Wish me luck on the cam install... - Page 53 - Forums at Modded Mustangs
 1Likes
post #1041 of 1155 Old April 8th, 2014, 03:36 PM
Originally Posted by fullmetal7777 View Post
Awesome, this makes me feel better. My only issue is after driving it, it's extremely fuckin difficult to keep it alive at neutral because itl just bomb down to 500, so unless I don't quickly catch it, and somehow be hitting the gas at the same time, it's dead, and I'm stuck in the road for a few seconds lol but I can atleast drive it normally now, so I'll probly just drive it when I'm going to brookshires or something lol does this mean I get to put the bumper on?!
Yeah just drive it around and you should notidce that getting better. There is also a cycle you can go through to help the cumputer learn but I don't know what it all entails.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #1042 of 1155 Old April 8th, 2014, 03:46 PM
Insomniac
BIGCHRISS197's Avatar
Clear kam data, let idle 10 min, turn defrost on let idle for 10 min
BIGCHRISS197 is offline
post #1043 of 1155 Old April 8th, 2014, 05:28 PM Thread Starter
fullmetal7777's Avatar
How do I go about clearing the kam? I don't actually know where the defrost is either lol
Edit: for clearing the kam, I've read just to disconnect the battery for like 15 minutes and press on the brake pedal for a few seconds to pull all the power out of the system. Is that right?
CDC Chin Spoiler - Roush Upper/Lower Grill - Shaker Hood - MGW Shifter - MAC Prochambers/Headers - Roush O/R Extreme Catback - Eibach Lowering Springs - FRPP Hot Rod Cams - Halos/6K HID'S - BBK CAI
fullmetal7777 is offline
post #1044 of 1155 Old April 8th, 2014, 05:55 PM
Insomniac
That is correct, the defrost is the window setting on your hvac turn dial
post #1045 of 1155 Old April 8th, 2014, 06:27 PM
Don't you need to run the A/C also?
07 Boss is offline
post #1046 of 1155 Old April 8th, 2014, 06:36 PM Thread Starter
I'll probly look up the idle thing later and make sure
post #1047 of 1155 Old April 8th, 2014, 06:57 PM
Insomniac
The defrost does use the ac
post #1048 of 1155 Old April 8th, 2014, 07:44 PM
Really? Didn't know that, I guess it does dry out the air, just hought it used the heater. Shows you how much I know about HVAC.
07 Boss is offline
post #1049 of 1155 Old April 11th, 2014, 04:28 PM Thread Starter
Well I got this bitch running and put the tune on. Here's the 4/11
The tune fixed all my idle problems, but it still feels like it's skipping a little whenever I really give it some gas. My guess is that I'll circle jerk with bama for a bit till I finally decide to start saving for ceramic coating my headers then dyno tune. I'm just gunna be pretty chill driving it for a while most likely, but driving it none the less! Would a dyno tune most likely fix my problem?
All in all, car runs like a dream compared to before, so thank you guys so much for all the help, there really too many people to individually name because so many if y'all were constantly helping me lol I definitely couldn't of done it without y'all. <3<3
END CAM SAGA, stay tuned for the next season
post #1050 of 1155 Old April 11th, 2014, 04:34 PM
glad its running! and yes, a dyno tune SHOULD fix your problem as long as you bring it to a good shop. send more datalogs to bama, they can prob fix the problem you are still having if its not in your head
07 gt, CMS cams, hurst, CAI/tuned, LT's, o/r h, m80's, FRPP mani, UDP, lowered with steeda 1.25/1.5, exedy mach 400/race flywheel, 1-pc DS, BMR upper/lowers, 4.10's, CHE brace with TL's, and a few other things that dont add up to much.
fzr confused is offline
post #1051 of 1155 Old April 11th, 2014, 07:44 PM
Make Me Squirt
i am ryan's Avatar
Thank Baby Jesus. 53 pages. Good God! You were a trooper for sure.
TORCH RED APPRECIATION CLUB
C&L Racer | Eibach Pro-Kit | BMR LCAs + Relo | BMR PHB | MGW |
GT500 Strut Mounts | Bassanni Axlebacks | OR-H |Tokico D-Spec |
i am ryan is offline
post #1052 of 1155 Old April 11th, 2014, 08:23 PM Thread Starter
Super glad it's done for sure. Gotta get an oil dipstick and cop bolt before I start driving it, can't find either of em. Then on with the bumper and it's gravy. Totally worth it tho lol
post #1053 of 1155 Old April 11th, 2014, 09:01 PM
When you say it is skipping, what exactly do you mean? When you step on the gas at low RPM's, or does it when your engine speeds are up there? Does it happen all the way through the rpm band or just in particular areas?
07 Boss is offline
post #1054 of 1155 Old April 12th, 2014, 12:54 AM Thread Starter
Lower rpms, it's just really difficult to get up in the rpms starting from lower rpms when I hit the gas hard. If I'm just driving normally than it doesn't feel any different, only when I'm gassing it hard
post #1055 of 1155 Old April 12th, 2014, 01:24 AM
Have you driven a cammed car before? Not trying to sound condescending or anything like that. It's just what you described could just be the cams. The higher or narrower you make your powerband, the crappier it tends to run everywhere else. Not saying that's what it is but for someone who doesn't have much experience driving a cammed car may not be familiar with it's nuances. I've driven cars that you had to constantly goose the throttle just to keep it running. Let's say your cruising at like 3000 RPM's and then romp on the gas, does it feel like it's skipping, or does she just run smooth?
07 Boss is offline
post #1056 of 1155 Old April 12th, 2014, 08:11 AM
Power down low is going to take a beating, especially with stock gears.
post #1057 of 1155 Old April 12th, 2014, 08:38 AM
If you don't have 3.73 or 4.10 gears, then that is normal. Those cams require gears.
geo06 is offline
post #1058 of 1155 Old April 12th, 2014, 01:11 PM Thread Starter
Nah your fine, I definitely have never driven a canned car. My driving experience involves a Prius, super old f150, and a tiburon lol I'll try a catch a video of it probly tomarrow so you can see. I think above 3k tho it would probly drive fine if I romped the gas, but any lower than that and it feels twitchy.
So like if I'm in fourth and it running around 3k, then shift into 5th and hit the gas hard, it would really feel like it's skipping (I'm using skipping as a general feeling, not like in a mechanical term, if that is one)
---------- Post added at 12:11 PM ---------- Previous post was at 12:08 PM ----------
Guess I might start lookin into some 3.73's soon. I don't wanna go through a DD with 4.10's again lol
post #1059 of 1155 Old April 12th, 2014, 01:16 PM
Eat Springs, Shit Valves
AnotherS197GT's Avatar
iTrader: 11 reviews
No shit, 5th is overdrive. You aren't gonna go anywhere fast in 5th.
AnotherS197GT is offline
post #1060 of 1155 Old April 12th, 2014, 01:18 PM Thread Starter
Yeah yeah I know lol but its mainly the fact that it skips really hard.
