Let it be known that I have Strange adjustable shocks/struts, v6 rear springs, GT500 upper strut mounts, GT500 LCAs, Roush UCA and mount...so I clearly have a modified suspension under the car and still no vibrations. I can't change the pinion angle if I wanted to
2011 GT/CS 6R80
post #18 of 29 Old July 6th, 2013, 11:42 AM
Already have one and yes my car handles like its on rails.the car is totally transformed. Dont forget solid sway bars, much stronger then the hollow ones most venders sell...
post #19 of 29 Old July 6th, 2013, 12:03 PM
xXFallout's Avatar
I have eibach front and rear sway bars. I don't follow?
post #20 of 29 Old July 6th, 2013, 02:14 PM
Quoted the wrong quote it was for the other guy about the watts link...
