Camshaft bearing cap broken - Forums at Modded Mustangs
post #1 of 32 Old August 8th, 2014, 09:04 PM Thread Starter
Her name is Tiffany.
ryandcampbell44's Avatar
So I was installing my new mutha thumprs and I accidentally broke the front cam cap and now I don't know what to do... I'm not sure if ford sells them individually. Should I try to outsource one or go to a machine shop first and see if they can fix it? My car is sadly down until this gets fixed.
AirRaid Cai, Comp Mutha Thumprs, Mac o/r Prochamber, Mac Boom Tubes, Bama Tunes
ryandcampbell44 is offline
post #2 of 32 Old August 8th, 2014, 10:26 PM
Make Me Squirt
i am ryan's Avatar
Looks like this guy had the same issue and had it welded back together. Problem with this source is that they never returned to update the thread. I would definitely talk to a machine shop.
Cam Bearing Cap! Need Help!!
The torque specs are 89 in/lbs. You can ask fullmetal7777 about the difference between in/lbs and ft/lbs.
As a side note, it would be helpful to future people searching if you included pictures and kept the thread updated. Too many people have unique issues like this and find relevant threads with no resolution or conclusion.
Good luck! Keep us updated!
TORCH RED APPRECIATION CLUB
C&L Racer | Eibach Pro-Kit | BMR LCAs + Relo | BMR PHB | MGW |
GT500 Strut Mounts | Bassanni Axlebacks | OR-H |Tokico D-Spec |
i am ryan is offline
post #3 of 32 Old August 8th, 2014, 11:30 PM
More Is Better.
DiMora's Avatar
I think you have to pull the whole head. Those cam caps and journals are line- honed.
Roush TVS Supercharger / T56 Magnum XL 6 speed
Steeda suspension /Big Brakes / BMR K Member
Mac L/T's / Prochamber / Roush Extremes
"Daily Driver" RWHP: [email protected] PSI w/ LT's
"Dyno Queen": [email protected] PSI-stock exhaust
Mods in Garage
DiMora is offline
post #4 of 32 Old August 9th, 2014, 02:13 AM
That's what I was thinking too. The cam towers are not replaceable like the TFS 2v heads. Even if you were to try and get it welded, there's no way of machining it to the proper size without overboring all the rest of them. If there was a way to overbore them and then put bushings and then line hone, that would be a solution, but the cost involved is way too prohibitive to be worthwhile. You'd be better off going to a scrap yard and pulling a good low mileage head. F150 or any other 3V 4.6L application should interchange properly iirc.
2010 Camaro 2SS LS3/Brembo Victory Red/Black
SCT X4 base tune, Speed Engineering 1 7/8" LT's, CAI intake, Outlaw a/b
12.65 @ 115 as of 9/19/15
2009 GT Premium 5A BSM Rip 4/3/15
12.9 @ 106 best before loss
09Silverbullet is offline
post #5 of 32 Old August 9th, 2014, 04:01 AM Thread Starter
So I went to the machine shop today and he said the same thing that he would want the head but after he looked at it it was an easy enough weld that he thought he could fix it and I think he did a good job with it. I'll send you pics in a bit. I'm getting ready to see how it fits. It didn't screw up the bearing part at all. So I'm keeping my fingers crossed!!!
---------- Post added at 09:01 PM ---------- Previous post was at 08:20 PM ----------
Another question I have is why is the timing chain resting up on the head? I have tightened and torqued all the bolts down and have just the valve cover left to do. I'm unable to get pictures uploaded for some reason.
post #6 of 32 Old August 9th, 2014, 05:43 AM
Insomniac
BIGCHRISS197's Avatar
Use a photo host site like photobucket and post the [img] link
BIGCHRISS197 is offline
post #7 of 32 Old August 9th, 2014, 01:16 PM
What do you mean resting on the head? Like there is no tension on it, it's just laying there slack?
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #8 of 32 Old August 9th, 2014, 04:14 PM
Insomniac
Hopefully he didnt put the wrong cam in each side, theyre different lengths.
post #9 of 32 Old August 9th, 2014, 04:15 PM Thread Starter
No it's tight. But on the drivers side where it's coming up out of the timing chain cover and over the cam phaser it rubs very slightly. But everything is lined up perfectly
---------- Post added at 09:15 AM ---------- Previous post was at 09:14 AM ----------
Minus that obviously
post #10 of 32 Old August 9th, 2014, 10:11 PM
That seems odd. Did you put the cams on the right sides? I know one is shorter than the other but I'm not sure if you can put them in on the wrong sides.
07 Boss is offline
post #11 of 32 Old August 9th, 2014, 10:29 PM
00blkvert
Defiantly possible the cam is in on the wrong side. If it's the shorter cam it's going to pull it closer to the head I would think.
Cammin' 08 is offline
post #12 of 32 Old August 9th, 2014, 11:40 PM Thread Starter
Which side has the shorter cam? I thought the passenger side did?
post #13 of 32 Old August 9th, 2014, 11:58 PM
00blkvert
The passenger side is shorter
post #14 of 32 Old August 10th, 2014, 03:58 AM Thread Starter
Alright so thank you guys so much!! For everybody else:
ATTENTION: Do not install your cams on the wrong side! It's easy to do and just be careful of which one goes on which side.
Besides that I am buttoning up everything tonight and going to start her up tomorrow and hope she runs good!!
post #15 of 32 Old August 10th, 2014, 04:27 AM
Insomniac
Glad to see you got her all sorted out. Good luck!
post #16 of 32 Old August 10th, 2014, 07:14 PM Thread Starter
And the car runs beautifully!! Totally worth the headache and problems I went through!! I'm def proficient at swapping cams in 3v's now!! Lol!!
How long would you guys suggest break in period be?
---------- Post added at 12:13 PM ---------- Previous post was at 12:07 PM ----------
http://<a href="http://s1281.photobu...&#91;/IMG]</a>
Here's the broken cam cap after I had it welded. It's ugly on the outside but it looks good on the inside with no rubbing on the cam at all.
---------- Post added at 12:14 PM ---------- Previous post was at 12:13 PM ----------
And this is what happens to the timing chain if you install the cams on the wrong side :S
post #17 of 32 Old August 10th, 2014, 08:23 PM
Rankus06's Avatar
looks like your links are bad.......
322 hp/ 329 tq
C&L Racer CAI
Kooks headers with catted H
Borla Touring Mufflers
FRPP 4:10s
Steeda UDP
CHE UCA
BMR LCA, Relocation Brackets, Panhard, Handling Springs
Steeda Srut Mounts
Koni ST-R
MGW shifter
Rankus06 is offline
post #18 of 32 Old August 10th, 2014, 08:33 PM
Insomniac
How long would you guys suggest break in period be?[COLOR="Silver"]
[SIZE=1]---------- Post added at 12:13 PM ---------- Previous post was
Here's the broken cam cap after I had it welded. It's ugly on the outside but it looks good on the inside with no rubbing on the cam at all.[COLOR="Silver"]
Did that fix it?
post #19 of 32 Old August 10th, 2014, 09:56 PM Thread Starter
Originally Posted by BIGCHRISS197 View Post
Did that fix it?
Ya placing the correct cam on the correct side made for a much better figment!
---------- Post added at 02:56 PM ---------- Previous post was at 02:56 PM ----------
How are my links bad?
post #20 of 32 Old August 10th, 2014, 11:22 PM
Insomniac
The [img] links you posted were messed up and the pictures wouldn't display. I fixed them in my quote. Thats what I was asking if it fixed. Glad you got the car sorted out and this headache is over. We had one member spend a few with problem after problem getting his sorted out.
